GT100N12M
N-Channel Enhancement Mode Power MOSFET
Description
The GT100N12M uses advanced trench technology to
provide excellent RDS(ON) , low gate charge. It can be used in
a wide variety of applications.
General Features
l
l
l
l
VDS
ID (at VGS = 10V)
RDS(ON) (at VGS = 10V)
100% Avalanche Tested
120V
70A
10mΩ
Schematic diagram
l RoHS Compliant
Application
l Power switch
l DC/DC converters
TO-263
Ordering Information
Device
Package
Marking
Packaging
GT100N12M
TO-263
GT100N12
800pcs/Reel
Absolute Maximum Ratings TC = 25ºC, unless otherwise noted
Parameter
Symbol
Value
Unit
VDS
120
V
ID
70
A
IDM
280
A
Gate-Source Voltage
VGS
±20
V
Power Dissipation
PD
100
W
EAS
156
mJ
TJ, Tstg
-55 To 150
ºC
Symbol
Value
Unit
Thermal Resistance, Junction-to-Ambient
RthJA
50
ºC/W
Maximum Junction-to-Case
RthJC
1.25
ºC/W
Drain-Source Voltage
Continuous Drain Current
Pulsed Drain Current
(note1)
Single pulse avalanche energy
(note2)
Operating Junction and Storage Temperature Range
Thermal Resistance
Parameter
www.gofordsemi.com
TEL:0755-29961263
FAX:0755-29961466(A1660)
GT100N12M
Specifications TJ = 25ºC, unless otherwise noted
Parameter
Symbol
Test Conditions
Drain-Source Breakdown Voltage
V(BR)DSS
Zero Gate Voltage Drain Current
Gate-Source Leakage
Value
Unit
Min.
Typ.
Max.
VGS = 0V, ID = 250µA
120
V
IDSS
VDS = 120V, VGS = 0V
1
μA
IGSS
VGS = ±20V
±100
nA
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS, ID = 250µA
2
3
4
V
Drain-Source On-Resistance
RDS(on)
VGS = 10V, ID = 20A
7.5
10
mΩ
Forward Transconductance
gFS
VGS = 5V, ID = 20A
25
S
2887
324
7
50
17
15
15
10
34
8
Static Parameters
Dynamic Parameters
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-off Delay Time
td(off)
Turn-off Fall Time
VGS = 0V,
VDS = 60V,
f = 1.0MHz
VDD = 60V,
ID = 20A,
VGS = 10V
VDD = 60V,
ID = 20A,
RG = 1.6Ω
tf
pF
nC
ns
Drain-Source Body Diode Characteristics
Continuous Body Diode Current
IS
TC = 25ºC
70
A
Body Diode Voltage
VSD
TJ = 25ºC, ISD = 20A, VGS = 0V
1.2
V
Reverse Recovery Charge
Qrr
106
nC
Reverse Recovery Time
Trr
IF = 20A, VGS = 0V
di/dt=100A/us
60
ns
Notes
1.
Repetitive Rating: Pulse width limited by maximum junction temperature
2.
EAS condition : Tj=25℃ ,VDD=50V,VGS=10V,L=0.5mH,Rg=25Ω
3.
Identical low side and high side switch with identical RG
www.gofordsemi.com
TEL:0755-29961263
GT100N12M
Gate Charge Test Circuit
Switch Time Test Circuit
EAS Test Circuit
www.gofordsemi.com
TEL:0755-29961263
GT100N12M
Typical Characteristics TJ = 25ºC, unless otherwise noted
Figure 1. Output Characteristics
25
VDS= 5V
5V
5.2V
4.8V
15
4.5V
10
5
2
3
RDS(on),On-Resistance(mΩ)
25℃
10
4
6
8
VDS, Drain-to-Source Voltage (V)
VGS, Gate-to-Source Voltage (V)
Figure 3. Drain Source On Resistance
Figure 4. Gate Charge
16
14
12
10
8
VGS= 10V
6
4
2
5
VGS= 4V
Vgs Gate-Source Voltage(V)
ID, Drain Current (A)
30
10V
30
Figure 2. Transfer Characteristics
10
6
4
2
40
ID-Drain Current(A)
VDD = 60V,
ID = 20A
8
40
50
60
Qg Gate Charge(nC)
Figure 5. Capacitance
Figure 6. Source-Drain Diode Forward
Ciss
3000
Capacitance(pF)
Is, Reverse Drain Current (A)
3500
2500
2000
Coss
1500
1000
500
Crss
40
50
60
VDS Drain-Source Voltage(V)
www.gofordsemi.com
TEL:0755-29961263
VSD, Source-to-Drain Voltage (V)
GT100N12M
Figure 8. Safe Operation Area
VGS = 10V,
ID = 20A
ID, Drain Current(A)
RDS(on), (Normalized)
Figure 7. Drain-Source On-Resistance
TJ, Junction Temperature (ºC)
VDS, Drain-Source Voltage(V)
ZthJC, Thermal Impedance (ºC/W)
Figure 9. Normalized Maximum Transient
Thermal Impedance
1.25°C/W
Pulse Width (s)
www.gofordsemi.com
TEL:0755-29961263
GT100N12M
TO-263 Package Information
www.gofordsemi.com
TEL:0755-29961263
很抱歉,暂时无法提供与“GT100N12M”相匹配的价格&库存,您可以联系我们找货
