YLCM1006C-471T
YLCM1006C-471T
    YJYCOIN(益嘉源)
    ACM_10X8.7MM_SM
    共模滤波器 ACM_10X8.7MM_SM 900Ω@100MHz ±40% 1.6A 65mΩ
YLCM1006C-471T 数据手册
Wire Wound Common Mode Choke -YLCM1006C Series ■ Features ● SMD construction,and low profile. ● High Impedance and Excelletn Frequency Characteristic. ● Self Electromagnetic Shielding. ● Low Magnetic Flux Leakage. ■ Applications ● LED Light,TV game,Monitor,etc. ● EMI common-mode noise. ■ Product Identification ⑴ :Type ⑵ :Dimensions ⑶ :Inductance Value ⑷ :Taping ■ Shapes and Dimensions (Unit:mm) TYPE A B C Max D E F YLCM1006C 10.0±0.5 8.7±0.5 6.5 6.22±0.1 7.62±0.1 1.4 Ref 深圳市益嘉源电子有限公司 http://www.yjycoin.com -1- Wire Wound Common Mode Choke -YLCM1006C Series ■ Circuit Diagram ■ YLCM1006C Series Part Number Inductance L1=L2(uH) @100KHz/0.1V DC Resistance (mΩ)Max. Rated Current (A)Max. Hi-Pot (Vac) 3mA/1S Impedance (Ω)Min. Freq. Range (MHz) YLCM1006C-471T 470±40% 65 1.60 1000 900 2~40 1. Rated Current:Temp.rise 40℃ Typ 2. Operating Temperature:-20℃ up to +125℃ 3.Storage Temperature:-20℃ up to +40℃,75% RH max. ■ Materlal List NO. ITEM DESCRIPTION 1 CORE FERRITE 2 CASE DAP-WH9100 3 WIRE P180 Grd1 4 SOLDER Sn99.3:Cu0.7 5 ADHESIVE XNR-3614 6 INK WHITE 深圳市益嘉源电子有限公司 http://www.yjycoin.com -2- Wire Wound Common Mode Choke -YLCM1006C Series ■ Reliability Testing Operating Temperature - 20 to + 125 ℃ ( Contain Heating coil ) Appearance Inspection No external defects by visual inspection Terminal Strength After soldering , between copper plaet and terminals of coils , push in two directions of X , Y with standing 10N(1.02kg) for10+/-2 sec. Terminal should not peel off. ( Refer to figure at right ) Heat endurance of reflow Refer to figure soldering Insulating resistance Over 100 MΩ at 100V D.C . between wire and core . Dielectric Strength Apply at 0.5KV 3mA for 1 minute between wire and core . Temperature characteristics Inductance coefficient ( 0~2,000 ) × 10 / ℃( - 20 ~ + 125 ℃ ) Humidity characteristics Inductance deviation within ± 10% , after 96 hours in 90~95% relative humidity at 40 ± 2 ℃ and 1 hours drying under normal condition . A test is made under the above mentioned condition , and it is kept for 2 hours in the normal ■ Recommended soldering temp.Graph IR Reflow profile Temperature and humidity. After that,no mechanical and electrical defect should be found. 深圳市益嘉源电子有限公司 http://www.yjycoin.com -3- Wire Wound Common Mode Choke -YLCM1006C Series ■ Taping Dimensions(Unit:mm) TYPE W A B D P K T MPQ YLCM1006C 24.0±0.3 10.6±0.3 11. 5±0.1 11.5±0.1 16±0.1 5.0±0.1 0.40±0.05 800 ■ Reel Dimensions(Unit:mm) TYPE W W1 A B C D YLCM1006C 330±2.0 24.4±1.5 30.4MAX 23.9 Min 13.0±0.50 21.0±0.80 深圳市益嘉源电子有限公司 http://www.yjycoin.com -4- Wire Wound Common Mode Choke -YLCM1006C Series ■ Direction of rolling ■ Cover tape peel off condition Cover tape peel force shall be 0.1N to 1.3N. Reference peel speed 300±10mm/min. 深圳市益嘉源电子有限公司 http://www.yjycoin.com -5-
YLCM1006C-471T 价格&库存
很抱歉,暂时无法提供与“YLCM1006C-471T”相匹配的价格&库存,您可以联系我们找货
YLCM1006C-471T
  • 1+5.36580
  • 10+4.33620
  • 160+3.31650
  • 320+3.00960
  • 800+2.85120
库存:787
