TSM70N750
Taiwan Semiconductor
N-Channel Power MOSFET
700V, 6A, 0.75Ω
FEATURES
KEY PERFORMANCE PARAMETERS
Super-Junction technology
High performance due to small figure-of-merit
High ruggedness performance
High commutation performance
PARAMETER
VALUE
UNIT
VDS
700
V
RDS(on) (max)
0.75
Ω
Qg
10.7
nC
APPLICATION
Power Supply
Lighting
TO-251 (IPAK)
TO-252 (DPAK)
Notes: MSL 3 (Moisture Sensitivity Level) for TO-252 (D-PAK) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TC = 25°C unless otherwise noted)
PARAMETER
SYMBOL
LIMIT
UNIT
Drain-Source Voltage
VDS
700
V
Gate-Source Voltage
VGS
±30
V
Continuous Drain Current
Pulsed Drain Current
TC = 25°C
(Note 1)
ID
TC = 100°C
(Note 2)
Total Power Dissipation @ TC = 25°C
6
3.6
A
IDM
18
A
PDTOT
62.5
W
Single Pulsed Avalanche Energy
(Note 3)
EAS
81
mJ
Single Pulsed Avalanche Current
(Note 3)
IAS
1.8
A
TJ, TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
2.0
°C/W
Junction to Ambient Thermal Resistance
RӨJA
62
°C/W
Operating Junction and Storage Temperature Range
THERMAL PERFORMANCE
PARAMETER
Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined
at the solder mounting surface of the drain pins. R ӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB in still air.
Document Number: DS_P0000139
1
Version: C1706
TSM70N750
ELECTRICAL SPECIFICATIONS (TC = 25°C unless otherwise noted)
PARAMETER
Static
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
(Note 4)
Drain-Source Breakdown Voltage
VGS = 0V, ID = 250µA
BVDSS
700
V
Gate Threshold Voltage
VDS = VGS, ID = 250µA
VGS(TH)
2
3
4
V
Gate Body Leakage
VGS = ±30V, VDS = 0V
IGSS
±100
nA
Zero Gate Voltage Drain Current
VDS = 700V, VGS = 0V
IDSS
1
µA
Drain-Source On-State Resistance
VGS = 10V, ID = 1.8A
RDS(on)
0.62
0.75
Ω
Qg
10.7
Qgs
2.8
Qgd
3.5
Dynamic
(Note 5)
Total Gate Charge
VDS = 380V, ID = 6A,
Gate-Source Charge
VGS = 10V
Gate-Drain Charge
nC
Input Capacitance
VDS = 100V, VGS = 0V,
Ciss
555
Output Capacitance
f = 1.0MHz
Coss
39
Gate Resistance
f = 1MHz, open drain
Rg
2.7
td(on)
15
tr
26
td(off)
30
tf
18
VSD
1.4
V
Switching
pF
Ω
(Note 6)
Turn-On Delay Time
VDD = 380V,
Turn-On Rise Time
RGEN = 25Ω,
Turn-Off Delay Time
ID = 6A, VGS = 10V,
Turn-Off Fall Time
Source-Drain Diode
ns
(Note 4)
Forward On Voltage
IS = 6A, VGS = 0V
Reverse Recovery Time
VR = 200V, IS = 3A
trr
182
ns
Reverse Recovery Charge
dIF/dt = 100A/μs
Qrr
1.3
μC
Notes:
1.
Current limited by package
2.
Pulse width limited by the maximum junction temperature
3.
L = 50mH, IAS = 1.8A, VDD = 50V, RG = 25Ω, Starting TJ = 25 C
4.
Pulse test: PW ≤ 300µs, duty cycle ≤ 2%
5.
For DESIGN AID ONLY, not subject to production testing.
6.
Switching time is essentially independent of operating temperature.
o
2
Version: C1706
TSM70N750
ORDERING INFORMATION
PART NO.
TSM70N750CH C5G
PACKAGE
PACKING
TO-251 (IPAK)
75pcs / Tube
TSM70N750CP ROG
TO-252 (DPAK)
2,500pcs / 13” Reel
Note:
1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC
2. Halogen-free according to IEC 61249-2-21 definition
3
Version: C1706
TSM70N750
CHARACTERISTICS CURVES
Output Characteristics
Transfer Characteristics
On-Resistance vs. Drain Current
Gate-Source Voltage vs. Gate Charge
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Current vs. Voltage
4
Version: C1706
TSM70N750
BVDSS vs. Junction Temperature
Capacitance vs. Drain-Source Voltage
Maximum Safe Operating Area (DPAK/IPAK)
Normalized Thermal Transient Impedance
Normalized Effective Transient
Thermal Impedance
10
1
100
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single pulse
10-1
10-2
10-3
10-5
10-4
10-3
10-2
10-1
100
Square Wave Pulse Duration (s)
5
Version: C1706
TSM70N750
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
TO-251 (IPAK)
MARKING DIAGRAM
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code (1~9, A~Z)
6
Version: C1706
TSM70N750
TO-252
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
Y = Year Code
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
7
Version: C1706
TSM70N750
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
8
Version: C1706
很抱歉,暂时无法提供与“TSM70N750CP ROG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+30.435941+3.95576
- 国内价格 香港价格
- 5000+8.927835000+1.16035
