GT060N04K
N-Channel Enhancement Mode Power MOSFET
Description
The GT060N04K uses advanced trench technology to
provide excellent RDS(ON) , low gate charge. It can be used in
a wide variety of applications.
General Features
l
l
l
l
l
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 10V)
RDS(ON) (at VGS = 4.5V)
100% Avalanche Tested
40V
54A
5.5mΩ
7.5mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-252
Ordering Information
Device
Package
Marking
Packaging
GT060N04K
TO-252
GT060N04
2500psc/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
40
V
ID
54
A
IDM
216
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
44
W
EAS
56
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
50
ºC/W
Maximum Junction-to-Case
RthJC
2.8
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1612)
GT060N04K
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = 250µA
40
V
IDSS
VDS = 40V, VGS = 0V
1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
1
1.6
2.3
V
Drain-Source On-Resistance
RDS(on)
VGS = 10V, ID = 30A
4.5
5.5
VGS = 4.5V, ID = 20A
6
7.5
Forward Transconductance
gFS
VGS = 5V, ID = 30A
56
1279
647
32
19
4.5
2.3
6
2.5
23
4
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = 20V,
f = 1.0MHz
VDD = 20V,
ID = 30A,
VGS = 10V
VDD = 20V,
ID = 30A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
54
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = 30A, VGS = 0V
1.2
V
Reverse Recovery Charge
Qrr
31
nC
Reverse Recovery Time
Trr
IF = 30A, VGS = 0V
di/dt=500A/us
15.5
ns
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=40V,VGS=10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
GT060N04K
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
GT060N04K
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
5V
10V
6V
ID, Drain Current (A)
100
120
VDS= 5V
4.5V
120
Figure 2. Transfer Characteristics
4V
80
60
VGS= 3.5V
40
80
60
40
25℃
2
3
VDS, Drain-to-Source Voltage (V)
Vgs Gate-Source Voltage(V)
Figure 3. Drain Source On Resistance
RDS(on),On-Resistance(mΩ)
10
VGS= 4.5V
6
VGS= 10V
4
2
4
6
8
VGS, Gate-to-Source Voltage (V)
12
8
2
Figure 4. Gate Charge
10
8
6
4
2
ID-Drain Current(A)
VDD = 40V
ID = 30A
10
15
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
Is, Reverse Drain Current (A)
2500
Capacitance(pF)
2000
Ciss
1500
1000
Coss
500
Crss
40
VDS Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
GT060N04K
VGS = 10V,
ID = 30A
VGS = 4.5V,
ID = 20A
Figure 8. Safe Operation Area
ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ, Junction Temperature (ºC)
TJ(MAX)=150℃
TC=25℃
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
2.8°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
GT060N04K
TO-252 Package Information
E
c
H
D
D1
L5
L3
b3
E1
L4
A2
b
θ
L
A1
L2
A
e
(L1)
COMMON DIMENSIONS
SYMBOL
A
A1
mm
MIN
NOM
MAX
2.20
2.30
2.40
0.00
0.20
A2
0.97
1.07
1.17
b
0.68
0.78
0.90
b3
5.20
5.33
5.50
c
0.43
0.53
0.63
D
5.98
6.10
6.22
D1
5.30REF
E
6.40
E1
4.63
e
6.60
6.80
2.286BSC
H
9.40
10.10
10.50
L
1.38
1.50
1.75
L1
L2
L3
L4
L5
θ
www.gofordsemi.com
2.90REF
0.51BSC
0.88
1.28
0.50
1.00
1.65
1.80
1.95
8°
0°
TEL:0755-29961263
很抱歉,暂时无法提供与“GT060N04K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.81880
- 10+2.24640
- 30+2.00880
- 100+1.69560
