G35N02K
N-Channel Enhancement Mode Power MOSFET
Description
The G35N02K uses advanced trench technology to provide
excellent RDS(ON) , low gate charge. It can be used in a wide
variety of applications.
General Features
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 4.5V)
RDS(ON) (at VGS = 2.5V)
20V
35A
< 13mΩ
< 18mΩ
Schematic diagram
⚫ 100% Avalanche Tested
⚫ RoHS Compliant
Application
⚫ Power switch
⚫ DC/DC converters
TO-252
Device
G35N02K
Marking
Package
TO-252
G35N02
Packaging
2500pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
V
ID
35
A
IDM
100
A
Gate-Source Voltage
VGS
±12
V
Power Dissipation
PD
40
W
EAS
23
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
RthJC
3.8
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
(note3)
Single pulse avalanche energy
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
Thermal Resistance, Junction-to-Case
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466 (A1522)
G35N02K
Specifications TJ = 25ºC, unless otherwise noted
Value
Parameter
Symbol
Test Conditions
Unit
Min.
Typ.
Max.
Static Parameters
Drain-Source Breakdown Voltage
V(BR)DSS
VGS = 0V, ID = 250µA
V
Zero Gate Voltage Drain Current
IDSS
VDS = 20V, VGS = 0V
1
μA
Gate-Source Leakage
IGSS
VGS = ±12V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
0.5
0.75
1.2
V
VGS = 4.5V, ID = 20A
7
13
Drain-Source On-Resistance
RDS(on)
VGS = 2.5V, ID = 20A
9
18
VDS = 5V,ID = 20A
60
1380
212
195
24
3
Forward Transconductance
mΩ
gFS
S
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
VDS=10V,
VGS=0V,
F=1.0MHz
VDS=10V,
ID=20A,
VGS=4.5V
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
6
Turn-on Delay Time
td(on)
4.5
Turn-on Rise Time
tr
9
Turn-off Delay Time
td(off)
19
3
Turn-off Fall Time
VDS = 10V,
ID = 20A,
RG = 3Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
35
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = 25A, VGS = 0V
1.2
V
Reverse Recovery Time
Trr
18
nS
Reverse Recovery Charge
Qrr
10
nC
IS = 20A, VGS = 0V
di/dt=100A/us
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
Identical low side and high side switch with identical R G
3.
EAS condition : Tj=25℃ ,VDD=20V,VGS=10V,L=0.5mH,Rg=25Ω
www.gofordsemi.com
TEL:0755-29961263
G35N02K
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
G35N02K
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 2. Transfer Characteristics
ID, Drain Current (A)
Figure 1. Output Characteristics
VDS, Drain-to-Source Voltage (V)
VGS, Gate-to-Source Voltage (V)
Figure 4. Drain Source On Resistance
RDS(on),On-Resistance(mΩ)
Vgs Gate-Source Voltage(V)
Figure 3. Gate Charge
VDS=10V
ID=20A
Qg Gate Charge(nC)
VGS=4.5V
ID-Drain Current(A)
Figure 6. Source-Drain Diode Forward
Is, Reverse Drain Current (A)
Figure 5. Capacitance
Capacitance(pF)
VGS=2.5V
Ciss
Coss
Crss
Vds Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
G35N02K
Figure 8. Safe Operation Area
Figure 7. Drain-Source On-Resistance
ID, Drain Current(A)
RDS(on), (Normalized)
VGS=4.5V,ID=20A
TJ, Junction Temperature (ºC)
TJ(MAX)=150℃,TC=25 ℃
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
G35N02K
TO-252 Package Information
Symbol
A
A1
A2
b
b3
c
D
D1
E
E1
e
H
L
L1
L2
L3
L4
L5
θ
www.gofordsemi.com
Dimensions in Millimeters
MIN.
NOM.
MAX.
2.2
2.3
2.4
0.97
1.07
1.17
0.68
0.78
0.9
5.2
5.33
5.5
0.43
0.53
0.63
5.98
6.1
6.22
5.30REF
6.4
6.6
6.8
4.63
2.286BSC
9.4
10.1
10.5
1.38
1.5
1.75
2.90REF
0.51BSC
0.88
1.28
0.5
1
1.65
1.8
1.95
0°
8°
TEL:0755-29961263
很抱歉,暂时无法提供与“G35N02K”相匹配的价格&库存,您可以联系我们找货
