NSi6601B-DSWVR
NSi6601B-DSWVR
    NOVOSENSE(纳芯微)
    SOP8_300MIL
    栅极驱动 单通道隔离栅极驱动器 SOP8_300MIL Vinput=3V~17V
NSi6601B-DSWVR 数据手册
NSi6601 Single-Channel Isolated Gate Driver Datasheet (EN) 1.2 Product Overview Safety Regulatory Approvals The NSi6601 is a single-channel isolated gate driver designed to drive IGBTs, power MOSFETs and SiC MOSFETs in many applications. It provides split outputs that control the rise and fall time individually. It can source and sink 5A peak current. The NSi6601 is available in SOP8(150 mil) or SOP8(300 mil) package, which can support 3000VRMS or 5700VRMS isolation per UL1577. System robustness is supported by 150kV/us minimum common-mode transient immunity (CMTI). The driver operates with a maximum supply voltage of 32V, while the input-side accepts from 3.1V to 17V supply voltage. Under voltage lock-out (UVLO) protection is supported by all the power supply voltage pins. With high driving current, excellent robustness, wide supply voltage range and fast signal propagation, NSi6601 is suitable for high reliability, power density and efficiency switching power system.  UL recognition: 3000VRMS SOP8(150 mil) and 5700VRMS SOP8(300 mil) for 1 minute per UL1577  DIN VDE V 0884-11:2017-01  CSA component notice 5A  CQC certification per GB4943.1-2011 Key Features Applications  Isolated DC/DC and AC/DC Power Supplies  High Voltage PFC  Solar Inverters  Motor Drives and EV Charging  UPS and Battery Chargers Device Information Part Number NSi6601B-DSPR UVLO Level 9V NSi6601C-DSPR 13V  Isolated single-channel driver  Input side supply voltage: 3.1V to 17V NSi6601C-DSWVR 13V  Driver side supply voltage: up to 32V with 9V and 13 UVLO options NSi6601B-DSWVR 9V  5A peak source and sink output current  High CMTI: ±150kV/us  78ns typical propagation delay  Operation ambient temperature: -40°C ~125°C  AEC-Q100 Grade1 option  RoHS-compliant packages: Package SOP8 (150 mil) SOP8 (150 mil) SOP8 (300 mil) SOP8 (300 mil) AEC-Q100 NO NO NO NO Functional Block Diagrams SOP8(150 mil) SOP8(300 mil) NSi6601 Block Diagram Copyright © 2021, NOVOSENSE Page 1 NSi6601 Datasheet (EN) 1.2 INDEX 1. PIN CONFIGURATION AND FUNCTIONS...................................................................................................................................... 3 2. ABSOLUTE MAXIMUM RATINGS..................................................................................................................................................4 3. RECOMMENDED OPERATING CONDITIONS................................................................................................................................ 4 4. THERMAL INFORMATION.............................................................................................................................................................4 5. SPECIFICATIONS............................................................................................................................................................................5 5.1. 5.2. 5.3. 5.4. DC ELECTRICAL CHARACTERISTICS.............................................................................................................................................5 SWITCHING CHARACTERISTICS.................................................................................................................................................. 6 TYPICAL PERFORMANCE CHARACTERISTICS.................................................................................................................................7 PARAMETER MEASUREMENT INFORMATION.............................................................................................................................. 8 6. HIGH VOLTAGE FEATURE DESCRIPTION...................................................................................................................................... 9 6.1. 6.2. 6.3. 6.4. 6.5. 6.6. 6.7. INSULATION AND SAFETY RELATED SPECIFICATIONS.....................................................................................................................9 DIN VDE V 0884-11 (VDE V 0884-11): 2017-01 INSULATION CHARACTERISTICS FOR SOP8(150 MIL) PACKAGE....................... 10 SAFETY LIMITING VALUES FOR SOP8(150 MIL) PACKAGE......................................................................................................... 11 REGULATORY INFORMATION FOR SOP8(150 MIL) PACKAGE..................................................................................................... 12 DIN VDE V 0884-11 (VDE V 0884-11): 2017-01 INSULATION CHARACTERISTICS FOR SOP8(300 MIL) PACKAGE....................... 13 SAFETY LIMITING VALUES FOR SOP8(300 MIL) PACKAGE......................................................................................................... 14 REGULATORY INFORMATION FOR SOP8(300 MIL) PACKAGE..................................................................................................... 15 7. FUNCTION DESCRIPTION............................................................................................................................................................16 7.1. 7.2. 7.3. 7.4. 7.5. 7.6. 7.7. OVERVIEW.......................................................................................................................................................................... 16 FUNCTIONAL BLOCK DIAGRAM...............................................................................................................................................16 TRUTH TABLES.....................................................................................................................................................................17 OUTPUT STAGE....................................................................................................................................................................17 VCC1, VCC2 AND UNDER VOLTAGE LOCK OUT (UVLO).............................................................................................................. 18 ACTIVE PULL-DOWN.............................................................................................................................................................18 SHORT CIRCUIT CLAMPING.................................................................................................................................................... 18 8. APPLICATION NOTE.................................................................................................................................................................... 19 8.1. 8.2. 8.3. TYPICAL APPLICATION CIRCUIT............................................................................................................................................... 19 INTERLOCK PROTECTION........................................................................................................................................................19 PCB LAYOUT.......................................................................................................................................................................19 9. PACKAGE INFORMATION........................................................................................................................................................... 21 10. ORDERING INFORMATION.......................................................................................................................................................22 11. DOCUMENTATION SUPPORT................................................................................................................................................... 22 12. TAPE AND REEL INFORMATION............................................................................................................................................... 23 13. REVISION HISTORY................................................................................................................................................................... 25 Copyright © 2021, NOVOSENSE Page 2 NSi6601 Datasheet (EN) 1.2 1. Pin Configuration and Functions Figure 1.1 NSi6601 Top View Table 1.1 NSi6601 Pin Configuration and Description NSi6601 PIN NO. SYMBOL 1 VCC1 Input-side supply rail 2 IN+ Non-inverted input signal with internal pull down to GND1 3 IN- Inverted input signal with internal pull up to VCC1 4 GND1 5 VCC2 6 OUT+ Driver source output 7 OUT- Driver sink output 8 VEE2 Negative output supply rail Copyright © 2021, NOVOSENSE FUNCTION Input-side ground reference Positive output supply rail Page 3 NSi6601 Datasheet (EN) 1.2 2. Absolute Maximum Ratings Parameters Symbol Min Max VCC1-GND1 -0.3 18 V VIN+-GND1, VIN--GND1 -0.3 18 V VCC2-VEE2 -0.3 35 V VOUT+, VOUT- VEE2-0.3 VCC2+0.3 V Operating Junction Temperature TJ -40 150 °C Storage Temperature Tstg -65 150 °C VESD_HBM ±2000 V VESD_CDM ±1500 V Max Unit Input Side Supply Voltage Input Signal Voltage Driver Side Supply Voltage Output Signal Voltage Electrostatic discharge Unit 3. Recommended Operating Conditions Parameters Input Side Supply Voltage Input Signal Voltage Driver Side Supply Voltage Symbol Min VCC1-GND1 3 17 V VIN+-GND1, VIN--GND1 -0.3 17 V VCC2-VEE2(NSi6601B) 10 32 VCC2-VEE2(NSi6601C) 13.7 32 TA -40 125 Ambient Temperature V °C 4. Thermal Information Parameters Symbol NSi6601 SOP8(150 mil) SOP8(300 mil) Unit Junction–to-ambient thermal resistance RθJA 110 120 °C/W Junction–to-top characterization parameter ΨJT 18 38 °C/W Copyright © 2021, NOVOSENSE Page 4 NSi6601 Datasheet (EN) 1.2 5. Specifications 5.1. DC Electrical Characteristics (Unless otherwise noted, VCC1=5V to GND1, VCC2=15V, VEE2=GND2. Typical values are at TA=25°C. All min and max specifications are at TA=-40°C to 125°C) Parameter Symbol Min Typ Max Unit Condition Supply Currents Input Supply Quiescent Current ICC1 0.9 1.5 mA Output Supply Quiescent Current ICC2 1.6 3 mA VCC1 UVLO Rising Threshold VCC1_ON 2.9 3.1 V VCC1 UVLO Falling Threshold VCC1_OFF VCC1 UVLO Hysteresis VCC1_HYS Input Side Supply UVLO Threshold 2.55 2.79 V 0.11 V Driver Side Supply UVLO Threshold (NSi6601B, 9V UVLO Level) VCC2 UVLO Rising Threshold VCC2_ON VCC2 UVLO Falling Threshold VCC2_OFF VCC2 UVLO Hysteresis VCC2_HYS 9.2 8 10 V 8.5 V 0.7 V Driver Side Supply UVLO Threshold (NSi6601C, 13V UVLO Level) VCC UVLO Rising Threshold VCC_ON VCC UVLO Falling Threshold VCC_OFF VCC UVLO Hysteresis VCC_HYS 13.2 11.7 13.7 V 12.3 V 0.9 V Input Pin Characteristic Logic High Input Threshold (IN+, IN) VIN+H, VIN-H Logic Low Input Threshold (IN+, IN-) VIN+L, VIN-L Input Hysteresis Voltage (IN+, IN-) 0.7×VCC1 0.3×VCC1 V V Vhys_IN 0.1×VCC1 V IN+ Input Current IIN+ 55 100 uA VIN+=VCC1 IN- Input Current IIN- 55 100 uA VIN-=GND1 V IOUT+=-50mA, VIN+=High, VIN=Low Output Pin Characteristic High Level Output Voltage VOH Low Level Output Voltage VOL Peak Source Output Current IOUT+ 4 5 A VCC2=15V, pulse width600 V DIN EN 60112 (VDE 0303-11); IEC 60112 I I Material Group Copyright © 2021, NOVOSENSE Page 9 NSi6601 Datasheet (EN) 1.2 6.2. DIN VDE V 0884-11 (VDE V 0884-11): 2017-01 Insulation Characteristics for SOP8(150 mil) Package Description Test Condition Symbol Value Unit Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 150 VRMS I to IV For Rated Mains Voltage ≤ 300 VRMS I to III Climatic Category 40/125/21 Pollution Degree 2 700 VRMS 990 VDC VIORM 990 VPEAK Vpd(m) 1485 VPEAK Vpd(m) 1188 VPEAK Vpd(m) 1188 VPEAK Maximum Working Isolation Voltage VIOWM Maximum Repetitive Peak Isolation Voltage Input to Output Test Voltage, Method B1 Vpd(m)=VIORM×1.5, 100% production test, tini=tm=1s, partial discharge
NSi6601B-DSWVR 价格&库存
很抱歉,暂时无法提供与“NSi6601B-DSWVR”相匹配的价格&库存,您可以联系我们找货
