GOFORD
G20P08K
P-Channel Enhancement Mode Power MOSFET
Description
The G20P08K uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
General Features
VDS
ID (at VGS = -10V)
RDS(ON) (at VGS = -10V)
RDS(ON) (at VGS = -4.5V)
100% Avalanche Tested
-80V
-20A
< 62mΩ
< 70mΩ
Schematic diagram
⚫ RoHS Compliant
Application
⚫ Power switch
⚫ DC/DC converters
TO-252
Device
Package
Marking
Packaging
G20P08K
TO-252
G20P08
2500pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
-80
V
ID
-20
A
IDM
-80
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
60
W
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
RthJC
2.1
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
Thermal Resistance, Junction-to-Case
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466
(A1355)
GOFORD
G20P08K
Specifications TJ = 25ºC, unless otherwise noted
Value
Parameter
Symbol
Test Conditions
Unit
Min.
Typ.
Max.
Static Parameters
Drain-Source Breakdown Voltage
V(BR)DSS
VGS = 0V, ID = -250µA
-80
V
Zero Gate Voltage Drain Current
IDSS
VDS = -80V, VGS = 0V
-1
uA
Gate-Source Leakage
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = -250µA
-1
-1.7
-2.5
V
VGS = -10V, ID = - 10A
52
62
Drain-Source On-Resistance
RDS(on)
VGS = -4.5V, ID = - 10A
58
70
VDS=10V,ID=-10A
25
3500
410
285
48
10.5
Forward Transconductance
mΩ
gFS
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
VGS = 0V,
VDS = -30V,
f = 1.0MHz
VDD = -30V,
ID = -10A,
VGS = -10V
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
11
Turn-on Delay Time
td(on)
13
Turn-on Rise Time
tr
16
Turn-off Delay Time
td(off)
40
16
Turn-off Fall Time
VDD = -30V,
ID = -10A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
-20
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = -10A, VGS = 0V
-1.2
V
Reverse Recovery Time
Trr
IS = -10A, VGS = 0V
di/dt=-100A/us
47
ns
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
Identical low side and high side switch with identical R G
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466
(A1355)
GOFORD
G20P08K
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466
(A1355)
GOFORD
G20P08K
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 2. Transfer Characteristics
- ID, Drain Current (A)
-ID, Drain Current (A)
Figure 1. Output Characteristics
-VDS, Drain-to-Source Voltage (V)
-VGS, Gate-to-Source Voltage (V)
Figure 4. Drain Source On Resistance
RDS(on),On-Resistance(mΩ)
Figure 3. Gate Charge
-Vgs Gate-Source Voltage(V)
VGS=-10V
ID=-10A
VDS=-30V
ID=-10A
Qg Gate Charge(nC)
VGS=-4.5V
VGS=-10V
-ID-Drain Current(A)
Figure 6. Source-Drain Diode Forward
Capacitance(pF)
-Is, Reverse Drain Current (A)
Figure 5. Capacitance
-Vds Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
-VSD, Source-to-Drain Voltage (V)
FAX:0755-29961466
(A1355)
GOFORD
G20P08K
Figure 8. Safe Operation Area
VGS=-10V
ID=-10A
-ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ, Junction Temperature (ºC)
-VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466
(A1355)
GOFORD
G20P08K
TO-252 Package Information
Symbol
A
A1
A2
b
b3
c
D
D1
E
E1
e
H
L
L1
L2
L3
L4
L5
θ
www.gofordsemi.com
Dimensions in Millimeters
MIN.
NOM.
MAX.
2.2
2.3
2.4
0.97
1.07
1.17
0.68
0.78
0.9
5.2
5.33
5.5
0.43
0.53
0.63
5.98
6.1
6.22
5.30REF
6.4
6.6
6.8
4.63
2.286BSC
9.4
10.1
10.5
1.38
1.5
1.75
2.90REF
0.51BSC
0.88
1.28
0.5
1
1.65
1.8
1.95
0°
8°
TEL:0755-29961263
FAX:0755-29961466
(A1355)
很抱歉,暂时无法提供与“G20P08K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.84040
- 10+2.26800
- 30+2.03040
- 100+1.72800
- 500+1.40400
- 1000+1.31760
