TSM090N03CP ROG
TSM090N03CP ROG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-252(DPAK)
    表面贴装型 N 通道 30 V 50A(Tc) 40W(Tc) TO-252,(D-Pak)
TSM090N03CP ROG 数据手册
TSM090N03CP 30V N-Channel Power MOSFET TO-252 (DPAK) Key Parameter Performance Pin Definition: 1. Gate 2. Drain 3. Source Parameter Value Unit VDS 30 V RDS(on) (max) VGS = 10V 9 VGS = 4.5V 13 Qg 7.5 nC Block Diagram Ordering Information Ordering code mΩ Package Packing TSM090N03CP ROG TO-252 2.5kpcs / 13” Reel Note: Halogen-free according to IEC 61249-2-21 definition N-Channel MOSFET Absolute Maximum Ratings (Tc=25oC unless otherwise noted) Parameter Symbol Limit Unit Drain-Source Voltage VDS 30 V Gate-Source Voltage VGS ±20 V 55 A 35 A IDM 220 A EAS 45 mJ IAS 30 A 40 W 0.32 W/ºC TJ 150 ºC TSTG -55 to +150 Symbol Limit Tc=25ºC Continuous Drain Current Pulsed Drain Current ID Tc=100ºC (Note 1) Single Pulse Avalanche Energy (Note 2) Single Pulse Avalanche Current (Note 2) o Total Power Dissipation @ TC=25 C PD o Derate above TC=25 C Operating Junction Temperature Storage Temperature Range o C Thermal Performance Parameter Thermal Resistance - Junction to Case RӨJC Thermal Resistance - Junction to Ambient RӨJA 1/5 3.1 62 Unit o C/W o C/W Version: B1807 TSM090N03CP 30V N-Channel Power MOSFET Electrical Specifications (TC=25oC unless otherwise noted) Parameter Conditions Symbol Min Typ Max Unit BVDSS 30 -- -- V -- 7.5 9 -- 10 13 1 1.6 2.5 -- -- 1 -- -- 10 IGSS -- -- ±100 nA gfs -- 14 -- S Qg -- 7.5 -- Qgs -- 1.3 -- Qgd -- 4.5 -- Ciss -- 750 -- Coss -- 150 -- Crss -- 110 -- Rg -- 2.7 -- td(on) -- 4.8 -- tr -- 12.5 -- td(off) -- 27.6 -- tf -- 8.2 -- Continuous Drain-Source Diode IS -- -- 55 A Pulse Drain-Source Diode ISM -- -- 220 A VSD -- -- 1 V Static Drain-Source Breakdown Voltage Drain-Source On-State Resistance Gate Threshold Voltage Zero Gate Voltage Drain Current VGS = 0V, ID = 250µA VGS = 10V, ID = 16A VGS = 4.5V, ID = 8A VDS = VGS, ID = 250µA VDS = 30V, VGS = 0V VDS = 24V, TJ = 125ºC Gate Body Leakage VGS = ±20V, VDS = 0V Forward Transconductance VDS = 10V, ID = 8A RDS(ON) VGS(TH) IDSS mΩ V µA Dynamic Total Gate Charge (Note 3,4) Gate-Source Charge Gate-Drain Charge (Note 3,4) (Note 3,4) VDS = 15V, ID = 20A, VGS = 4.5V Input Capacitance VDS = 25V, VGS = 0V, Output Capacitance f = 1MHz Reverse Transfer Capacitance Gate Resistance f = 1MHz nC pF Ω Switching Turn-On Delay Time Turn-On Rise Time (Note 3,4) Turn-Off Delay Time Turn-Off Fall Time (Note 3,4) (Note 3,4) VDD=15V , VGS=10V , RG=3.3, ID=-15A (Note 3,4) ns Source-Drain Diode Ratings and Characteristic Diode-Source Forward Voltage VGS = 0V, IS = 1A Note: 1. Repetitive Rating : Pulsed width limited by maximum junction temperature. 2. VDD=25V,VGS=10V,L=0.1mH,IAS=30A.,RG=25,Starting TJ=25℃ 3. The data tested by pulsed , pulse width ≤300µs, duty cycle ≤2% 4. Essentially independent of operating temperature. 2/5 Version: B1807 TSM090N03CP 30V N-Channel Power MOSFET Electrical Characteristics Curve Normalized RDSON vs. TJ Normalized On Resistance ID , Continuous Drain Current (A) Continuous Drain Current vs. Tc TJ , Junction Temperature (℃) TC , Case Temperature (℃) Gate Charge Waveform VGS , Gate to Source Voltage (V) Normalized Gate Threshold Voltage (V) Normalized Vth vs. TJ Qg , Gate Charge (nC) Normalized Transient Impedance Maximum Safe Operation Area ID , Drain Current (A) Normalized Thermal Response TJ , Junction Temperature (℃) VDS , Drain to Source Voltage (V) Square Wave Pulse Duration (s) 3/5 Version: B1807 TSM090N03CP 30V N-Channel Power MOSFET TO-252 Mechanical Drawing Unit: Millimeters SUGGESTED PAD LAYOUT (Unit: Millimeters) Marking Diagram Y M 090N03 YML L = Year Code = Month Code O =Jan P =Feb S =May T =Jun W =Sep X =Oct = Lot Code (1~9, A~Z) Q =Mar U =Jul Y =Nov 4/5 R =Apr V =Aug Z =Dec Version: B1807 TSM090N03CP 30V N-Channel Power MOSFET Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5/5 Version: B1807
TSM090N03CP ROG 价格&库存
很抱歉,暂时无法提供与“TSM090N03CP ROG”相匹配的价格&库存,您可以联系我们找货
TSM090N03CP ROG
    TSM090N03CP ROG
    • 1+9.41950
    • 10+6.17945
    • 25+4.95650
    • 100+3.76708
    TSM090N03CP ROG
    • 2500+2.731392500+0.35500
    • 7500+2.409987500+0.31323
    库存:4059
    TSM090N03CP ROG
    • 1+10.678721+1.38791
    • 10+6.6782010+0.86797
    • 50+4.9437950+0.64255
    • 100+4.38190100+0.56952
    • 500+3.39398500+0.44112
    库存:4059
