UMW
R
UMW 100N03A
30V N-Channel Power
UMW 100N03A
Mosfet
General Description
These N-channel enhancement mode power mosfets used
advanced trench technology design, provided excellent Rdson
and low gate charge. Which accords with the RoHS standard.
Features
VDS = 30V,ID =90A
RDS(ON),3.8 mΩ(Typ) @ VGS =10V
RDS(ON), 6.4mΩ(Typ) @ VGS =4.5V
Low on resistance
Low gate charge
Fast switching
Low reverse transfer capacitances
Application
DC-DC converters
Synchronous Rectifier
Package Marking and Ordering Information
Device Marking
Device
Device Package
UMW 100N03A
UMW 100N03A
TO-252
Reel Size
Tape width
330mm
QuantitY
12mm
2500
Absolute Maximum Ratings(TA=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
30
V
Gate-Source Voltage
VGS
±20
V
90
A
63
A
Drain Current-ContinuousNote3
TC=25℃
TC=100℃
ID
Drain Current-Pulsed
IDM
200
A
Avalanche Energy
EAS
280
mJ
Avalanche Current
IAS
33
A
PD
105
W
TSTG
-55 to +150
TJ
-55 to +150
Note1
Note4
Maximum Power Dissipation
TC=25℃
Storage Temperature Range
Operating Junction Temperature Range
Thermal Resistance
Parameter
Thermal Resistance,Junction-to-Case
www.umw-ic.com
Symbol
Min.
Typ.
Max
Unit
RθJC
3.3
℃/W
1
友台半导体有限公司
UMW
R
UMW 100N03A
Electrical Characteristics(TJ=25℃ unless otherwise noted)
OFF CHARACTERISTICS
Parameter
Symbol
Conditions
VGS=0V,IDS=250uA
Min.
Typ.
Max.
Unit
30
V
Drain-Source Breakdown Voltage
BVDSS
Zero Gate Voltage Drain Current
IDSS
VDS=30V,VGS=0V
1
uA
Gate-Body Leakage
IGSS
VGS=±20V,VDS=0V
±100
nA
ON CHARACTERISTICS
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
Gate Threshold Voltage
VGS(TH)
VDS=VGS,IDS=250uA
1.0
1.7
2.5
V
Drain-Source On-State Resistance
RDS(ON)
VGS=10V,IDS=30A
3.8
4.9
VGS=4.5V,IDS=20A
6.4
7.9
Conditions
Min.
Typ.
Max.
1963
248
221
1.43
Ω
Min.
Typ.
Max.
Unit
55
36.4
37.5
14
41
6.4
11
mΩ
DYNAMIC CHARACTERISTICS
Parameter
Symbol
Input Capacitance
CiSS
Output Capacitance
COSS
Reverse Transfer Capacitance
Crss
Gate Resisitance
Rg
VDS =15V, VGS = 0V,
f=1MHz
VDD=0V,VGS=1V,
F=1MHz
Unit
pF
SWITCHING CHARACTERISTICS
Parameter
Turn-On Delay Time
Rise Time
Symbol
Td(on)
tr
Turn-Off Delay Time
Fall Time
Conditions
VGS=10V,VDs=15V,
RGEN=3Ω
Td(off)
ID=20A
tf
Total Gate Charge at 10V
Qg
Gate to Source Gate Charge
Qgs
Gate to Drain“Miller”Charge
Qgd
VDS=15V,IDS=45A,
VGS=10V
ns
nC
DRAIN-SOURCE DIODE CHARACTERISTICS AND MAXIMUM RATINGS
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
VSD
VGS=0V,IDS=20A
1.2
V
Reverse Recovery Time
trr
TJ=25℃,IF=20A
21.7
nS
Reverse Recovery Charge
Qrr
di/dt=100A/us
7.2
nC
Drain-Source Diode Forward Voltage
Notes:
1: Repetitive rating, pulse width limited by maximum junction temperature.
2: Surface mounted on FR4 Board, t≤10sec.
3: Pulse width ≤ 300μs, duty cycle ≤ 2%.
4: EAS condition: L=0.5mH,VDD=15V,VG=10V,VGATE=30V,Start TJ=25℃.
www.umw-ic.com
2
友台半导体有限公司
UMW
R
www.umw-ic.com
UMW 100N03A
3
友台半导体有限公司
UMW
R
www.umw-ic.com
UMW 100N03A
4
友台半导体有限公司
UMW
R
www.umw-ic.com
UMW 100N03A
5
友台半导体有限公司
UMW
R
www.umw-ic.com
UMW 100N03A
6
友台半导体有限公司
很抱歉,暂时无法提供与“100N03A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.96481
- 100+0.74166
- 1250+0.62847
- 2500+0.58212
- 国内价格
- 5+1.20834
- 50+0.94158
- 500+0.68473
- 1000+0.67446
- 2500+0.54527
- 国内价格
- 5+1.33164
- 50+1.03767
- 150+0.91174
- 500+0.75460
- 2500+0.60092
- 5000+0.55890
