G15P04K
G15P04K
    GOFORD(谷峰)
    TO-252(DPAK)
    表面贴装型 P 通道 40 V 15A 50W TO-252(DPAK)
G15P04K 数据手册
GOFORD G15P04K P-Channel Enhancement Mode Power MOSFET Description The G15P04K uses advanced trench technology to provide excellent RDS(ON) , low gate charge. It can be used in a wide variety of applications. General Features ⚫ ⚫ ⚫ ⚫ ⚫ VDS ID (at VGS = -10V) RDS(ON) (at VGS = -10V) RDS(ON) (at VGS = -4.5V) 100% Avalanche Tested -40V -15A < 39mΩ < 70mΩ Schematic diagram ⚫ RoHS Compliant Application ⚫ Power switch ⚫ DC/DC converters TO-252 Device Package Marking Packaging G15P04K TO-252 G15P04 2500pcs/Reel Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDS -40 V ID -15 A IDM -60 A VGS ±20 V EAS 36 mJ PD 50 W TJ, Tstg -55 To 150 ºC Symbol Value Unit RthJC 3 ºC/W Drain-Source Voltage Continuous Drain Current Pulsed Drain Current (note1) Gate-Source Voltage Single Pulse Avalanche Energy (note3) Power Dissipation Operating Junction and Storage Temperature Range Thermal Resistance Parameter Thermal Resistance, Junction-to-Case www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 (A1430) GOFORD G15P04K Specifications TJ = 25ºC, unless otherwise noted Value Parameter Symbol Test Conditions Unit Min. Typ. Max. Static Parameters Drain-Source Breakdown Voltage V(BR)DSS VGS = 0V, ID = -250µA -40 -- -- V Zero Gate Voltage Drain Current IDSS VDS = -40V, VGS = 0V -- -- -1 uA Gate-Source Leakage IGSS VGS = ±20V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = -250µA -1.0 -1.5 -3.0 V VGS = -10V, ID = - 10A -- 25 39 Drain-Source On-Resistance RDS(on) VGS = -4.5V, ID = - 8A -- 30 70 VDS=10V,ID=-10A -- 10 -- -- 930 -- -- 85 -- -- 35 -- -- 25 -- -- 3 -- Forward Transconductance mΩ gFS S Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg VGS = 0V, VDS = -20V, f = 1.0MHz VDD = -20V, ID = -6A, VGS = -10V Gate-Source Charge Qgs Gate-Drain Charge Qgd -- 7 -- Turn-on Delay Time td(on) -- 8 -- Turn-on Rise Time tr -- 4 -- Turn-off Delay Time td(off) -- 32 -- -- 7 -- Turn-off Fall Time VDD = -20V, ID = -6A, RG = 3Ω tf pF nC ns Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25ºC -- -- -15 A Body Diode Voltage VSD TJ = 25ºC, ISD = -10A, VGS = 0V -- -- -1.2 V Reverse Recovery Time Trr -- 25 -- ns Reverse Recovery Charge Qrr -- 31 -- nc IS = -15A, VGS = 0V di/dt=-100A/us Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. Identical low side and high side switch with identical R G 3. VDD = -40V, RG = 25Ω, L=0.5 mH, Starting TJ = 25°C 。 www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 (A1430) GOFORD G15P04K Gate Charge Test Circuit Switch Time Test Circuit EAS Test Circuit www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 (A1430) GOFORD G15P04K Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 2. Transfer Characteristics - ID, Drain Current (A) -ID, Drain Current (A) Figure 1. Output Characteristics 125℃ 25℃ -VDS, Drain-to-Source Voltage (V) -VGS, Gate-to-Source Voltage (V) Figure 4. Drain Source On Resistance RDS(on),On-Resistance(mΩ) -Vgs Gate-Source Voltage(V) Figure 3. Gate Charge VDD=-20V ID=-15A Qg Gate Charge(nC) VGS=-4.5V VGS=-10V -ID-Drain Current(A) Figure 6. Source-Drain Diode Forward Capacitance(pF) -Is, Reverse Drain Current (A) Figure 5. Capacitance -Vds Drain-Source Voltage(V) www.gofordsemi.com TEL:0755-29961263 -VSD, Source-to-Drain Voltage (V) FAX:0755-29961466 (A1430) GOFORD G15P04K Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 8. Safe Operation Area RDS(on), (Normalized) VGS=-10V ID=-10A VGS=-4.5V ID=-8A -ID, Drain Current(A) Figure 7. Drain-Source On-Resistance TJ, Junction Temperature (ºC) TJ(MAX)=150℃ TC=25℃ -VDS, Drain-Source Voltage(V) ZthJC, Thermal Impedance (ºC/W) Figure 9. Normalized Maximum Transient Thermal Impedance Pulse Width (s) www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 (A1430) GOFORD G15P04K TO-252 Package Information Symbol A A1 A2 b b3 c D D1 E E1 e H L L1 L2 L3 L4 L5 θ www.gofordsemi.com Dimensions in Millimeters MIN. NOM. MAX. 2.2 2.3 2.4 0 0.2 0.97 1.07 1.17 0.68 0.78 0.9 5.2 5.33 5.5 0.43 0.53 0.63 5.98 6.1 6.22 5.30REF 6.4 6.6 6.8 4.63 2.286BSC 9.4 10.1 10.5 1.38 1.5 1.75 2.90REF 0.51BSC 0.88 1.28 0.5 1 1.65 1.8 1.95 0° 8° TEL:0755-29961263 FAX:0755-29961466 (A1430)
G15P04K 价格&库存
很抱歉,暂时无法提供与“G15P04K”相匹配的价格&库存,您可以联系我们找货
