GT035N10M
GT035N10M
    GOFORD(谷峰)
    TO-263(D²Pak)
    表面贴装型 N 通道 100 V 190A(Tc) 277W(Tc) TO-263
GT035N10M 数据手册
GT035N10M N-Channel Enhancement Mode Power MOSFET Description The GT035N10M uses advanced trench technology to provide excellent RDS(ON) , low gate charge. It can be used in a wide variety of applications. General Features l l l l VDS ID (at VGS = 10V) RDS(ON) (at VGS = 10V) 100% Avalanche Tested < 100V 190A 3.5mΩ Schematic diagram l RoHS Compliant Application l Power switch l DC/DC converters TO-263 Ordering Information Device Package Marking Packaging GT035N10M TO-263 GT035N10 800pcs/Reel Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Symbol Value Unit VDS 100 V ID 190 A IDM 760 A Gate-Source Voltage VGS ±20 V Power Dissipation PD 250 W EAS 441 mJ TJ, Tstg -55 To 150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Ambient RthJA 55 ºC/W Maximum Junction-to-Case RthJC 0.5 ºC/W Drain-Source Voltage Continuous Drain Current Pulsed Drain Current (note1) Single pulse avalanche energy (note2) Operating Junction and Storage Temperature Range Thermal Resistance Parameter www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 GT035N10M Specifications TJ = 25ºC, unless otherwise noted Parameter Symbol Test Conditions Drain-Source Breakdown Voltage V(BR)DSS Zero Gate Voltage Drain Current Gate-Source Leakage Value Unit Min. Typ. Max. VGS = 0V, ID = 250µA 100 -- -- V IDSS VDS = 100V, VGS = 0V -- -- 1 μA IGSS VGS = ±20V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = 250µA 2 3 4 V Drain-Source On-Resistance RDS(on) VGS = 10V, ID = 20A -- 2.9 3.5 mΩ Forward Transconductance gFS VGS = 5V, ID = 20A -- 51 -- S -- 6188 -- -- 1928 -- -- 178 -- -- 68 -- -- 26 -- -- 31 -- -- 27 -- -- 21 -- -- 78 -- -- 30 -- Static Parameters Dynamic Parameters Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Turn-on Delay Time td(on) Turn-on Rise Time tr Turn-off Delay Time td(off) Turn-off Fall Time VGS = 0V, VDS = 50V, f = 1.0MHz VDD = 50V, ID = 50A, VGS = 10V VDD = 50V, ID = 50A, RG = 3Ω tf pF nC ns Drain-Source Body Diode Characteristics Continuous Body Diode Current IS TC = 25ºC -- -- 190 A Body Diode Voltage VSD TJ = 25ºC, ISD = 20A, VGS = 0V -- -- 1.2 V Reverse Recovery Charge Qrr -- 680 -- nC Reverse Recovery Time Trr IF = 20A, VGS = 0V di/dt=100A/us -- 132 -- ns Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω 3. Identical low side and high side switch with identical RG www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 GT035N10M Gate Charge Test Circuit Switch Time Test Circuit EAS Test Circuit www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 GT035N10M Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 1. Output Characteristics 40 10V 7V ID, Drain Current (A) 80 5.5V 60 5V 40 20 0 VGS= 4.5V 0 0.5 1 VDS= 5V 35 6V 100 ID, Drain Current (A) 120 Figure 2. Transfer Characteristics 30 25 20 25℃ 15 10 5 1.5 2 0 2.5 0 RDS(on),On-Resistance(mΩ) Figure 3. Drain Source On Resistance VGS= 10V 4 6 8 10 VGS, Gate-to-Source Voltage (V) Vgs Gate-Source Voltage(V) VDS, Drain-to-Source Voltage (V) 2 VDD = 50V, ID = 50A 8 6 4 2 0 ID-Drain Current(A) Figure 4. Gate Charge 10 0 20 40 60 80 Qg Gate Charge(nC) Figure 6. Source-Drain Diode Forward Capacitance(pF) Is, Reverse Drain Current (A) Figure 5. Capacitance VDS Drain-Source Voltage(V) www.gofordsemi.com TEL:0755-29961263 VSD, Source-to-Drain Voltage (V) FAX:0755-29961466 GT035N10M Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 7. Drain-Source On-Resistance Figure 8. Safe Operation Area ID, Drain Current(A) RDS(on), (Normalized) VGS = 10V, ID = 20A TJ, Junction Temperature (ºC) VDS, Drain-Source Voltage(V) ZthJC, Thermal Impedance (ºC/W) Figure 9. Normalized Maximum Transient Thermal Impedance 0.45°C/W Pulse Width (s) www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466 GT035N10M TO-263 Package Information www.gofordsemi.com TEL:0755-29961263 FAX:0755-29961466
GT035N10M 价格&库存
很抱歉,暂时无法提供与“GT035N10M”相匹配的价格&库存,您可以联系我们找货
