FTE02P15G/FTP02P15G
150V P-Channel Enhancement Mode MOSFET
General Features
High Dense Cell Design for Low RDS(ON)
Rugged Polysilicon Gate Cell Structure
RoHS Compliant
Halogen-free Available
100% Avalanche Tested
Part Number
BVDSX
RDS(ON) (Typ.)
ID
FTE02P15G
-150V
0.20 Ω
-2.3A
FTP02P15G
-150V
0.20 Ω
-15A
SOP-8
TO-220AB
D
Applications
Reset Switch for Active Clamp Reset
DC-DC Converters
S
S
G
D
S
D
D
D
D
D
G
S
G
S
Ordering Information
Part Number
Package
Marking
Remark
FTE02P15G
SOP-8
02P15
Halogen Free
FTP02P15G
TO-220AB
02P15
Halogen Free
Absolute Maximum Ratings
Symbol
TA =25℃ unless otherwise
Parameter
FTE02P15G
FTP02P15G
Unit
VDSX
Drain-to-Source Voltage[1]
-150
-150
V
VDGX
Drain-to-Gate Voltage[1]
-150
-150
V
Continuous Drain Current
-2.3
-15
-9.2
-60
Power Dissipation
2.5
100
W
Derating Factor above 25℃
0.02
0.8
W/℃
ID
IDM
PD
Pulsed Drain
Current[2]
A
VGS
Gate-to-Source Voltage
±20
V
EAS
Single Pulse Avalanche Energy[3]
200
mJ
IAR
Avalanche Current[2]
-4.0
A
TL
Soldering Temperature
Distance of 1.6mm from case for 10 seconds
300
TJ and
TSTG
Operating and Storage Temperature Range
-55 to 150
Caution: Stresses greater than those listed in the“Absolute Maximum Ratings” may cause permanent damage to the device.
Thermal Characteristics
Symbol
RθJA
Parameter
FTE02P15G
FTP02P15G
Unit
50
1.25
℃/W
Thermal Resistance, Junction-to-Ambient
ARK Microelectronics Co., Ltd.
www.ark-micro.com
1 /7
Rev. 1.0 Aug. 2022
FTE02P15G/FTP02P15G
Electrical Characteristics
OFF Characteristics
Symbol
BVDSX
TA =25℃ unless otherwise specified
Parameter
Drain-to-Source Breakdown Voltage
IDSS
Drain-to-Source Leakage Current
IGSS
Gate-to-Source Leakage Current
Min.
Typ.
Max.
Unit
Test Conditions
-150
V
VGS=0V, IDS=-250µA
-1
µA
VDS=-150V,VGS=0V
100
-100
ON Characteristics
Symbol
Parameter
Static Drain-to-Source On-Resistance
VGS(th)
Gate Threshold Voltage
Forward Transconductance
Min.
Typ.
Max.
Unit
Test Conditions
0.20
0.30
Ω
VGS=-10V,IDS=-1.3A [4]
-1.8
-4.0
V
VGD=0V, IDS=-250µA
4.5
S
VDS=-50V, IDS=-1.3A
Min.
Typ.
Max.
Dynamic Characteristics
Symbol
Parameter
Essentially independent of operating temperature
Ciss
Input Capacitance
1420
Coss
Output Capacitance
180.5
Crss
Reverse Transfer Capacitance
38.4
Qg
Total Gate Charge
35.1
Qgs
Gate-to-Source Charge
9.6
Qgd
Gate-to-Drain (Miller) Charge
13.8
Resistive Switching Characteristics
Symbol
Parameter
Unit
Test Conditions
pF
VGS=0V
VDS=-25V
f=1.0MHZ
nC
VDS=-120V
ID=-1.3A
VGS=-10V
Min.
Typ.
Max.
td(on)
Turn-on Delay Time
16.5
trise
Rise Time
14.6
td(off)
Turn-off Delay Time
35.0
Fall Time
24.6
tfall
Unit
Test Conditions
ns
VGS=-10V
VDD=-75V
RG=6.5Ω
ID=-1.3A
Source-Drain Diode Characteristics
Symbol
VSD
VGS=-20V, VDS=0V
RDS(ON)
gfs
VGS=+20V, VDS=0V
nA
Parameter
Diode Forward Voltage
Min
Typ.
Max.
Unit
Test Conditions
1.5
V
ISD=1.3A, VGS=0V
NOTE:
[1] TJ=+25℃ to +150℃.
[2] Repetitive rating, pulse width limited by maximum junction temperature.
[3] L=25mH,RG=25Ω,IAS=-4.0A,Starting TJ=25°C.
[4] Pulse width≤380µs; duty cycle≤2%.
www.ark-micro.com
2 /7
Rev. 1.0 Aug. 2022
FTE02P15G/FTP02P15G
Typical Characteristics
Figure 1. Maximum Power Dissipation vs.
Case Temperature
Figure 2. Maximum Power Dissipation vs.
Case Temperature
120
PD,Power Dissipation(W)
3
2.5
2
FTE02P15G
1.5
1
0.5
100
80
FTP02P15G
60
40
50
75
100
125
25
150
50
75
100
125
TC,Case Temperature(℃)
Figure 3. Maximum Continuous Drain Current
vs. Case Temperature
Figure 4. Maximum ContinuousDrain Current
vs Case Temperature
2.4
16
14
2
-ID,Drain Current(A)
150
FTE02P15G
1.6
1.2
0.8
FTP02P15G
12
10
8
6
4
0.4
2
50
75
100
125
150
25
50
75
100
125
Figure 6. Typical Transfer Characteristics
22
VGS=-15V
VGS=-12V
VGS=-10V
VGS=-8V
VGS=-7V
VGS=-5V
16
14
-ID,Dranin-to-Source Current(A)
Figure 5.Typical Output Characteristics
150
12
10
8
6
4
VDS=-5V
=5V
18
16
14
12
10
8
6
4
2
2
2
3
4
5
6
7
8
9
1
VDS,Drain Voltage(V)
www.ark-micro.com
3 /7
2
3
4
5
6
7
8
9
VGS,Gate-to-Source Voltage(V)
10
Rev. 1.0 Aug. 2022
FTE02P15G/FTP02P15G
Figure 8. Typical Gate Charge vs.
Figure 7. Typical Capacitance vs.
10
-VGS,Gate-to-Source Voltage(V)
2500
C,Capacitance(pF)
2000
CISS
1500
1000
500
COSS
CRSS
9
8
7
6
5
4
3
2
1
8
12
16
4
8
12 16 20 24 28
QG,Gate Charge(nC)
Figure 9. Maximum Rated Safe Operating Area
100
FTP02P15G
10
1
FTE02P15G
0.1
0.01
0.001
0.1
1
10
RDS(ON),Drain-to-Source Resistance (Ω)
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
0.0
2
3
4
5
6
7
8
9 10 11 12
100
Figure 12. Gate Threshold Voltage vs.
Junction Temperature
ID=-1.3A
1.8
1.6
1.4
1.2
1
0.8
0.6
1.2
1.1
(Normalized)
VGS(th) ,Gate Threshold Voltage
2.2
(Normalized)
36
Figure 10. Drain-to-Source On-Resistance
vs. Drain Current
Figure 11. Drain-to-Source On-Resistance
vs. Junction Temperature
2
32
1
0.9
0.8
0.7
0.6
0.4
-50
-25
50
75
100
125
-50
150
50
75
100
125
150
TJ,Junction Temperature(℃)
-25
www.ark-micro.com
4 /7
Rev. 1.0 Aug. 2022
FTE02P15G/FTP02P15G
Package Dimensions
SOP-8
SYMBOM
MIN
NOM
MAX
A
1.40
1.60
1.80
A1
0.05
0.15
0.25
A2
1.35
1.45
1.55
b
0.30
0.40
0.50
c
0.153
0.203
0.253
D
4.80
4.90
5.00
E
3.80
3.90
4.00
E1
5.80
6.00
6.20
L
0.45
0.70
1.00
θ
2°
4°
6°
L1
1.04 REF
e
1.27 BSC
R1
0.07 TYP
R2
0.07 TYP
www.ark-micro.com
5 /7
Rev. 1.0 Aug. 2022
FTE02P15G/FTP02P15G
TO-220AB
SYMBOM
MIN
NOM
MAX
A
4.30
4.50
4.70
b
0.70
0.80
0.90
b1
1.42
b2
1.17
1.27
1.37
c
0.40
0.50
0.60
c1
1.25
1.30
1.35
c2
2.20
2.40
2.60
D
15.45
15.65
15.85
D1
13.20
13.40
13.60
E
9.80
10.0
10.2
E1
8.60
8.70
8.80
E2
7.80
8.00
8.20
e1
4.88
5.08
5.28
L
12.95
13.15
13.35
L1
2.70
2.80
2.90
L2
2.40
2.50
2.60
L3
6.30
6.50
6.70
θ1
3.50
3.60
3.70
θ2
1.35
1.50
1.65
e
2.54 BSC
www.ark-micro.com
6 /7
Rev. 1.0 Aug. 2022
FTE02P15G/FTP02P15G
Published by
ADD: D26,UESTC National Science Park No. 1 Shuangxing Avenue, Chengdu, Sichuan.
All Rights Reserved.
Disclaimers
ARK Microelectronics Co., Ltd. reserves the right to make change without notice in order to improve
reliability, function or design and to discontinue any product or service without notice. Customers should obtain
the latest relevant information before orders and should verify that such information is current and complete. All
products are sold subject to ARK Microelectronics Co., Ltd’s terms and conditions supplied at the time of
order acknowledgement.
ARK Microelectronics Co., Ltd. warrants performance of its hardware products to the specifications at the
time of sale, Testing, reliability and quality control are used to the extent ARK Microelectronics Co., Ltd
deems necessary to support this warrantee. Except where agreed upon by contractual agreement, testing of all
parameters of each product is not necessary performed.
ARK Microelectronics Co., Ltd. does not assume any liability arising from the use of any product or circuit
designs described herein. Customers are responsible for their products and applications using ARK
Microelectronics Co., Ltd’s components. To minimize risk, customers must provide adequate design and
operating safeguards.
ARK Microelectronics Co., Ltd. does not warrant or convey any license either expressed or implied under its
patent rights, nor the rights of others. Reproduction of information in ARK Microelectronics Co., Ltd’s data
sheets or data books is permissible only if reproduction is without modification or alteration. Reproduction of this
information with any alteration is an unfair and deceptive business practice. ARK Microelectronics Co., Ltd is
not responsible or liable for such altered documentation.
Resale of ARK Microelectronics Co., Ltd’s products with statements different from or beyond the parameters
stated by ARK Microelectronics Co., Ltd. for the product or service voids all express or implied warrantees for
the associated ARK Microelectronics Co., Ltd’s product or service and is unfair and deceptive business
practice. ARK Microelectronics Co., Ltd is not responsible or liable for any such statements.
Life Support Policy:
ARK Microelectronics Co., Ltd’s products are not authorized for use as critical components in life devices or
systems without the expressed written approval of ARK Microelectronics Co., Ltd.
As used herein:
1. Life support devices or systems are devices or systems which:
a. are intended for surgical implant into the human body,
b. support or sustain life,
c. whose failure to perform when properly used in accordance with instructionsfor used provided in the
labeling, can be reasonably expected to result in significantinjury to the user.
2. A critical component is any component is any component of a life support device or system whose failure
to perform can be reasonably expected to cause the failure of the life support device or system, or to affect
its safety or effectiveness.
www.ark-micro.com
7 /7
Rev. 1.0 Aug. 2022
