GT025N06AM
GT025N06AM
    GOFORD(谷峰)
    TO-263(D²Pak)
    表面贴装型 N 通道 60 V 170A(Tc) 215W(Tc) TO-263
GT025N06AM 数据手册
GT025N06AM N-Channel Enhancement Mode Power MOSFET Description The GT025N06AM uses advanced trench technology to provide excellent RDS(ON) , low gate charge. It can be used in a wide variety of applications. General Features l l l l l VDS 60V ID (at VGS = 10V) 170A RDS(ON) (at VGS = 10V) < 2.5mΩ RDS(ON) (at VGS = 4.5V) < 3mΩ 100% Avalanche Tested Schematic Diagram l RoHS Compliant Application l Power switch l DC/DC converters l Synchronous Rectification TO-263 Device Package Marking Packaging GT025N06AM TO-263 GT025N06 800psc/Reel Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDS 60 V ID 170 A IDM 300 A VGS ±20 V EAS 420 mJ PD 215 W TJ, Tstg -55 To 150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Case RthJA 50 ºC/W Maximum Junction-to-Case RthJC 0.58 ºC/W Drain-Source Voltage Continuous Drain Current Pulsed Drain Current (note1) Gate-Source Voltage Single pulse avalanche energy (note2) Power Dissipation Operating Junction and Storage Temperature Range Thermal Resistance Parameter www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1577) GT025N06AM Specifications TJ = 25ºC, unless otherwise noted Parameter Symbol Test Conditions Drain-Source Breakdown Voltage V(BR)DSS Zero Gate Voltage Drain Current Gate-Source Leakage Value Unit Min. Typ. Max. VGS = 0V, ID = 250µA 60 -- -- V IDSS VDS = 60V, VGS = 0V -- -- 1 μA IGSS VGS = ±20V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = 250µA 1.2 1.6 2.5 V Drain-Source On-Resistance RDS(on) VGS = 10V, ID = 20A -- 2 2.5 VGS = 4.5V, ID = 15A -- 2.5 3 Forward Transconductance gFS VDS = 5V,ID = 20A -- 60 -- -- 5119 -- -- 1347 -- -- 78 -- -- 70 -- -- 21 -- -- 16 -- -- 16 -- -- 9 -- -- 36 -- -- 11 -- Static Parameters mΩ S Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Turn-on Delay Time td(on) Turn-on Rise Time tr Turn-off Delay Time td(off) Turn-off Fall Time VGS = 0V, VDS = 30V, f = 1.0MHz VDD = 30V, ID = 20A, VGS = 10V VDD = 30V, ID = 50A, RG = 3Ω tf pF nC ns Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25ºC -- -- 170 A Body Diode Voltage VSD TJ = 25ºC, ISD = 20A, VGS = 0V -- -- 1.2 V Reverse Recovery Chrage Qrr 150 -- nC Reverse Recovery Time Trr 30 -- ns IF=20A, di/dt=500A/us Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. Identical low side and high side switch with identical RG 3. EAS condition :Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1577) GT025N06AM Gate Charge Test Circuit EAS Test Circuit Switch Time Test Circuit www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1577) GT025N06AM Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 1. Output Characteristics ID, Drain Current (A) 140 140 4.5V 4V 10V ID, Drain Current (A) 160 Figure 2. Transfer Characteristics 3.8V 120 100 3.5V 80 VGS=3.3V 60 40 100 80 60 40 25 ºC 20 20 0 VDS=5V 120 0 1 2 3 4 0 5 0 5 4.5 4 3.5 3 VGS=4.5V 2 VGS=10V 1.5 1 0.5 0 10 20 30 40 ID-Drain Current(A) 4000 Coss 2000 1000 Crss 0 10 20 30 40 50 8 6 4 2 0 20 40 60 80 60 Vds Drain-Source Voltage(V) www.gofordsemi.com VDD=30V ID=20A Is, Reverse Drain Current (A) Capacitance(pF) Ciss 5000 3000 5 Figure 6. Source-Drain Diode Forward 7000 6000 4 Qg Gate Charge(nC) Figure 5. Capacitance vs Vds 0 10 0 0 3 Figure 4. Gate Charge Figure 3. Drain Source On Resistance 2.5 2 VGS, Gate-to-Source Voltage (V) Vgs Gate-Source Voltage(V) RDS(on),On-Resistance(mΩ) VDS, Drain-to-Source Voltage (V) 1 TEL:0755-29961263 VSD, Source-to-Drain Voltage (V) FAX:0755-29961466(A1577) GT025N06AM Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 8. Safe Operation Area VGS=10V ID=20A VGS=4.5V ID=20A ID, Drain Current(A) RDS(on), (Normalized) Figure 7. Drain-Source On-Resistance TJ, Junction Temperature (ºC) VDS, Drain-Source Voltage(V) ZthJC, Thermal Impedance (ºC/W) Figure 9. Normalized Maximum Transient Thermal Impedance Pulse Width (s) www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1577) GT025N06AM TO-263 Package Mechanical Data www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466(A1577)
GT025N06AM 价格&库存
很抱歉,暂时无法提供与“GT025N06AM”相匹配的价格&库存,您可以联系我们找货
