GT100N12K
N-Channel Enhancement Mode Power MOSFET
Description
The GT100N12K uses advanced trench technology to
provide excellent RDS(ON) , low gate charge. It can be used in
a wide variety of applications.
General Features
⚫ VDS
⚫ ID (at VGS = 10V)
⚫ RDS(ON) (at VGS = 10V)
⚫ 100% Avalanche Tested
120V
65A
< 12mΩ
Schematic Diagram
⚫ RoHS Compliant
Application
⚫ Power switch
⚫ DC/DC converters
TO-252
Ordering Information
Device
Package
Marking
Packaging
GT1 0 0 N1 2K
TO- 252
GT100N12
2500pcs/ Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Symbol
Value
Unit
V DS
120
V
ID
65
A
IDM
260
A
V GS
±20
V
PD
75
W
TJ , Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
46
ºC/W
Maximum Junction-to-Case
RthJC
1.67
ºC/W
Parameter
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Gate-Source Voltage
Power Dissipation
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1320)
GT100N12K
Specifications TJ = 25ºC, unless otherwise noted
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V (BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Parameter
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = 250µA
120
V
IDSS
VDS = 120V, VGS = 0V
1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS , ID = 250µA
2.5
3
3.5
V
Drain-Source On-Resistance
RDS(on)
VGS = 10V, ID = 35A
9.5
12
mΩ
Forward Transconductance
gFS
VDS = 5V,ID = 35A
46
S
2911
329
11
50
17
15
15
10
34
8
Static Parameters
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
Turn-off Delay Time
tr
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = 60V,
f = 1.0MHz
VDS = 60V,
ID = 35A,
VGS = 10V
VDD = 60V,
ID = 35A,
RG = 1.6Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
Body Diode Voltage
IS
TC = 25ºC
65
A
V SD
TJ = 25ºC, ISD = 35A, VGS = 0V
1.2
V
106
nC
60
ns
Reverse Recovery Charge
Qrr
Reverse Recovery Time
Trr
IF = 35A, VGS = 0V
di/dt=100A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
www.gofordsemi.com
TEL:0755-29961263
GT100N12K
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
GT100N12K
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
120
120
10V
VDS= 5V
6.5V
6V
80
ID, Drain Current (A)
100
5.5V
60
5V
40
2
80
60
25℃
40
VGS=4.5V
3
VDS, Drain-to-Source Voltage (V)
Vgs Gate-Source Voltage(V)
RDS(on), On-Resistance (mΩ)
16
14
12
VGS= 10V
8
6
4
Coss
1500
1000
500
Crss
10
VDD = 60V
ID =35A
8
6
4
2
40
50
60
Is, Reverse Drain Current (A)
Capacitance(pF)
Ciss
2000
10
Figure 6. Source-Drain Diode Forward
4000
2500
8
Qg Gate Charge(nC)
Figure 5. Capacitance
3000
6
Figure 4. Gate Charge
ID-Drain Current (A)
3500
4
VGS, Gate-to-Source Voltage (V)
Figure 3.Drain Source On Resistance
10
2
40
50
60
VDs Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
GT100N12K
Figure 10. Safe Operation Area
VGS=10V
ID=35A
ID=35A
ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
ZthJC, Thermal Impedance (ºC/W)
TJ, Junction Temperature (ºC)
VDS, Drain-Source Voltage(V)
Figure 9. Normalized Maximum Transient
Thermal Impedance
1.67°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
GT100N12K
TO-252 Package Information
Symbol
A
A1
A2
b
b3
c
D
D1
E
E1
e
H
L
L1
L2
L3
L4
L5
θ
www.gofordsemi.com
MIN.
2.2
0.68
5.2
0.43
5.98
6.4
4.63
9.4
1.38
0.88
0.5
1.65
0°
Dimensions in Millimeters
NOM.
2.3
1.07
0.78
5.33
0.53
6.1
5.30REF
6.6
2.286BSC
10.1
1.5
2.90REF
0.51BSC
1.8
TEL:0755-29961263
MAX.
2.4
0.2
1.17
0.9
5.5
0.63
6.22
6.8
10.5
1.75
1.28
1
1.95
8°
很抱歉,暂时无法提供与“GT100N12K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.49280
- 10+3.65040
- 30+3.22920
- 100+2.80800
