TSM60NC196CM2 RNG
TSM60NC196CM2 RNG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-263(D²Pak)
    表面贴装型 N 通道 600 V 28A(Tc) 152W(Tc) TO-263AB(D²PAK)
TSM60NC196CM2 RNG 数据手册
TSM60NC196CM2 Taiwan Semiconductor N-Channel Power MOSFET 600V, 28A, 196mΩ FEATURES KEY PERFORMANCE PARAMETERS ● Super-Junction technology PARAMETER VALUE UNIT VDS 600 V RDS(on) (max) 196 mΩ Qg 39 nC ● High performance, small RDS(ON)*Qg figure of merit (FOM) ● High ruggedness performance ● 100% UIS & Rg tested ● High commutation performance ● ROHS Compliant ● Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Power Supply ● AC/DC LED Lighting 2 TO-263-2L (D PAK-2L) Note: MSL 3 (Moisture Sensitivity Level) per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL LIMIT UNIT Drain-Source Voltage VDS 600 V Gate-Source Voltage VGS ±20 V 28 A 18 A IDM 84 A PD 152 W Continuous Drain Current Pulsed Drain Current TC = 25°C (Note 1) ID TC = 100°C (Note 2) Total Power Dissipation @ TC = 25°C Single Pulse Avalanche Energy (Note 3) EAS 440 mJ Single Pulse Avalanche Current (Note 3) IAS 4.2 A TJ, TSTG -55 to +150 °C SYMBOL MAXIMUM UNIT Junction to Case Thermal Resistance RӨJC 0.82 °C/W Junction to Ambient Thermal Resistance RӨJA 40 °C/W Operating Junction and Storage Temperature Range THERMAL PERFORMANCE PARAMETER Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. R ӨJC is guaranteed by design while RӨCA is determined by the user’s board design. 1 Version: C2209 TSM60NC196CM2 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNIT Static Drain-Source Breakdown Voltage VGS = 0V, ID = 1mA BVDSS 600 -- -- V Gate Threshold Voltage VDS = VGS, ID = 1mA VGS(TH) 3 4.2 5 V Gate Body Leakage VGS = ±20V, VDS = 0V IGSS -- -- ±100 nA Zero Gate Voltage Drain Current VDS = 600V, VGS = 0V IDSS -- -- 1 µA RDS(on) -- 182 196 mΩ Qg -- 39 -- Qgs -- 12 -- Qgd -- 17 -- Ciss -- 1566 -- Coss -- 46 -- Crss -- 11 -- Rg -- 2.3 4.6 td(on) -- 32 -- tr -- 31 -- td(off) -- 55 -- tf -- 11 -- Body-Diode Continuous Forward Current IS -- -- 20 A Body-Diode Pulsed Current ISM -- -- 60 A VSD -- -- 1.5 V Drain-Source On-State Resistance (Note 4) Dynamic VGS = 10V, ID = 9.5A (Note 5) Total Gate Charge VDS = 300V, ID = 20A, Gate-Source Charge VGS = 10V Gate-Drain Charge Input Capacitance VDS = 300V, VGS = 0V, Output Capacitance f = 1.0MHz Reverse Transfer Capacitance Gate Resistance Switching f = 1.0MHz nC pF Ω (Note 6) Turn-On Delay Time Turn-On Rise Time VDD = 300V, RG = 10Ω, Turn-Off Delay Time ID = 10A, VGS = 10V, Turn-Off Fall Time ns Source-Drain Diode Forward Voltage (Note 4) IS = 20A, VGS = 0V Reverse Recovery Time IS = 20A trr -- 420 -- ns Reverse Recovery Charge dIF/dt = 100A/μs Qrr -- 8.4 -- μC Notes: 1. Current limited by package. 2. Pulse width limited by the maximum junction temperature. 3. L = 50mH, IAS = 4.2A, VDD = 50V, RG = 25Ω, Starting TJ = 25 C 4. Pulse test: PW ≤ 300µs, duty cycle ≤ 2%. 5. For DESIGN AID ONLY, not subject to production testing. 6. Switching time is essentially independent of operating temperature. o ORDERING INFORMATION ORDERING CODE TSM60NC196CM2 RNG PACKAGE PACKING 2 800pcs / 13” Reel TO-263-2L (D PAK-2L ) 2 Version: C2209 TSM60NC196CM2 Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) Output Characteristics Transfer Characteristics 20 20 ID, Drain Current (A) ID, Drain Current (A) VGS= 10V VGS= 8V 15 VGS= 7V VGS= 6.5V 10 VGS= 6V 5 0 10 150℃ -55℃ 5 25℃ 0 0 1 2 3 4 VDS, Drain to Source Voltage (V) 0 5 On-Resistance vs. Drain Current VGS, Gate to Source Voltage (V) 0.3 0.2 0.1 VGS=10V 0 5 10 15 ID, Drain Current (A) RDS(on), Drain-Source On-Resistance (Normalized) 3 2.5 2 1.5 1 VGS=10V ID=9.5A 0 -75 -50 -25 0 25 50 3 4 5 6 7 8 9 10 10 8 6 4 75 100 125 150 175 VDS=300V ID=20A 2 0 0 20 On-Resistance vs. Junction Temperature 0.5 2 Gate-Source Voltage vs. Gate Charge 0.4 0 1 VGS, Gate to Source Voltage (V) 10 20 30 40 Qg, Gate Charge (nC) RDS(on), Drain-Source On-Resistance (Ω) RDS(on), Drain-Source On-Resistance (Ω) 15 TJ, Junction Temperature (°C) On-Resistance vs. Gate-Source Voltage 0.4 0.3 0.2 0.1 ID=9.5A 0 6 7 8 9 10 VGS, Gate to Source Voltage (V) 3 Version: C2209 TSM60NC196CM2 Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) BVDSS vs. Junction Temperature Capacitance vs. Drain-Source Voltage BVDSS (Normalized) Drain-Source Breakdown Voltage 10000 C, Capacitance (pF) CISS 1000 100 COSS 10 CRSS 1 0 100 200 300 400 500 1.2 1.1 1 0.9 ID=1mA 0.8 -75 -50 -25 600 25 50 75 100 125 150 175 TJ, Junction Temperature (°C) VDS, Drain to Source Voltage (V) Maximum Safe Operating Area, Junction-to-Case Source-Drain Diode Forward Current vs. Voltage 100 IS, Reverse Drain Current (A) 100 RDS(ON)=196mΩ ID, Drain Current (A) 0 10 1 SINGLE PULSE RӨJC=0.82°C/W TC=25°C 10 150℃ -55℃ 1 25℃ 0.1 0.1 0.1 1 10 100 0.2 1000 VDS, Drain to Source Voltage (V) 0.4 0.6 0.8 1 1.2 VSD, Body Diode Forward Voltage (V) Normalized Effective Transient Thermal Impedance Normalized Thermal Transient Impedance, Junction-to-Case 10 SINGLE PULSE RӨJC=0.82°C/W 1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single 0.1 0.01 0.0001 0.001 Notes: Duty = t1 / t2 TJ = TC + PDM x ZNORMALIZED x RӨJC 0.01 0.1 1 t, Square Wave Pulse Duration (sec) 4 Version: C2209 TSM60NC196CM2 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) TO-263 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM 60NC196 G Y WW F = Halogen Free = Year Code = Week Code (01~52) = Factory Code 5 Version: C2209 TSM60NC196CM2 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: C2209
TSM60NC196CM2 RNG 价格&库存
很抱歉,暂时无法提供与“TSM60NC196CM2 RNG”相匹配的价格&库存,您可以联系我们找货
TSM60NC196CM2 RNG
