BC847BS/ZLF
BC847BS/ZLF
    NEXPERIA(安世)
    TSSOP6,SC88,SOT363
    GENERAL-PURPOSE TRANSISTOR
BC847BS/ZLF 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia BC847BS 45 V, 100 mA NPN/NPN general-purpose transistor Rev. 03 — 18 February 2009 Product data sheet 1. Product profile 1.1 General description NPN/NPN general-purpose transistor pair in a very small SOT363 (SC-88) Surface-Mounted Device (SMD) plastic package. PNP/PNP complement: BC857BS. 1.2 Features n n n n n Low collector capacitance Low collector-emitter saturation voltage Closely matched current gain Reduces number of components and board space No mutual interference between the transistors 1.3 Applications n General-purpose switching and amplification 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit open base - - 45 V - - 100 mA 200 - 450 Per transistor VCEO collector-emitter voltage IC collector current hFE DC current gain VCE = 5 V; IC = 2 mA BC847BS NXP Semiconductors 45 V, 100 mA NPN/NPN general-purpose transistor 2. Pinning information Table 2. Pinning Pin Description 1 emitter TR1 2 base TR1 3 collector TR2 4 emitter TR2 5 base TR2 6 collector TR1 Simplified outline 6 5 4 Graphic symbol 6 5 4 TR2 TR1 1 2 3 1 2 3 sym020 3. Ordering information Table 3. Ordering information Type number BC847BS Package Name Description Version SC-88 plastic surface-mounted package; 6 leads SOT363 4. Marking Table 4. Marking codes Type number Marking code[1] BC847BS 1F* [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China BC847BS_3 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 03 — 18 February 2009 2 of 12 BC847BS NXP Semiconductors 45 V, 100 mA NPN/NPN general-purpose transistor 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Per transistor VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 45 V VEBO emitter-base voltage open collector - 5 V IC collector current - 100 mA ICM peak collector current single pulse; tp ≤ 1 ms - 200 mA IBM peak base current single pulse; tp ≤ 1 ms - 200 mA Ptot total power dissipation Tamb ≤ 25 °C [1] - 220 mW [2] - 250 mW [1] - 300 mW [2] Per device Tamb ≤ 25 °C total power dissipation Ptot - 400 mW Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. 006aab419 500 Ptot (mW) (1) 400 (2) 300 200 100 0 −75 −25 25 75 125 175 Tamb (°C) (1) FR4 PCB, mounting pad for collector 1 cm2 (2) FR4 PCB, standard footprint Fig 1. Per device: Power derating curves SOT363 (SC-88) BC847BS_3 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 03 — 18 February 2009 3 of 12 BC847BS NXP Semiconductors 45 V, 100 mA NPN/NPN general-purpose transistor 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit - - 568 K/W Per transistor thermal resistance from junction to ambient Rth(j-a) in free air [1] [2] - - 500 K/W - - 230 K/W [1] - - 416 K/W [2] - - 313 K/W thermal resistance from junction to solder point Rth(j-sp) Per device thermal resistance from junction to ambient Rth(j-a) in free air [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for collector 1 cm2. 006aab420 103 Zth(j-a) (K/W) δ=1 0.75 0.50 0.33 102 0.20 0.10 0.05 0.02 10 0.01 0 1 10−5 10−4 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BC847BS_3 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 03 — 18 February 2009 4 of 12 BC847BS NXP Semiconductors 45 V, 100 mA NPN/NPN general-purpose transistor 006aab421 103 Zth(j-a) (K/W) δ=1 0.75 0.50 0.33 102 0.20 0.10 0.05 0.02 10 0.01 0 1 10−5 10−4 10−3 10−2 10−1 1 102 10 103 tp (s) FR4 PCB, mounting pad for collector 1 cm2 Fig 3. Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit collector-base cut-off VCB = 30 V; IE = 0 A current VCB = 30 V; IE = 0 A; Tj = 150 °C - - 15 nA - - 5 µA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 5 V; IC = 2 mA 200 - 450 VCEsat collector-emitter saturation voltage IC = 10 mA; IB = 0.5 mA - - 100 mV - - 300 mV VBEsat base-emitter saturation voltage IC = 10 mA; IB = 0.5 mA - 755 - mV VBE base-emitter voltage IC = 2 mA; VCE = 5 V 580 655 700 mV Cc collector capacitance IE = ie = 0 A; VCB = 10 V; f = 1 MHz - - 1.5 pF Ce emitter capacitance IC = ic = 0 A; VEB = 0.5 V; f = 1 MHz - 11 - pF fT transition frequency IC = 10 mA; VCE = 5 V; f = 100 MHz 100 - - MHz Per transistor ICBO [1] IC = 100 mA; IB = 5 mA Pulse test: tp ≤ 300 µs; δ ≤ 0.02. BC847BS_3 Product data sheet [1] © NXP B.V. 2009. All rights reserved. Rev. 03 — 18 February 2009 5 of 12 BC847BS NXP Semiconductors 45 V, 100 mA NPN/NPN general-purpose transistor mgt727 600 hFE IB (mA) = 4.0 3.6 3.2 2.8 2.4 2.0 IC (A) (1) 500 006aab422 0.20 0.15 1.6 400 1.2 (2) 0.8 300 0.10 0.4 200 0.05 (3) 100 0 10−1 1 102 10 0 103 0 1 2 3 4 5 VCE (V) I C (mA) Tamb = 25 °C VCE = 5 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 4. Per transistor: DC current gain as a function of collector current; typical values Fig 5. mgt728 1200 VBE (mV) 1000 Per transistor: Collector current as a function of collector-emitter voltage; typical values 006aab423 1.2 VBEsat (V) 1.0 (1) (1) 800 0.8 (2) (2) 600 0.6 (3) (3) 400 0.4 200 0 10−2 10−1 1 10 0.2 10−1 102 103 I C (mA) 1 VCE = 5 V IC/IB = 20 (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 150 °C (3) Tamb = 150 °C Per transistor: Base-emitter voltage as a function of collector current; typical values Fig 7. 103 Per transistor: Base-emitter saturation voltage as a function of collector current; typical values BC847BS_3 Product data sheet 102 IC (mA) (1) Tamb = −55 °C Fig 6. 10 © NXP B.V. 2009. All rights reserved. Rev. 03 — 18 February 2009 6 of 12 BC847BS NXP Semiconductors 45 V, 100 mA NPN/NPN general-purpose transistor mgt729 104 VCEsat (mV) 006aab424 109 fT (Hz) 103 108 102 (1) (3) (2) 10 10−1 1 10 102 103 107 10−1 1 102 10 IC (mA) I C (mA) VCE = 5 V; f = 1 MHz; Tamb = 25 °C IC/IB = 20 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = −55 °C Fig 8. Per transistor: Collector-emitter saturation voltage as a function of collector current; typical values Fig 9. Per transistor: Transition frequency as a function of collector current; typical values BC847BS_3 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 03 — 18 February 2009 7 of 12 BC847BS NXP Semiconductors 45 V, 100 mA NPN/NPN general-purpose transistor 8. Package outline 2.2 1.8 6 2.2 1.35 2.0 1.15 1.1 0.8 5 4 2 3 0.45 0.15 pin 1 index 1 0.3 0.2 0.65 0.25 0.10 1.3 Dimensions in mm 06-03-16 Fig 10. Package outline SOT363 (SC-88) 9. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number BC847BS Package Description SOT363 3000 10000 4 mm pitch, 8 mm tape and reel; T1 [2] -115 -135 4 mm pitch, 8 mm tape and reel; T2 [3] -125 -165 [1] For further information and the availability of packing methods, see Section 13. [2] T1: normal taping [3] T2: reverse taping BC847BS_3 Product data sheet Packing quantity © NXP B.V. 2009. All rights reserved. Rev. 03 — 18 February 2009 8 of 12 BC847BS NXP Semiconductors 45 V, 100 mA NPN/NPN general-purpose transistor 10. Soldering 2.65 solder lands 2.35 1.5 0.4 (2×) 0.6 0.5 (4×) (4×) solder resist solder paste 0.5 (4×) 0.6 (2×) occupied area 0.6 (4×) Dimensions in mm 1.8 sot363_fr Fig 11. Reflow soldering footprint SOT363 (SC-88) 1.5 solder lands 0.3 2.5 4.5 solder resist occupied area 1.5 Dimensions in mm 1.3 1.3 preferred transport direction during soldering 2.45 5.3 sot363_fw Fig 12. Wave soldering footprint SOT363 (SC-88) BC847BS_3 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 03 — 18 February 2009 9 of 12 BC847BS NXP Semiconductors 45 V, 100 mA NPN/NPN general-purpose transistor 11. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes BC847BS_3 20090218 Product data sheet - BC847BS_2 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • • Legal texts have been adapted to the new company name where appropriate. Section 4 “Marking”: updated Section 7 “Characteristics”: enhanced Section 9 “Packing information”: added Section 10 “Soldering”: added Section 12 “Legal information”: updated BC847BS_2 19990428 Product specification - BC847BS_1 BC847BS_1 19970714 Product specification - - BC847BS_3 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 03 — 18 February 2009 10 of 12 BC847BS NXP Semiconductors 45 V, 100 mA NPN/NPN general-purpose transistor 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 12.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com BC847BS_3 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 03 — 18 February 2009 11 of 12 BC847BS NXP Semiconductors 45 V, 100 mA NPN/NPN general-purpose transistor 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics. . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Packing information. . . . . . . . . . . . . . . . . . . . . . 8 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 18 February 2009 Document identifier: BC847BS_3
BC847BS/ZLF 价格&库存
很抱歉,暂时无法提供与“BC847BS/ZLF”相匹配的价格&库存,您可以联系我们找货
