G20P10KE
P-Channel Enhancement Mode Power MOSFET
Description
The G20P10KE uses advanced trench technology to
provide excellent RDS(ON) , low gate charge. It can be used in
a wide variety of applications.
General Features
l
l
l
l
VDS
ID (at VGS = -10V)
RDS(ON) (at VGS = -10V)
100% Avalanche Tested
-100V
-20A
< 116mΩ
Schematic diagram
l RoHS Compliant
l ESD (HBM)>7.0KV
Application
l Power switch
l DC/DC converters
TO-252
Ordering Information
Device
Package
Marking
Packaging
G20P10KE
TO-252
G20P10
2500pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
-100
V
ID
-20
A
IDM
-80
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
69
W
EAS
56
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
25
ºC/W
Maximum Junction-to-Case
RthJC
1.8
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1418-V1.3)
G20P10KE
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = -250µA
-100
V
IDSS
VDS = -100V, VGS = 0V
-1
μA
IGSS
VGS = ±20V
±10
uA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = -250µA
-1
-1.5
-3
V
Drain-Source On-Resistance
RDS(on)
VGS = -10V, ID = -16A
94
116
mΩ
Forward Transconductance
gFS
VDS = -5V,ID = -16A
35
S
3354
89
87
70
12.5
15.5
16
73
34
57
Static Parameters
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = -50V,
f = 1.0MHz
VDD = -50V,
ID = -16A,
VGS = -10V
VDD = -50V,
ID = -16A,
RG = 9Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
-20
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = -16A, VGS = 0V
-1.2
V
Reverse Recovery Charge
Qrr
66
nC
Reverse Recovery Time
Trr
88
ns
IF = -16A, VGS = 0V
di/dt=-500A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=-50V,VGS=-10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
G20P10KE
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G20P10KE
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
18
-ID, Drain Current (A)
30
-10V
16
VDS= -5V
-3.5V
-4.5V
Figure 2. Transfer Characteristics
-3V
14
12
10
8
-2.7V
6
4
VGS= -2.5V
2
2
3
25
5
25℃
10
-VDS, Drain-to-Source Voltage (V)
140
120
100
VGS= -10V
60
2500
2000
1500
1000
Coss
Crss
40
50
8
6
4
2
60
80
60
-VDS Drain-Source Voltage(V)
www.gofordsemi.com
VDD = -50V,
ID = -16A
-Is, Reverse Drain Current (A)
Capacitance(pF)
Ciss
3000
Figure 6. Source-Drain Diode Forward
4500
500
5
Qg Gate Charge(nC)
Figure 5. Capacitance
3500
4
10
-ID-Drain Current (A)
4000
3
Figure 4. Gate Charge
-Vgs Gate-Source Voltage(V)
RDS(on), On-Resistance (mΩ)
160
40
2
-VGS, Gate-to-Source Voltage (V)
Figure 3.Drain Source On Resistance
80
1
TEL:0755-29961263
-VSD, Source-to-Drain Voltage (V)
G20P10KE
Figure 10. Safe Operation Area
-ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
VGS = -10V,
ID = -16A
ZthJC, Thermal Impedance (ºC/W)
TJ, Junction Temperature (ºC)
-VDS, Drain-Source Voltage(V)
Figure 9. Normalized Maximum Transient
Thermal Impedance
1.8°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G20P10KE
TO-252 Package Mechanical Data
Symbol
A
A1
A2
b
b3
c
D
D1
E
E1
e
H
L
L1
L2
L3
L4
L5
θ
www.gofordsemi.com
MIN.
2.2
0.68
5.2
0.43
5.98
6.4
4.63
9.4
1.38
0.88
0.5
1.65
0°
Dimensions in Millimeters
NOM.
2.3
1.07
0.78
5.33
0.53
6.1
5.30REF
6.6
2.286BSC
10.1
1.5
2.90REF
0.51BSC
1.8
TEL:0755-29961263
MAX.
2.4
0.2
1.17
0.9
5.5
0.63
6.22
6.8
10.5
1.75
1.28
1
1.95
8°
很抱歉,暂时无法提供与“G20P10KE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.69957
- 50+2.21519
- 150+2.00751
- 500+1.66277
- 2500+1.54743
- 5000+1.47820
