G900P15K
P-Channel Enhancement Mode Power MOSFET
Description
The G900P15K uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
General Features
l
l
l
l
VDS
ID (at VGS = -10V)
RDS(ON) (at VGS = -10V)
100% Avalanche Tested
-150V
-50A
< 80mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-252
Ordering Information
Device
Package
Marking
Packaging
G900P15K
TO-252
G900P15
2500pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
-150
V
ID
-50
A
IDM
-200
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
96
W
EAS
132
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
50
ºC/W
Maximum Junction-to-Case
RthJC
1.3
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1672)
G900P15K
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = -250µA
-150
V
IDSS
VDS = -150V, VGS = 0V
-1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = -250µA
-1
-2.5
-4
V
Drain-Source On-Resistance
RDS(on)
VGS = -10V, ID = -5A
65
80
mΩ
gFS
VDS = -5V,ID = -5A
9
S
3918
149
106
27
7
3
9
10
29
4
Static Parameters
Forward Transconductance
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = -75V,
f = 1.0MHz
VDD = -75V,
ID = -5A,
VGS = -4.5V
VDD = -75V,
ID = -5A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
-50
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = -5A, VGS = 0V
-1.2
V
Reverse Recovery Charge
Qrr
434
nC
Reverse Recovery Time
Trr
51
ns
IF = -5A, VGS = 0V
di/dt=-500A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=-50V,VGS=-10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G900P15K
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G900P15K
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
30
-10V
25
-ID, Drain Current (A)
30
-5.5V
-4.5V
15
-4V
10
-3.5V
5
VDS= -5V
25
25℃
10
5
VGS=-3.3V
2
3
-VDS, Drain-to-Source Voltage (V)
2
-Vgs Gate-Source Voltage(V)
RDS(on), On-Resistance (mΩ)
120
100
80
VGS= -10V
40
4
6
8
8
Figure 4. Gate Charge
140
-VGS, Gate-to-Source Voltage (V)
Figure 3.Drain Source On Resistance
60
4
10
6
4
2
-ID-Drain Current (A)
VDD = -75V,
ID = -5A
8
10
15
30
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
Capacitance(pF)
5000
-Is, Reverse Drain Current (A)
6000
Ciss
4000
3000
2000
1000
Coss
0 Crss
40
50
60
-VDS Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
-VSD, Source-to-Drain Voltage (V)
G900P15K
Figure 10. Safe Operation Area
VGS = -10V
ID = -5A
-ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ(MAX)=150℃
TC=25℃
ZthJC, Thermal Impedance (ºC/W)
TJ, Junction Temperature (ºC)
-VDS, Drain-Source Voltage(V)
Figure 9. Normalized Maximum Transient
Thermal Impedance
1.3°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G900P15K
TO-252 Package information
E
c
H
D
D1
L5
L3
b3
E1
L4
A2
b
θ
L
A1
L2
A
e
(L1)
COMMON DIMENSIONS
SYMBOL
A
A1
mm
MIN
NOM
MAX
2.20
2.30
2.40
0.00
0.20
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
E1
4.63
e
6.60
6.80
2.286BSC
H
9.40
10.10
10.50
L
1.38
1.50
1.75
L1
L2
L3
L4
L5
θ
www.gofordsemi.com
2.90REF
0.51BSC
0.88
1.28
0.50
1.00
1.65
1.80
1.95
8°
0°
TEL:0755-29961263
很抱歉,暂时无法提供与“G900P15K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.04600
- 10+6.75000
- 30+6.10200
