COS1042T/3
COS1042T/3
    COSINE(科山芯创)
    SOP-8
    CAN收发器 高速CAN收发器 Vcc=4.5V~5.5V SOP8_150MIL
COS1042T/3 数据手册
COS1042 High-Speed CAN Transceiver Features General Description ■ Very Low Standby Current (5 μA,typical) The COS1042 is a high-speed CAN, fault ■ Suitable for 12 V and 24 V systems tolerant ■ VIO Supply Pin to interface Directly to CAN between a Controller Area Network (CAN) Controllers and MCU with 1.8V to 5.5V I/O protocol controller and the physical two-wire SPLIT Output Pin to Stabilize Common Mode CAN bus. The COS1042 provides differential in Biased Split Termination Schemes transmit and receive capability for the CAN CAN Bus Pins are Disconnected when protocol controller, and is fully compatible with Device is Unpowered the ISO-11898-2 and ISO-11898-5 standards. ■ ■ ■ Bus Glitch-Free Power-Up and Power-Down ■ Over Temperature Protection ■ Allow Up to 128 Transceivers on the bus ■ Data Rate Up to 5Mbps ■ Half-duplex Transceiver ■ Available Packaging: SOP8/DFN8/DIP8 transceiver. It serves the interface The COS1042 can be interfaced directly to micro-controllers with supply voltages from 1.8V to 5.5V. It has a passive behavior to the CAN bus when the supply voltage is off. Applications The COS1042 has a very low-current standby ■ Industrial Automation, Control reliable communication in the CAN FD fast ■ CAN Networks phase at data rates up to 5 Mbit/s. Rev1.0 Copyright@2018 Cosine Nanoelectronics Inc. All rights reserved The information provided here is believed to be accurate and reliable. Cosine Nanoelectronics assumes no reliability for inaccuracies and omissions. Specifications described and contained here are subjected to change without notice on the purpose of improving the design and performance. All of this information described herein should not be implied or granted for any third party. www.cosine-ic.com mode with bus wake-up capability. It enables Pin Diagram 1 COS1042 1. Pin Configuration and Block Diagram Figure 1 Pin Diagram Pin Description Pin Name 1 TXD 2 3 4 5 5 6 7 8 Description Transmit digital data input. LOW for dominant and HIGH for recessive bus states. GND VCC RXD Ground Supply voltage Receive digital data output; reads out data from the bus lines, LOW for dominant and HIGH for recessive bus states. SPLIT Common-mode stabilization output; in COS1042T version only CANL LOW-level CAN bus I/O line VIO CANH STB Supply voltage for I/O level adapter; in COS1042T/3 version only HIGH-level CAN bus I/O line Standby mode control input ( Active high) 2. Ordering Information Model COS1042 www.cosine-ic.com Order Number Package Package Option Marking Information COS1042T SOP-8 Tape and Reel, 4000 COS1042T COS1042T/3 SOP-8 Tape and Reel, 4000 COS1042T/3 2 COS1042 Note 1: COS1042T has the SPLIT pin. 2: COS1042T/3 has the VIO pin. Figure 2. Block Diagram www.cosine-ic.com 3 COS1042 3. Product Specification 3.1 Absolute Maximum Ratings (1) Min Max Unit DC supply voltage VCC -0.3 7 V DC supply voltage VIO -0.3 7 V DC voltage at TXD, RXD, STB -0.3 VIO + 0.3 V DC voltage at CANH, CANL and SPLIT -44 +44 V RXD output current -8 +8 mA Operating junction temperature -40 +125 °C Storage temperature -55 +150 °C Parameter (1) Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. 3.2 Thermal Data Parameter Package Thermal Resistance Rating Unit 150 (SOP8) 90 (DIP8) 57 (DFN8,3x3) °C/W 3.3 Recommended Operating Conditions Parameter Min. Typ. Max. Unit VCC Supply voltage 4.5 5.0 5.5 V VIO Supply voltage on Pin VIO 2.8 3.3 5.5 V Operating ambient temperature -40 +85 °C Operating junction temperature -40 +125 °C www.cosine-ic.com 4 COS1042 3.4 DC Characteristics (Typical values are tested at TA=25 oC, VCC=4.5V to 5.5V, VIO=2.8V to 5.5V, RL=60Ω, unless otherwise specified.) Parameter Sym. Conditions Min. Typ. Max. Unit VCC 4.5 5.0 5.5 V Undervoltage detection voltage VUVD 3.5 4.0 4.5 V Hysteresis of UVD comparator VUVDH 0.3 0.5 0.8 V Recessive; VTXD=VIO - 4 10 mA Dominant; VTXD=0V - 22 40 mA COS1042T - 12 17 μA COS1042T/3 - - 1 μA 2.8 - 5.5 V 1.3 2.0 2.7 V Normal mode; VTXD=0 or VIO - 20 200 μA Standby mode; - 12 17 μA -0.1 0 +0.1 V 0.5VCC 3 mV Vcc Supply Voltage range Supply current ICC Standby current ICCS VIO Supply Digital Supply voltage range VIO Undervoltage detection voltage VUVIO Supply current IVIO BUS Line (CANH; CANL) Transmitter Standby mode output voltage Recessive output voltage VO(S) VO(R) Recessive Differential output voltage VO(DIFF) Recessive Short circuit output current IO(SC) Dominant output voltage VO(D) Dominant Differential output voltage www.cosine-ic.com VO(DIFF) Standby mode, no load Normal mode, VTXD=VIO, no load 2 VTXD=VIO -50 0 50 mV VTXD=VIO, no load -500 0 50 mV Normal mode, VCANH=VCANH=-27V to +32V -5 +5 mA Pin CANH, VTXD=0V 2.75 3.5 4.5 V Pin CANL, VTXD=0V 0.5 1.5 2.25 V Dominant, Normal mode, VTXD=0V 1.5 2.0 3.0 V 5 COS1042 Dominant Output voltage symmetry -400 0 400 mV CANH; VTXD=0, VCANH=0V -120 -70 -40 mA CANL; VTXD=0, VCANL=18V 40 85 120 mA -1.0 - +0.5 V -1.0 - +0.4 V 0.9 - VDD V 1.0 - VDD V 0.5 0.7 0.9 V 0.4 - 1.15 V 50 - 200 mV RIN 10 15 25 kΩ Common mode resistance matching RIN(M) -1 - +1 % Differential input resistance RIN(DIFF) 20 30 50 kΩ Common mode input capacitance CIN(CM) - - 20 pF Differential input capacitance CIN(DIFF) - - 10 pF +5 μA 0.7VCC V 0.45VCC 0.5VCC 0.55VCC V Dominant Short circuit output current VO(D)(M) VDD-VCANH-VCANL IO(SC) BUS Line (CANH; CANL) Receiver Normal mode; Recessive Differential input voltage VDIFF(RI) 12V  VCANH,CANL  +12V; Standby mode; 12V  VCANH,CANL  +12V; Normal mode; Dominant Differential input voltage VDIFF(DI) 12V  VCANH,CANL  +12V; Standby mode; 12V  VCANH,CANL  +12V; Normal mode; Differential Receiver Threshold VTH(DIFF) 12V  VCANH,CANL  +12V; Standby mode; 12V  VCANH,CANL  +12V; Differential Input Hysteresis Common mode input resistance Input leakage current VHYS(DIFF) ILI Normal mode VCC = VTXD = VSTB = 0V; VCANH = VCANL = 5V -5 SPLIT; Common Mode Stabilization Output Pin (only for COS1042T) Output voltage VO Leakage current IL Normal mode; ISPLIT = -500μA to +500μA Normal mode; RL = 1MΩ Standby mode; VSPLIT = -24V to +24V 0.3VCC 0.5VCC -5 +5 μA TXD, STB Digital Input Pin HIGH-level input voltage VIH 0.7VIO - VIO+0.3 V LOW-level input voltage VIL -0.3 - 0.3VIO V HIGH-level input current IIH -1 +1 μA www.cosine-ic.com 6 COS1042 TXD:LOW-level input current IIL(TXD) STB:LOW-level input current IIL(STB) -270 -150 -30 μA -20 - -1 μA RXD Receive Data Output Pin HIGH-level output voltage VOH IOH=-4mA VIO-0.4 - - V LOW-level output voltage VOL IOL=4mA - - 0.4 V TJ(SD) 160 170 180 °C TJ(HYST) 20 30 40 °C Thermal Shutdown Shutdown junction temperature Shutdown temperature Hysteresis 3.5 Dynamic Characteristics (Typical values are tested at TA=25 oC, VCC=4.5V to 5.5V, VIO=1.8V to 5.5V, RL=60Ω, unless otherwise specified. See Figure 6,7,8) Parameter Sym. Delay TXD Low to bus dominant tTXD-BUSON Min. Typ. Max. Unit Normal mode - 65 - ns Delay TXD High to bus recessive tTXD-BUSOFF Normal mode - 60 - ns Delay bus dominant to RXD tBUSON-RXD Normal mode - 65 - ns Delay bus recessive to RXD tBUSOFF-RXD Normal mode - 65 - ns Propagation delay TXD Low to RXD Low Propagation delay TXD High to RXD High Bus wake-up filter time Delay standby to normal mode Conditions tTXDL-RXDL Normal mode - - 220 ns tTXDH-RXDH Normal mode - - 220 ns tFLTR(WAKE) Standby mode 0.5 1 4 μs 2 3 10 μs tWAKE Negative edge on STB TXD dominant time-out time Tto(dom)TXD VTXD=0V, Normal mode 0.3 2 5 ms Bus dominant time-out time Tto(dom)BUS Standby mode 0.3 2 5 ms 4. Functional Description 4.1 Operating Mode The COS1042 supports two operating modes, Normal and Standby, which are selected via pin STB. See Table 1 for a description of the operating modes under normal supply conditions. www.cosine-ic.com 7 COS1042 Table 1. Operating Modes Mode STB DRIVER RECEIVER Normal LOW Enable (ON) Standby HIGH Disable (OFF) Enable (ON) Only low power Bus monitor is active RXD LOW HIGH Bus dominant Bus recessive Wake-up request detected No wake-up request detected 4.1.1 Normal Mode A LOW level on pin STB selects Normal mode. In this mode, the transceiver can transmit and receive data via the bus lines CANH and CANL (see Figure 2 for the block diagram). The differential receiver converts the analog data on the bus lines into digital data which is output to pin RXD. The slopes of the output signals on the bus lines are controlled internally and are optimized in a way that guarantees the lowest possible EME. 4.1.2 Standby Mode A HIGH level on pin STB selects Standby mode. In Standby mode, the transceiver is not able to transmit or correctly receive data via the bus lines. The transmitter and Normal-mode receiver blocks are switched off to reduce supply current, and only a low-power differential receiver monitors the bus lines for activity. The wake-up filter on the output of the low-power receiver does not latch bus dominant states, but ensures that only bus dominant and bus recessive states that persist longer than tfltr(wake)bus are reflected on pin RXD. In Standby mode, the bus lines are biased to ground to minimize the system supply current. The low-power receiver is supplied by VIO, and is capable of detecting CAN bus activity even if VIO is the only supply voltage available. When pin RXD goes LOW to signal a wake-up request, a transition to Normal mode will not be triggered until STB is forced LOW. 4.2 Fail-Safe Features 4.2.1 TXD Dominant Time-out Function A ‘TXD dominant time-out’ timer is started when pin TXD is set LOW. If the LOW state on pin TXD persists for longer than tto(dom)TXD, the transmitter is disabled, releasing the bus lines to recessive state. This function prevents a hardware and/or software application failure from driving the bus lines to a permanent dominant state (blocking all network communications). The TXD dominant time-out timer is reset when pin TXD is set to HIGH. The TXD dominant time-out time also defines the minimum possible bit rate of 40 kbit/s. www.cosine-ic.com 8 COS1042 4.2.2 Bus Dominant Time-out Function In Standby mode a 'bus dominant time-out' timer is started when the CAN bus changes from recessive to dominant state. If the dominant state on the bus persists for longer than tto(dom)bus, the RXD pin is reset to HIGH. This function prevents a clamped dominant bus (due to a bus short-circuit or a failure in one of the other nodes on the network) from generating a permanent wake-up request. The bus dominant time-out timer is reset when the CAN bus changes from dominant to recessive state. 4.2.3 Internal Biasing of TXD and STB Input Pins Pins TXD and STB have internal pull-ups to VIO to ensure a safe, defined state in case one or both of these pins are left floating. Pull-up currents flow in these pins in all states; both pins should be held HIGH in Standby mode to minimize standby current. 4.2.4 Undervoltage Detection on Pins Vcc and VIO Should VCC drop below the VCC undervoltage detection level, VUVD(VCC), the transceiver will switch to Standby mode. The logic state of pin STB will be ignored until VCC has recovered. Should VIO drop below the VIO undervoltage detection level, VUVD(VIO), the transceiver will switch off and disengage from the bus (zero load) until VIO has recovered. 4.2.5 Over-temperature Protection The output drivers are protected against over-temperature conditions. If the virtual junction temperature exceeds the shutdown junction temperature, Tj(sd), the output drivers will be disabled until the virtual junction temperature falls below Tj(sd) and TXD becomes recessive again. Including the TXD condition ensures that output driver oscillation due to temperature drift is avoided. 4.2.6 Unpowered Device The COS1042 is designed to be “ideal passive” or “no load” to the CAN bus if it is unpowered. The bus terminals (CANH, CANL) have extremely low leakage currents when the device is unpowered to avoid loading down the bus. This is critical if some nodes of the network are unpowered while the rest of the of network remains in operation. The logic terminals also have extremely low leakage currents when the device is unpowered to avoid loading down other circuits that may remain powered. www.cosine-ic.com 9 COS1042 4.2.7 Floating Terminals The COS1042 has internal pull ups on critical terminals to place the device into known states if the terminals float. The TXD terminal is pulled up to VCC or VIO to force a recessive input level if the terminal floats. The STB terminal is also pulled up to force the device into low power Standby mode if the terminal floats. 4.2.8 CAN Bus Short Circuit Current Limiting The COS1042 has The device has two protection features that limit the short circuit current when a CAN bus line is short-circuit fault condition: driver current limiting (both dominant and recessive states) and TXD dominant state time out to prevent permanent higher short circuit current of the dominant state during a system fault. 4.3 SPLIT Output Pin and VIO Supply Pin Two versions of the COS1042 are available, only differing in the function of a single pin. Pin 5 is either a SPLIT output pin or a VIO supply pin. Using the SPLIT pin on the COS1042T in conjunction with a split termination network (see Figure 3 and Figure 4) can help to stabilize the recessive voltage level on the bus. This will reduce EME in networks with DC leakage to ground (e.g. from deactivated nodes with poor bus leakage performance). In Normal mode, pin SPLIT delivers a DC output voltage of 0.5VCC. In Standby mode or when VCC is off, pin SPLIT is floating. When not used, the SPLIT pin should be left open. Pin VIO on the COS1042T/3 should be connected to the micro-controller supply voltage (see Figure 5). This will adjust the signal levels of pins TXD, RXD and STB to the I/O levels of the micro-controller. Pin VIO also provides the internal supply voltage for the low-power differential receiver of the transceiver. For applications running in low-power mode, this allows the bus lines to be monitored for activity even if there is no supply voltage on pin VCC. For versions of the COS1042 without a VIO pin, the VIO input is internally connected to VCC. This sets the signal levels of pins TXD, RXD and STB to levels compatible with 5 V micro-controllers. www.cosine-ic.com 10 COS1042 Figure 3. Stabilization Circuitry and Application for Version with SPLIT Pin 5. Typical Application Diagrams Figure 4. Typical Application with COS1042T and a 5V Micro-controller www.cosine-ic.com 11 COS1042 Figure 5. Typical Application with COS1042T/3 and a 3V Micro-controller Figure 6. Test Circuit for Measuring Transceiver Driver Symmetry www.cosine-ic.com 12 COS1042 Figure 7. CAN Transceiver Timing Diagram Figure 8. CAN FD Timing Definition According to ISO11898-2 www.cosine-ic.com 13 COS1042 6. Package Information 6.1 SOP8 (Package Outline Dimensions) 6.2 DIP8 (Package Outline Dimensions) www.cosine-ic.com 14
COS1042T/3 价格&库存
很抱歉,暂时无法提供与“COS1042T/3”相匹配的价格&库存,您可以联系我们找货
