G58N06K
N-Channel Enhancement Mode Power MOSFET
Description
The G58N06K uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used
in a wide variety of applications.
General Features
l
l
l
l
l
VDS
60V
ID (at VGS = 10V)
58A
RDS(ON) (at VGS = 10V)
< 13mΩ
RDS(ON) (at VGS = 4.5V)
< 15mΩ
100% Avalanche Tested
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-252
Device
Package
Marking
Packaging
G58N06K
TO-252
G58N06
2500pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
60
V
ID
58
A
IDM
120
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
71
W
EAS
81
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
50
ºC/W
Maximum Junction-to-Case
RthJC
1.76
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1455)
G58N06K
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = 250µA
60
V
IDSS
VDS = 60V, VGS = 0V
1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
1
1.7
2.5
V
Drain-Source On-Resistance
RDS(on)
VGS = 10V, ID = 30A
10.5
13
VGS = 4.5V, ID = 25A
12
15
Forward Transconductance
gFS
VDS = 5V,ID = 20A
35
2841
155
139
36
10
6.5
12
5
38
27
Static Parameters
mΩ
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = 30V,
f = 1.0MHz
VDD = 30V,
ID = 30A,
VGS = 10V
VDD = 30V,
ID = 30A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
58
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = 30A, VGS = 0V
1.2
V
Reverse Recovery Charge
Qrr
35
nC
Reverse Recovery Time
Trr
IF = 30A, VGS = 0V
di/dt=100A/us
47
ns
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
Identical low side and high side switch with identical RG
3.
EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω
www.gofordsemi.com
TEL:0755-29961263
G58N06K
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G58N06K
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
Figure 2. Transfer Characteristics
140
10V
120
4.5V
100
4.2V
80
3.8V
60
3.5V
40
1
80
25℃
60
40
VGS=3.3V
VDS= 5V
120
ID, Drain Current (A)
140
2
3
VDS, Drain-to-Source Voltage (V)
15
14
VGS= 4.5V
11
10
VGS= 10V
9
8
7
6
6
8
Figure 4. Gate Charge
Vgs Gate-Source Voltage(V)
RDS(on),On-Resistance(mΩ)
16
12
4
VGS, Gate-to-Source Voltage (V)
Figure 3. Drain Source On Resistance
13
2
40
ID-Drain Current(A)
10
VDD = 30V
ID = 30A
8
6
4
2
40
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
Capacitance(pF)
3500
Is, Reverse Drain Current (A)
4000
Ciss
3000
2500
2000
1500
1000
Coss
500
Crss
40
50
60
VDs Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
G58N06K
Figure 8. Safe Operation Area
VGS=10V
ID=30A
VGS=4.5V
ID=25A
ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ(Max)=150℃
TC=25℃
VDS, Drain-Source Voltage(V)
TJ, Junction Temperature (ºC)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
1.76°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G58N06K
TO-252 Package Information
Symbol
A
A1
A2
b
b3
c
D
D1
E
E1
e
H
L
L1
L2
L3
L4
L5
θ
www.gofordsemi.com
MIN.
2.2
0.68
5.2
0.43
5.98
6.4
4.63
9.4
1.38
0.88
0.5
1.65
0°
Dimensions in Millimeters
NOM.
2.3
1.07
0.78
5.33
0.53
6.1
5.30REF
6.6
2.286BSC
10.1
1.5
2.90REF
0.51BSC
1.8
TEL:0755-29961263
MAX.
2.4
0.2
1.17
0.9
5.5
0.63
6.22
6.8
10.5
1.75
1.28
1
1.95
8°
很抱歉,暂时无法提供与“G58N06K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.88360
- 10+2.28960
- 30+2.03040
