TSM60NC1R5CP ROG
TSM60NC1R5CP ROG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-252(DPAK)
    表面贴装型 N 通道 600 V 3A(Tc) 55W(Tc) TO-252,(D-Pak)
TSM60NC1R5CP ROG 数据手册
TSM60NC1R5CP Taiwan Semiconductor N-Channel Power MOSFET 600V, 3A, 1.5Ω FEATURES KEY PERFORMANCE PARAMETERS ● Super-Junction technology PARAMETER VALUE UNIT VDS 600 V RDS(on) (max) 1.5 Ω Qg 8 nC ● High performance due to small figure-of-merit ● High ruggedness performance ● High commutation performance ● 100% UIS & Rg tested ● RoHS Compliant ● Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Power Supply ● Lighting TO-252 Note: MSL 3 (Moisture Sensitivity Level) per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL LIMIT UNIT Drain-Source Voltage VDS 600 V Gate-Source Voltage VGS ±20 V 3 A 2 A IDM 9 A Continuous Drain Current Pulsed Drain Current TC = 25°C (Note 1) ID TC = 100°C (Note 2) Total Power Dissipation @ TC = 25°C PD 55 W Single Pulse Avalanche Energy (Note 3) EAS 100 mJ Single Pulse Avalanche Current (Note 3) IAS 2 A TJ, TSTG - 55 to +150 °C SYMBOL LIMIT UNIT Junction to Case Thermal Resistance RӨJC 2.2 °C/W Junction to Ambient Thermal Resistance RӨJA 52 °C/W Operating Junction and Storage Temperature Range THERMAL PERFORMANCE PARAMETER Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. R ӨJA is guaranteed by design while RӨCA is determined by the user’s board design. 1 Version: C2209 TSM60NC1R5CP Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Static CONDITIONS SYMBOL MIN TYP MAX UNIT (Note 4) Drain-Source Breakdown Voltage VGS = 0V, ID = 1mA BVDSS 600 -- -- V Gate Threshold Voltage VDS = VGS, ID = 1mA VGS(TH) 3.5 4.2 5.5 V Gate Body Leakage VGS = ± 20V, VDS = 0V IGSS -- -- ±100 nA Zero Gate Voltage Drain Current VDS = 600V, VGS = 0V IDSS -- -- 100 µA Drain-Source On-State Resistance VGS = 10V, ID = 1A RDS(on) -- 1.3 1.5 Ω Qg -- 8.1 -- Qgs -- 2.5 -- Qgd -- 3.4 -- Ciss -- 235 -- Coss -- 16 -- Crss -- 10 -- Rg 0.84 2.8 5.6 td(on) -- 18 -- tr -- 17 -- td(off) -- 33 -- tf -- 40 -- Body-Diode Continuous Forward Current IS -- -- 3 A Body-Diode Pulsed Current ISM -- -- 9 A VSD -- -- 1.5 V Dynamic (Note 5) Total Gate Charge VDS = 300V, ID = 3A, Gate-Source Charge VGS = 10V Gate-Drain Charge Input Capacitance VDS = 300V, VGS = 0V, Output Capacitance f = 1.0MHz Reverse Transfer Capacitance Gate Resistance Switching f = 1.0MHz nC pF Ω (Note 6) Turn-On Delay Time Turn-On Rise Time VDD = 300V, RG = 10Ω, Turn-Off Delay Time ID = 1.5A, VGS = 10V Turn-Off Fall Time Source-Drain Diode ns (Note 4) Forward Voltage IS = 3A, VGS = 0V Reverse Recovery Time VDD = 300V, IS = 3A trr -- 250 -- ns Reverse Recovery Charge dIF/dt = 100A/μs Qrr -- 1.9 -- μC Notes: 1. Current limited by package. 2. Pulse width limited by the maximum junction temperature. 3. L = 50mH, VDD = 50V, RG = 25Ω, Starting TJ = 25 C 4. Pulse test: PW ≤ 300µs, duty cycle ≤ 2%. 5. For DESIGN AID ONLY, not subject to production testing. 6. Switching time is essentially independent of operating temperature. o ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TSM60NC1R5CP ROG TO-252 (DPAK) 2500pcs / 13”Reel 2 Version: C2209 TSM60NC1R5CP Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) Output Characteristics Transfer Characteristics 3 3 VGS= 10V ID, Drain Current (A) ID, Drain Current (A) 2.5 VGS= 8V 2 VGS= 7V 1.5 VGS= 6.5V VGS= 6V 1 0.5 2.5 2 1.5 150°C 1 25°C 0 0 1 2 3 4 0 5 0 2 4 6 8 10 VGS, Gate to Source Voltage (V) On-Resistance vs. Drain Current Gate-Source Voltage vs. Gate Charge 10 2.5 VGS, Gate to Source Voltage (V) RDS(on), Drain-Source On-Resistance (Ω) VDS, Drain to Source Voltage (V) 2 1.5 1 0.5 VGS=10V 8 6 4 VDS=300V ID=3A 2 0 0 0 0.5 1 1.5 2 2.5 0 3 2 ID, Drain Current (A) RDS(on), Drain-Source On-Resistance (Ω) 2.5 2 1.5 1 VGS=10V ID=1A 0.5 0 -50 -25 0 25 50 75 6 8 10 On-Resistance vs. Gate-Source Voltage 3 -75 4 Qg, Gate Charge (nC) On-Resistance vs. Junction Temperature RDS(on), Drain-Source On-Resistance (Normalized) -55°C 0.5 100 125 150 175 TJ, Junction Temperature (°C) 2.5 2 1.5 1 0.5 ID=1A 0 5 6 7 8 9 10 VGS, Gate to Source Voltage (V) 3 Version: C2209 TSM60NC1R5CP Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) BVDSS vs. Junction Temperature Capacitance vs. Drain-Source Voltage 1000 Ciss 100 Coss 10 VGS = 0V f = 1MHz Crss 1 0 100 200 300 400 500 1.2 BVDSS (Normalized) Drain-Source Breakdown Voltage C, Capacitance (pF) 10000 1.1 1 0.9 ID=1mA 0.8 -75 600 VDS, Drain to Source Voltage (V) -25 0 25 50 75 100 125 150 175 TJ, Junction Temperature (°C) Maximum Safe Operating Area, Junction-to-Case Source-Drain Diode Forward Current vs. Voltage 100 IS, Reverse Drain Current (A) 10 10 ID, Drain Current (A) -50 RDS(ON) 1 0.1 SINGLE PULSE RӨJC=2.2°C/W TC=25°C 0.01 1 150°C -55°C 0.1 25°C 0.01 0.1 1 10 100 1000 0 0.5 1 1.5 VSD, Body Diode Forward Voltage (V) VDS, Drain to Source Voltage (V) Normalized Thermal Transient Impedance, Junction-to-Case Normalized Effective Transient Thermal Impedance, ZӨJC 10 SINGLE PULSE RӨJC=2.2°C/W 1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single 0.1 0.01 0.0001 0.001 0.01 Notes: Duty = t1 / t2 TJ = TC + PDM x ZӨJC x RӨJC 0.1 1 t, Square Wave Pulse Duration (sec) 4 Version: C2209 TSM60NC1R5CP Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) TO-252 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM 60NC1R5 YWWLF Y WW L F = Year Code = Week Code (01~52) = Lot Code (1~9,A~Z) = Factory Code 5 Version: C2209 TSM60NC1R5CP Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: C2209
TSM60NC1R5CP ROG 价格&库存
很抱歉,暂时无法提供与“TSM60NC1R5CP ROG”相匹配的价格&库存,您可以联系我们找货
TSM60NC1R5CP ROG
  • 2500+4.457472500+0.57934
  • 7500+3.985037500+0.51794
库存:9820
TSM60NC1R5CP ROG
  • 1+16.243251+2.11114
  • 10+10.2817010+1.33631
  • 50+7.7152350+1.00275
  • 100+6.88652100+0.89504
  • 500+5.43208500+0.70601
库存:9820
TSM60NC1R5CP ROG
