KHV12-0.5K10000P
KHV12-0.5K10000P
    KAGA
    DIP7 模块
    高电压 - 非隔离模块 直流转换器 1 输出 500V 10mA 10.8V - 16.5V 输入
KHV12-0.5K10000P 数据手册
KHV Series 5 Watt DC/DC CONVERTER 5 WATT HIGH VOLTAGE DC/DC CONVERTER OUTPUT SPECIFICATIONS FEATURES        Max. Output Capacity 5W Adjustable Output Voltage from 0 to 100% Control Voltage 0 to +6V Over Current Protection On/Off Control (Optional) Adjustable Voltage by Variable Resistor RoHS Compliant DISCRIPTION The KHV series is an ultra-compact, medium-high voltage DC/DC converters with 5sided metal shield case. Output voltage can be adjusted by external voltage or external variable resistor, with built in short circuit and over current protection providing this unit with high reliability and long life. ELECTRICAL SPECIFICATIONS All specifications are typical at nominal input, full load, and 25° C unless otherwise noted. Output Current (see table) See Chart Voltage Accuracy ± 5% or less Ripple and Noise See Chart Line Regulation, Full Load 0.01% typ Load Regulation (0% to 100% of FL) 0.01% Output Voltage Control Either with 0V to +6V external voltage or a 5KΩ external variable resistor. Over Current Protection Drooping characteristic, built-in automatic return circuit, activated at 105% or more On/Off Control Between 2pin and 5pin, ON when open, and OFF when short circuited. GENERAL SPECIFICATIONS Isolation (Input – Output) None Isolated (2 pin and 6 pin internally connected) Ripple Noise(typ) 100mVp-p MTBF(Calculated) 380K hours ENVIRONMENTAL SPECIFICATIONS Operating Temperature -10° C ̴ +50° C Storage Temperature Range -25° C to +85° C Relative Humidity 20% to 95% RH PHYSICAL SPECIFICATIONS INPUT SPECIFICATIONS Input Voltage Range 10.8 ̴ 16.5VDC Input Current 580mA Metallic Shielding 5 Sided Dimensions 60 x 40 x 20 mm Kaga Electronics (USA) Inc. 780 Montague Expressway, Suite #403, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com KHV Series 5 Watt MODEL INPUT VOLTAGE OUTPUT VOLTAGE ADJUSTABLE OUTPUT VOLTAGE RANGE OUTPUT CURRENT INPUT CURRENT RIPPLE NOISE KHV12-0.5K10000P 10.8 ̴ 16.5VDC +500VDC 0 ̴ +500 VDC 0 ̴ 10mA 580mA 100mVp-p KHV12-0.5K10000N 10.8 ̴ 16.5VDC -500VDC 0 ̴ -500 VDC 0 ̴ 10mA 580mA 100mVp-p KHV12-1.0K5000P 10.8 ̴ 16.5VDC +1000VDC 0 ̴ +1000 VDC 0 ̴ 5mA 580mA 100mVp-p KHV12-1.0K5000N 10.8 ̴ 16.5VDC -1000VDC 0 ̴ -1000 VDC 0 ̴ 5mA 580mA 100mVp-p KHV12-2.0K2500P 10.8 ̴ 16.5VDC +2000VDC 0 ̴ +2000 VDC 0 ̴ 2.5mA 580mA 100mVp-p KHV12-2.0K2500N 10.8 ̴ 16.5VDC -2000VDC 0 ̴ -2000 VDC 0 ̴ 2.5mA 580mA 100mVp-p Note 1. The output voltage will be controlled by applying the Vcont voltage. Using an adjustable resistor or an external voltage, voltage should be applied on the Vcont in in order to control the output voltage. When Vcont voltage=0V, the output voltage (output residual voltage) should be less than 2.0% of the max output voltage. 2. The ON/OFF control is optional. When ordering, add a suffix “R” to the end of the product name. (example: KHV12-0.5K10000PR; R=Remote Control) DIMENSIONS: PIN OUTPUT: PIN CONNECTION TEST CIRCUIT: 1 PIN DEFINE 1 +VIN 2 -VIN 3 Vcont 4 Vref 5 ON/OFF 6 Vout(Com) 7 HVout BLOCK DIAGRAM: Vout (+ or -) +Vin 7 +Vin + 12V DC-AC Switching circuit 1 C2 C1 Load 2 Vin Com Vout Com ON/OFF Vref SW1 5 4 (OPEN) Vcont 3 Vin Com 6 (Impress 0V to 6V) 7 Load Output voltage control Over current protection Standard voltage generating part 6 Vout (Com) 2 C1=47μ F C2=4700pF + Output voltage control H.V Out (+ or -) high voltage rectification Control IC + 12V SW1 Open=ON Short=OFF High voltage oscillating transistor Voltage detection circuit SW1 Open=ON Short=OFF Case ON/OFF control part SW1 ON/OFF 5 Vref 4 Vcont 3 External voltage (0~6V) or VR (5KΩ) + Kaga Electronics (USA) Inc. 780 Montague Expressway, Suite #403, San Jose, CA 95131 Phone: (408) 570-0955 | Fax: (408) 570-0186 | Toll Free: (888) 2-VOLGEN (888-286-5436) www.volgen.com
KHV12-0.5K10000P 价格&库存
很抱歉,暂时无法提供与“KHV12-0.5K10000P”相匹配的价格&库存,您可以联系我们找货
