8481-2
8481-2
    MGCHEMICALS
    TO-252(DPAK)
    LUBRICANT GREASE BLACK
8481-2 数据手册
8481 Premium Carbon Conductive Grease 8481 is a carbon-filled, silicone-free electrically conductive grease. It lubricates, reduces contact resistance, repels moisture, prevents static buildup, and is a powerful corrosion inhibitor. This conductive grease has great conductivity with extreme environmental protection. It is excellent for ground connections, rotating connections, rotary switches, variable capacitors, roller inductors, roller bearings, slip rings, slide connecters and potentiometers. Features & Benefits • Improves electrical connections between irregular and pitted surfaces • Ensures electrical contact between loose or vibrating parts • Prevents arcing, pitting, hotspots and welds • Reduces mechanical wear • Excellent corrosion resistance—passed ASTM B117 salt fog test (>550 hours) • Excellent thermal stability—will not separate Available Packaging Cat. No. Packaging Net Vol. Net Wt. 8481-1 Tube 85 mL 85.4 g 8481-2 Jar 462 mL 465 g 8481-3 Pail 3.78 L 3.79 kg Storage and Handling Store between 0 and 30 °C in dry area to minimize settling (see SDS). Properties Color Black Filler Carbon, graphite Base Material Synthetic oil Density 1.0 g/mL Viscosity 128 Pa∙s Resistivity 104 Ω·cm Thermal Conductivity @ 25 ˚C Evaporation Loss, 22 h @ 165 ˚C 2 % Oil Separation, 30 h @ 165 ˚C 5 % Water Washout @ 38 ˚C,   Bearing Dried @ 77 ˚C 0.9 % Rust Preventive, 48 h @ 52 ˚C   Bearing A, B, C Pass Pass Emcor Rust Test, DI Water   Bearing A 0 Salt Spray Corrosion Resistance Service Temperature Range Contact Information MG Chemicals, 1210 Corporate Drive Burlington, Ontario, Canada L7L 5R6 Email: support@mgchemicals.com Phone: North America: +(1)800-340-0772 International: +(1) 905-331-1396 Europe: +(44)1663 362888 0.29 W/(m·K) >550 h -70–165 ˚C Disclaimer This information is believed to be accurate. It is intended for professional end-users who have the skills required to evaluate and use the data properly. M.G. Chemicals Ltd. does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. ISO 9001:2015 Quality Management System. Burlington, Ontario, Canada SAI Global File: 004008 02 March 2022 / Ver. 3.1 1
8481-2 价格&库存
很抱歉,暂时无法提供与“8481-2”相匹配的价格&库存,您可以联系我们找货
