DMZ6012E
DMZ6012E
    ARKMICRO(方舟微)
    SOT-23
    MOS管 N-Channel VDS=600V VGS=±20V ID=40mA RDS(ON)=150Ω@50mA SOT23
DMZ6012E 数据手册
DMZ6012E Depletion-Mode Power MOSFET General Features ➢ ➢ ➢ ➢ ➢ ➢ ➢ ESD improved Capability Depletion Mode (Normally On) Proprietary Advanced Planar Technology Rugged Polysilicon Gate Cell Structure Fast Switching Speed RoHS Compliant Halogen-free available RDS(ON) (Max.) IDSS,min 600V 150 Ω 50mA SOT-23 Applications ➢ ➢ ➢ ➢ ➢ ➢ BVDSX D Drain Normally-on Switches SMPS Start-up Circuit Linear Amplifier Converters Constant Current Source Telecom Source G Gate S Ordering Information Part Number Package Marking Remark DMZ6012E SOT-23 612 Halogen Free Absolute Maximum Ratings Symbol TA=25℃ unless otherwise specified Parameter DMZ6012E Unit VDSX Drain-to-Source Voltage[1] 600 V VDGX Drain-to-Gate Voltage[1] 600 V ID Continuous Drain Current 0.04 IDM Pulsed Drain Current[2] 0.16 PD Power Dissipation 0.50 W VGS Gate-to-Source Voltage ±20 V TL Soldering Temperature Distance of 1.6mm from case for 10 seconds 300 TJ and TSTG Operating and Storage Temperature Range A ℃ -55 to 150 Caution: Stresses greater than those listed in the“Absolute Maximum Ratings” may cause permanent damage to the device. Thermal Characteristics Symbol RθJA Parameter Thermal Resistance, Junction-to-Ambient ARK Microelectronics Co., Ltd. www.ark-micro.com 1 /6 DMZ6012E Unit 250 K/W Rev. 2.3 Jan. 2022 DMZ6012E Electrical Characteristics OFF Characteristics Symbol BVDSX ID(OFF) IGSS TA=25℃ unless otherwise specified Parameter Drain-to-Source Breakdown Voltage Min. Typ. Max. Unit Test Conditions 600 -- -- V VGS=-5V, ID=250µA -- -- 1 µA VDS=600V,VGS= -5V -- -- 100 µA VDS=600V,VGS= -5V TJ=125℃ -- -- 20 -- -- -20 Drain-to-Source Leakage Current Gate-to-Source Leakage Current ON Characteristics Symbol IDSS Saturated Drain-to-Source Current RDS(ON) Static Drain-to-Source On-Resistance VGS(OFF) Gate-to-Source Cut-off Voltage gfs Forward Transconductance Min. Typ. Max. Unit Test Conditions 50 -- -- mA VGS=0V, VDS=25V -- 110 150 Ω VGS=0V,ID=50mA [3] -3.3 -- -1.5 V VDS =3V, ID=8µA -- 77 -- mS VDS =10V, ID=5mA Dynamic Characteristics Parameter Essentially independent of operating temperature Min. Typ. Max. CISS Input Capacitance -- 62 -- COSS Oput Capacitance -- 13 -- CRSS Reverse Transfer Capacitance -- 9 -- QG Total Gate Charge -- 8 -- QGS Gate-to-Source Charge -- 0.6 -- QGD Gate-to-Drain (Miller) Charge -- 3 -- Resistive Switching Characteristics Symbol td(ON) trise td(OFF) tfall VGS=-20V, VDS=0V TA=25℃ unless otherwise specified Parameter Symbol VGS=+20V, VDS=0V µA Parameter Test Conditions pF VGS=-5V VDS=25V f=1.0MHZ nC VGS=-5V~5V VDS=300V, ID=7mA Essentially independent of operating temperature Min. Typ. Max. Turn-on Delay Time -- 10 -- Rise Time -- 22 -- Turn-off Delay Time -- 35 -- Fall Time -- 210 -- ARK Microelectronics Co., Ltd. Unit www.ark-micro.com 2 /6 Unit Test Conditions ns VGS = -5V~5V VDD = 300V, ID=7mA RG = 20 Ω Rev. 2.3 Jan. 2022 DMZ6012E Source-Drain Diode Characteristics Symbol VSD Parameter Diode Forward Voltage TA=25℃ unless otherwise specified Min Typ. Max. Units Test Conditions -- -- 1.2 V ISD =100 mA, VGS = -10 V NOTE: [1] TJ=+25℃ to +150℃ [2] Repetitive rating, pulse width limited by maximum junction temperature. [3] Pulse width≤380µs; duty cycle≤2%. ARK Microelectronics Co., Ltd. www.ark-micro.com 3 /6 Rev. 2.3 Jan. 2022 DMZ6012E Typical Characteristics Figure 1. Maximum Power Dissipation vs. Case Temperature Figure 2. Maximum Continuous Drain Current vs. Case Temperature 50 0.5 ID,Drain Current(mA) PD,Power Dissipation(W) 0.6 0.4 0.3 0.2 0.1 40 30 20 10 0 0 25 50 75 100 125 150 25 50 VGS=0.5V VGS=0.4V VGS=0.3V ID,Drain Current(mA) 160 VGS=0.2V VGS=0.1V VGS=0V VGS=-0.1V 140 VGS=-0.2V 120 100 80 60 40 20 0 0 10 20 30 40 150 50 35 VDS=3V 30 25 20 15 10 5 0 -2.0 60 -1.5 -1.0 -0.5 0.0 0.5 1.0 1.5 2.0 VGS,Gate-to-source Voltage(V) VDS,Drain-to-Source(V) Figure 5. Typical Capacitance vs. Drainto-Source Voltage Figure 6. Typical Gate Charge vs. Gateto-Source Voltage 90 VGS,Gate-to-Source Voltage(V) 5 80 C,Capacitance(pF) 125 Figure 4. Typical Transfer Characteristics ID,Drain-to-Source Current(mA) Figure 3.Typical Output Characteristics 180 100 TC,Case Temperature(℃) TC,Case Temperature(℃) 200 75 70 60 CISS 50 40 30 20 COSS 10 0 5 10 15 20 25 30 35 40 3 2 1 0 -1 -2 -3 -4 -5 CRSS 0 4 0 45 2 4 6 8 10 QG,Gate Charge(nC) VDS,Drain Voltage(V) ARK Microelectronics Co., Ltd. www.ark-micro.com 4 /6 Rev. 2.3 Jan. 2022 DMZ6012E Package Dimensions ARK Microelectronics Co., Ltd. www.ark-micro.com 5 /6 Rev. 2.3 Jan. 2022 DMZ6012E Published by ARK Microelectronics Co., Ltd. ADD: D26,UESTC National Science Park No. 1 Shuangxing Avenue, Chengdu, Sichuan. All Rights Reserved. Disclaimers ARK Microelectronics Co., Ltd. reserves the right to make change without notice in order to improve reliability, function or design and to discontinue any product or service without notice. Customers should obtain the latest relevant information before orders and should verify that such information is current and complete. All products are sold subject to ARK Microelectronics Co., Ltd’s terms and conditions supplied at the time of order acknowledgement. ARK Microelectronics Co., Ltd. warrants performance of its hardware products to the specifications at the time of sale, Testing, reliability and quality control are used to the extent ARK Microelectronics Co., Ltd deems necessary to support this warrantee. Except where agreed upon by contractual agreement, testing of all parameters of each product is not necessary performed. ARK Microelectronics Co., Ltd. does not assume any liability arising from the use of any product or circuit designs described herein. Customers are responsible for their products and applications using ARK Microelectronics Co., Ltd’s components. To minimize risk, customers must provide adequate design and operating safeguards. ARK Microelectronics Co., Ltd. does not warrant or convey any license either expressed or implied under its patent rights, nor the rights of others. Reproduction of information in ARK Microelectronics Co., Ltd’s data sheets or data books is permissible only if reproduction is without modification or alteration. Reproduction of this information with any alteration is an unfair and deceptive business practice. ARK Microelectronics Co., Ltd is not responsible or liable for such altered documentation. Resale of ARK Microelectronics Co., Ltd’s products with statements different from or beyond the parameters stated by ARK Microelectronics Co., Ltd. for the product or service voids all express or implied warrantees for the associated ARK Microelectronics Co., Ltd’s product or service and is unfair and deceptive business practice. ARK Microelectronics Co., Ltd is not responsible or liable for any such statements. Life Support Policy: ARK Microelectronics Co., Ltd’s products are not authorized for use as critical components in life devices or systems without the expressed written approval of ARK Microelectronics Co., Ltd. As used herein: 1. Life support devices or systems are devices or systems which: a. are intended for surgical implant into the human body, b. support or sustain life, c. whose failure to perform when properly used in accordance with instructionsfor used provided in the labeling, can be reasonably expected to result in significantinjury to the user. 2. A critical component is any component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. ARK Microelectronics Co., Ltd. www.ark-micro.com 6 /6 Rev. 2.3 Jan. 2022
DMZ6012E 价格&库存
很抱歉,暂时无法提供与“DMZ6012E”相匹配的价格&库存,您可以联系我们找货
DMZ6012E
  • 5+0.36960
  • 20+0.36300
  • 100+0.34980
库存:22
DMZ6012E
  • 5+0.89652
  • 50+0.73400
  • 150+0.65275
  • 500+0.59180
  • 3000+0.49997
  • 6000+0.47556
库存:928
