NSI1312S-DSWVR
NSI1312S-DSWVR
    NOVOSENSE(纳芯微)
    SOW8_300MIL
    隔离放大器 高可靠性增强型隔离放大器 SOW8_300MIL 5KVrms
NSI1312S-DSWVR 数据手册
NSi1312 High Reliability Reinforced Isolated Amplifier Datasheet (EN) 1.2 Key Features  Up to 5000VRMS Insulation Voltage  ±1.2V Linear Input Voltage Range  Offset Drift: ±20μV/℃ (Typ)  Gain Error: ±1% (Max)  Gain Drift: ±30ppm/℃ (Typ)  Nonlinearity: ±0.3% (Max)  Nonlinearity Drift: ±10ppm/℃ (Typ)  SNR: 72dB (Typ)  SOP8 narrow body (SOP 150mil)  UL recognition:  SOW8: 5000Vrms for 1 minute per UL1577  SOP8: 3000Vrms for 1 minute per UL1577  CQC certification per GB4943.1-2011  CSA component notice 5A approval IEC60950-1 standard  DIN VDE V 0884-11:2017-01 Applications  AC motor controls  Power and solar inverters  Uninterruptible Power Suppliers  Automotive onboard chargers Device Information Part Number NSI1312x-DSWVR Package SOW8(300mil) Body Size 5.85mm × 7.50mm NSI1312x-DSPR SOP8(150mil) 4.90mm × 3.90mm Functional Block Diagrams VDD1  Excellent DC Performance: Offset Error: ±5mV (Max) SOW8 wide body (SOP8 300mil) Safety Regulatory Approvals  Fixed Gain : 1   VDD2 VDD1 detection Reference INP Σ-Δ modulator INN  Copyright © 2022, NOVOSENSE Retiming and 4thOrder Active Low-Pass Filter OUTP OUTN Reference GND1 GND2 Figure 1. NSi1312D Block Diagram VDD1 VDD2 VDD1 detection Reference INP Σ-Δ modulator INN TX RX Oscillator VDD1 monitoring  Operation Temperature: -40℃~125℃ RX Oscillator  High CMTI: 100kV/μs (Typ)  System-Level Diagnostic Features: TX Isolation Barrier NSI1312 is a cost-effective isolated amplifier with output separated from input based on the NOVOSENSE capacitive isolation technology Adaptive OOK®. The device has a linear differential input signal range of ±1.2V (±1.5V fullscale). The high input impedance of NSI1312 makes it highly suitable for connection to high-voltage resistive dividers or other voltage signal sources with high output resistance. The device has a fixed gain of 1 and provides differential analog output version(NSI1312D) and single-ended analog output version(NSI1312S) option. The low offset and gain drift ensure the accuracy over the entire temperature range. The high common-mode transient immunity ensures that the device is able to provide accurate and reliable measurements even in the presence of high-power switching such as in motor control applications. The fail-safe function (missing VDD1 detection) simplifies system-level design and diagnostics.  RoHS-Compliant Packages: Isolation Barrier Product Overview GND1 Retiming and 4thOrder Active Low-Pass Filter OUT Reference REFIN GND2 Figure 2. NSi1312S Block Diagram Page 1 NSi1312 Datasheet (EN) 1.2 INDEX 1. PIN CONFIGURATION AND FUNCTIONS............................................................................................................................. 3 2. ABSOLUTE MAXIMUM RATINGS ......................................................................................................................................... 5 3. RECOMMENDED OPERATING CONDITIONS ....................................................................................................................... 5 4. THERMAL INFORMATION ................................................................................................................................................... 5 5. SPECIFICATIONS ................................................................................................................................................................ 5 5.1. 5.2. 5.3. 5.4. ELECTRICAL CHARACTERISTICS....................................................................................................................................... 6 POWER RATING CHARACTERISTICS .................................................................................................................................. 7 TYPICAL PERFORMANCE CHARACTERISTICS ...................................................................................................................... 8 PARAMETER MEASUREMENT INFORMATION .................................................................................................................... 10 6. HIGH VOLTAGE FEATURE DESCRIPTION .......................................................................................................................... 11 6.1. 6.2. 6.3. INSULATION AND SAFETY RELATED SPECIFICATIONS ......................................................................................................... 11 INSULATION CHARACTERISTICS..................................................................................................................................... 11 REGULATORY INFORMATION ......................................................................................................................................... 13 7. FUNCTION DESCRIPTION ................................................................................................................................................ 13 7.1. 7.2. 7.3. OVERVIEW ................................................................................................................................................................ 13 ANALOG INPUT .......................................................................................................................................................... 14 ANALOG OUTPUT ....................................................................................................................................................... 14 8. APPLICATION NOTE ......................................................................................................................................................... 17 8.1. 8.2. 8.3. TYPICAL APPLICATION CIRCUIT .................................................................................................................................... 17 SENSE RESISTOR SELECTION ....................................................................................................................................... 17 PCB LAYOUT ............................................................................................................................................................ 18 9. PACKAGE INFORMATION ................................................................................................................................................. 18 10. ORDERING INFORMATION ............................................................................................................................................. 21 11. DOCUMENTATION SUPPORT ......................................................................................................................................... 21 12. TAPE AND REEL INFORMATION ..................................................................................................................................... 22 13. REVISION HISTORY ........................................................................................................................................................ 24 Copyright © 2022, NOVOSENSE Page 2 NSi1312 Datasheet (EN) 1.2 1. Pin Configuration and Functions VDD1 1 INP 2 INN 3 GND1 4 NSI1312D TOP VIEW 8 VDD2 7 OUTP 6 OUTN 5 GND2 Figure 1.1 NSi1312D Package (SOW8 and SOP8) Table 1.1 NSi1312D Pin Configuration and Description NSi1312D PIN NO. SYMBOL FUNCTION 1 VDD1 Power supply for isolator input side (4.5V to 5.5V) 2 INP Positive analog input 3 INN Negative analog input 4 GND1 Ground 1, the ground reference for input side 5 GND2 Ground 2, the ground reference for output side 6 OUTN Negative output 7 OUTP Positive output 8 VDD2 Power supply for isolator output side (3.0V to 5.5V) Copyright © 2022, NOVOSENSE Page 3 NSi1312 Datasheet (EN) 1.2 VDD1 1 INP 2 INN 3 GND1 4 NSI1312S TOP VIEW 8 VDD2 7 OUT 6 REFIN 5 GND2 Figure 1.2 NSi1312S Package (SOW8 and SOP8) Table 1.2 NSi1312S Pin Configuration and Description NSi1312S PIN NO. SYMBOL FUNCTION 1 VDD1 Power supply for input side (4.5V to 5.5V) 2 INP Positive analog input 3 INN Negative analog input 4 GND1 Ground 1, the ground reference for input side 5 GND2 Ground 2, the ground reference for output side 6 REFIN External Reference Input 7 OUT Output 8 VDD2 Power supply for output side (3.0V to 5.5V) Copyright © 2022, NOVOSENSE Page 4 NSi1312 Datasheet (EN) 1.2 2. Absolute Maximum Ratings Parameters Symbol Min VDD1, VDD2 -0.3 6.5 V INP, INN GND1-6 VDD1+0.5 V REFIN GND2-0.5 VDD2+0.5 V OUTP, OUTN, OUT GND2-0.5 VDD2+0.5 V Io -10 10 mA Operating Temperature TOPR -40 125 ℃ Junction Temperature TJ -40 150 ℃ Storage Temperature TSTG -55 150 ℃ HBM (1) ±2000 V CDM (2) ±1000 V Power Supply Voltage Input Voltage Output Voltage Output current per Output Pin Electrostatic discharge Typ Max Unit (1) Human body model (HBM), per AEC-Q100-002-RevD (2) Charged device model (CDM), per AEC-Q100-011-RevB 3. Recommended Operating Conditions Parameters Symbol Min Typ Max Unit Input side Power Supply VDD1 3.0 5.0 5.5 V Output side Power Supply VDD2 3.0 3.3 5.5 V Differential input voltage before clipping output VClipping Linear differential input full scale voltage VFSR -1.2 1.2 V Operating common-mode input voltage VCM -0.8 0.8 V Operating Ambient Temperature TA -40 125 ℃ ±1.5 V 4. Thermal Information Parameters Symbol SOW8 SOP8 Unit Junction–to-ambient thermal resistance RθJA 86 137.7 ℃/W Junction-to-case (top) thermal resistance RθJC(top) 28 54.9 ℃/W Junction-to-board thermal resistance RθJB 42 71.7 ℃/W Junction–to-top characterization parameter ΨJT 4 12 ℃/W Junction-to-board characterization parameter ΨJB 42 46 ℃/W 5. Specifications Copyright © 2022, NOVOSENSE Page 5 NSi1312 Datasheet (EN) 1.2 5.1. Electrical Characteristics (AVDD = 3.0V ~ 5.5V, DVDD = 3.0V ~ 5.5V, INP = -1.2V to +1.2V, and INN = AGND = 0V, TA = -40℃ to 125℃. Unless otherwise noted, Typical values are at VDD1 = 5V, VDD2 = 3.3V, TA = 25℃.Output characteristics is based on OUTP-OUTN for NSI1312D, is based on OUT-REFIN for NSI1312S.) Parameters Symbol Min Typ Max Unit Input side supply voltage VDD1 3.0 5.0 5.5 V Output side supply voltage VDD2 3.0 5.0 5.5 V Input side supply current IDD1 7.2 9 mA Output side supply current IDD2 4.7 6.2 mA Comments Power Supply VDD1 undervoltage detection threshold voltage VDD1UV 1.8 2.3 2.7 V VOS -5 ±1 5 mV TCVOS -25 0.5 25 μV/°C VDD1 falling Analog Input Input offset voltage Input offset drift INP = INN = GND1, at TA =25℃ CMRRdc -80 dB INP = INN, fIN = 0 Hz, VCM min ≤ VIN ≤ VCM max CMRRac -82 dB INP = INN, fIN = 10 kHz, VCM min ≤ VIN ≤ VCM max Single-ended input resistance RIN 1 MΩ INN = GND1 Differential input resistance RIND 1.6 MΩ Input capacitance CI 2 pF Input bias current IIB Common-mode rejection ratio Input bias current drift -0.7 TCIIB -0.6 -0.5 uA -1 nA/°C 1 V/V INP = INN = GND1, at TA =25℃, IIB = (IIBP + IIBN) / 2 Analog Output Nominal Gain Gain error Gain error thermal drift EG -0.4% ±0.1% 0.4% TCEG -50 -10 50 -0.05% ±0.01% 0.05% Nonlinearity Nonlinearity drift Total harmonic distortion THD Output noise Signal to noise ratio SNR Common-mode output voltage VCMout Copyright © 2022, NOVOSENSE 1.39 at TA =25℃ ppm/°C at TA =25℃ ±1 ppm/°C -70 dB 100 µVRMS 78 dB 1.44 1.49 V VIN =±1.2V, fIN = 10kHz, BW = 50kHz INP = INN = GND1, BW = 50kHz VIN =±1.2V, fIN = 10kHz, BW = 50kHz Only for NSI1312D Page 6 NSi1312 Differential fail-safe output voltage Datasheet (EN) 1.2 VFAILSAFE -1.8 -1.7 0 Single-ended fail-safe output voltage VFAILSAFE Single end reference input REFIN Single end reference input impedance REFININ V NSI1312D VDD1 missing V NSI1312S VDD1 missing, REFIN1.8V VDD21.5 V Only for NSI1312S. See application description for more details. 1 GΩ 100 kHz PSRRdc -95 dB PSRR vs VDD1, at DC PSRRac -95 dB PSRR vs VDD1, 100mV and 10kHz ripple PSRRdc -90 dB PSRR vs VDD2, at DC PSRRac -80 dB PSRR vs VDD2 for NSI1312D, 100mV and 10kHz ripple PSRRac -72 dB PSRR vs VDD2 for NSI1312S, 100mV and 1kHz ripple Output resistance ROUT < 0.2 Ω Output limit current ILIM ±13 mA 150 kV/μs Output bandwidth Power supply rejection ratio Common-mode transient immunity BW CMTI 50 100 Only for NSI1312S Common-mode transient immunity Timing Rising time of OUTP, OUTN tr 3.6 μs Falling time of OUTP, OUTN tf 3.6 μs INP, INN to OUTP, OUTN signal delay (50% - 50%) tPD 3.5 Analog setting time tAS 0.5 4 μs ms VDD1 step to 5.0 V with VDD2 ≥ 3.0 V, to OUTP, OUTN valid, 0.1% settling 5.2. Power Rating Characteristics Parameters Symbol Max Unit Comments Total Power dissipation PD 83.6 mW VDD1=VDD2=5.5V Power dissipation of high side PD1 49.5 mW VDD1=5.5V Power dissipation of low side PD2 34.1 mW VDD2=5.5V Copyright © 2022, NOVOSENSE Page 7 NSi1312 Datasheet (EN) 1.2 5.3. Typical Performance Characteristics Unless otherwise noted, test at NSI1312D VDD1 = 5V, VDD2 = 3.3V, INN=GND1=0V, INP = -1.2V to 1.2V, fIN = 1kHz, BW = 10kHz. Characteristics of NSI1312S may be related to REFIN accuracy. 0.4 0.02 0.3 0.018 Sample1 0.016 Sample2 0.014 Sample3 Nonlinearity/% 0.2 Vos/mV 0.1 0 -0.1 Sample 1 -0.2 -40 -20 0 20 40 60 80 100 0.006 0.002 Sample 3 -0.4 0.01 0.008 0.004 Sample 2 -0.3 0.012 0 120 -40 140 -20 0 20 Templerature(℃) 60 80 100 120 140 Figure 5. 3 Nonlinearity vs Temperature Figure 5. 1 Input Offset Voltage vs Temperature -0.55 0.2 0.15 Sample 1 0.1 Sample 2 0.05 Sample 3 Sample 1 -0.56 Sample 2 Sample 3 -0.57 IIByuA Gain Error/% 40 Templerature(℃) 0 -0.05 -0.58 -0.59 -0.1 -0.6 -0.15 -0.61 -0.2 -40 -20 0 20 40 60 80 100 120 -40 140 -20 0 20 40 60 80 100 120 140 Templerature(℃) Templerature(℃) Figure 5. 4 Input Bias Current vs Temperature Figure 5. 2 Gain Error vs Temperature -60 1.6 -65 1.59 -75 RinDyMΩ CMRRydB -70 -80 1.58 1.57 -85 1.56 -90 -95 -40 -20 0 20 40 60 80 100 120 140 Templerature(℃) Figure 5. 5 Common-Mode Rejection Ratio vs Temperature Copyright © 2022, NOVOSENSE 1.55 -40 -20 0 20 40 60 80 100 120 140 Templerature(℃) Figure 5. 6 Differential Input Resistance vs Temperature Page 8 Datasheet (EN) 1.2 -65 -65 -66 -66 -67 -67 -68 -68 -69 -69 THDydB THDydB NSi1312 -70 -71 -72 VDD1 VDD2 -70 -71 -72 -73 -73 -74 -74 -75 -40 -20 0 20 40 60 80 100 120 -75 140 3 Templerature(℃) 4.5 5 5.5 Figure 5. 8 THD vs Supply Voltage 82 82 81 81 80 80 79 SNRydB SNRydB 4 Supply Voltage(V) Figure 5. 7 THD vs Temperature 78 77 VDD1 VDD2 79 78 77 76 76 75 -40 -20 0 20 40 60 80 100 120 75 140 3 Templerature(℃) 3.5 4 4.5 5 5.5 Supply Voltage(V) Figure 5. 9 SNR vs Temperature Figure 5. 10 SNR vs Supply Voltage 0 2.5 vs VDD1 -20 2 vs VDD2 Output VoltageyV -40 PSRRydB 3.5 -60 -80 1.5 1 0.5 -100 -120 0.1 1 10 100 Frequency(kHz) Figure 5. 11 Power-Supply Rejection Ratio vs Ripple Frequency (NSI1312D) Copyright © 2022, NOVOSENSE 1000 OUTP-GND OUTN-GND 0 -2 -1.5 -1 -0.5 0 0.5 1 1.5 2 Input Voltage(V) Figure 5. 12 Output Voltage vs Input Voltage (NSI1312D) Page 9 NSi1312 Datasheet (EN) 1.2 -1.75 1.5 Common Mode VoltageyV Failsafe VoltageyV -1.76 -1.77 -1.78 -1.79 -1.8 -1.81 1.48 1.46 1.44 1.42 -1.82 1.4 -40 -20 0 20 40 60 80 100 120 140 -40 -20 0 20 40 Templerature(℃) Figure 5. 13 Fail-Safe Output Voltage vs Temperature(NSI1312D) 3.5 100 120 140 8 7.5 3.49 3.485 Supply CurrentymA Propagation Delayyus 80 Figure 5. 14 Output Common-Mode Voltage vs Temperature(NSI1312D) 3.495 3.48 3.475 3.47 3.465 7 6.5 3.46 3.455 4.5 -20 0 20 40 60 80 100 120 VDD2=3.3V 5.5 5 -40 VDD1=5V 6 3.45 4 140 -1.2 -0.7 -0.2 Templerature(℃) 0.3 0.8 Input Voltage(V) Figure 5. 15 Vin to Vout Delay vs Temperature Figure 5. 16 Supply Current vs Input Voltage 8 7.5 7.5 7 7 6.5 VDD1=5V 6 VDD2=3.3V 5.5 5 4.5 Supply CurrentymA Supply CurrentymA 60 Templerature(℃) 6.5 6 VDD1 5.5 VDD2 5 4.5 4 -40 -20 0 20 40 60 80 100 120 140 Temperature(C) Figure 5. 17 Supply Current vs Temperature 4 3 3.5 4 4.5 5 5.5 Supply Voltage(V) Figure 5. 18 Supply Current vs Supply Voltage 5.4. Parameter Measurement Information Copyright © 2022, NOVOSENSE Page 10 NSi1312 Datasheet (EN) 1.2 3.3V Battery VDD1 VDD2 INP OUTP INN OUTN GND1 GND2 Differential Probe Oscilloscope High Voltage Probe VCM Figure 5.19 Common-Mode Transient Immunity Test Circuit 6. High Voltage Feature Description 6.1. Insulation and Safety Related Specifications Parameters Symbol Value Unit Comments SOW8 SOP8 CLR 8 4 mm Shortest terminal-to-terminal distance through air Minimum External Tracking (Creepage) CPG 8 4 mm Shortest terminal-to-terminal distance across the package surface Minimum internal gap DTI 28 μm Distance through insulation Tracking Resistance (Comparative Tracking Index) CTI >600 V Minimum External Air Gap (Clearance) Material Group I DIN EN 60112 (VDE 0303-11); IEC 60112 IEC 60664-1 6.2. Insulation Characteristics Description Test Condition Symbol Value Unit DIN VDE 0110 SOP8 SOW8 For Rated Mains Voltage ≤ 150Vrms I to IV I to IV For Rated Mains Voltage ≤ 300Vrms I to III I to IV For Rated Mains Voltage ≤ 600Vrms I to II I to IV 40/125/21 40/125/21 2 2 990 2121 VPEAK 700 1500 VRMS 990 2121 VDC Climatic Classification Pollution Degree per DIN VDE 0110, Table 1 Maximum repetitive isolation voltage Maximum working isolation voltage Copyright © 2022, NOVOSENSE VIORM AC Voltage DC Voltage VIOWM Page 11 NSi1312 Datasheet (EN) 1.2 Description Test Condition VIORM × 1.5 = Vpd (m), 100% production test, Input to Output Test Voltage, Method B1 Input to Output Test Voltage, Method A. After Input and /or Safety Test Subgroup 2 and Subgroup 3 Maximum transient isolation voltage Maximum Surge Isolation Voltage Isolation resistance Isolation capacitance Safety total power dissipation Safety input, output, or supply current Value Unit V pd (m) 1485 / VPEAK V pd (m) / 3977 VPEAK VIORM × 1.3 = Vpd (m), tini = 60 sec, tm = 10 sec, partial discharge < 5 pC V pd (m) 1287 / VPEAK VIORM × 1.6 = Vpd (m), tini = 60 sec, tm = 10 sec, partial discharge < 5 pC V pd (m) / 3394 VPEAK VIORM × 1.2= Vpd (m), tini = 60 sec, tm = 10 sec, partial discharge < 5 pC V pd (m) 1188 2545 VPEAK t = 60 sec VIOTM 4242 7000 VPEAK Test method per IEC62368-1, 1.2/50us waveform, VTEST=VIOSM×1.3 VIOSM 6000 / VPEAK Test method per IEC62368-1, 1.2/50us waveform, VTEST=VIOSM×1.6 VIOSM / 6250 VPEAK VIO =500V, Tamb=Ts RIO >109 >109 Ω VIO =500V, 100℃ ≤ Tamb ≤ 125℃ RIO >1011 >1011 Ω f = 1MHz CIO 0.8 0.8 pF VI = 5.5V, TJ = 150 ℃, TA = 25 ℃ Ps 907 1453 mW 165 / mA / 264 mA Ts 150 150 ℃ VISO 3000 5000 VRMS tini = tm = 1 sec, partial discharge < 5 pC VIORM × 1.875 = Vpd (m), 100% production test, tini = tm = 1 sec, partial discharge < 5 pC Input to Output Test Voltage, Method A. After Environmental Tests Subgroup 1 Symbol θJA = 137.7℃/W for SOP8, VI = 5.5V, TJ = 150 ℃, TA = 25 ℃ θJA = 86℃/W for SOW8, VI = 5.5V, TJ = 150 ℃, TA = 25 ℃ Maximum safety temperature Is UL1577 Insulation voltage per UL Copyright © 2022, NOVOSENSE VTEST = VISO, t = 60 s (qualification), VTEST = 1.2 × VISO, t = 1 s (100% production test) Page 12 NSi1312 Datasheet (EN) 1.2 Safety Limiting Current(mA) 300 SOW8 250 SOP8 200 150 100 50 0 0 50 100 150 Ambient Temperature(℃) 200 Figure 6.1 NSi1312x Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 6.3. Regulatory Information The NSi1312x-DSWVR are approved or pending approval by the organizations listed in table. UL VDE CQC Certified by CQC11-4715432012 UL 1577 Component Recognition Program Approved under CSA Component Acceptance Notice 5A DIN VDE V 0884-11(VDE V 0884-11):2017-01 Single Protection, 5000Vrms Isolation voltage Single Protection, 5000Vrms Isolation voltage Reinforce Insulation 2121Vpeak, VIOSM=6250Vpeak Reinforced insulation Certificate No.E500602 Certificate No.E500602 File (pending) CQC20001264940 GB4943.1-2011 The NSi1312x-DSPR are approved or pending approval by the organizations listed in table. UL VDE CQC Certified by CQC11-4715432012 UL 1577 Component Recognition Program Approved under CSA Component Acceptance Notice 5A DIN VDE V 0884-11(VDE V 0884-11):2017-01 Single Protection, 3000Vrms Isolation voltage Single Protection, 3000Vrms Isolation voltage Basic Insulation 990Vpeak, VIOSM=6000Vpeak Basic insulation Certificate No.E500602 Certificate No.E500602 File (pending) CQC20001264940 GB4943.1-2011 7. Function Description 7.1. Overview The NSI1312 is a cost-effective isolated amplifier with a high input impedance that accept wide range fully-differential input. The fully-differential input is suited to AC or bus voltage monitoring in high voltage applications where isolation is required. The analog input is continuously sampled by a second-order Σ-Δ modulator in the device. With the internal voltage reference and clock generator, the modulator converts the analog input signal to a digital bitstream, as shown in the Figure 7.1. The output of the modulator is transferred by the drivers (called TX in the Functional Block Diagram) across the isolation barrier that separates the isolated input side and output side voltage. The received bitstream and clock are synchronized and processed, as shown in the Functional Block Diagram, by a fourth-order analog filter on the output side and has a differential output. NSI1312 also has singleended output version, as shown in the Figure 7.2, the received bitstream are processed and presented as a single-ended output with external voltage reference from REFIN pin. Copyright © 2022, NOVOSENSE Page 13 NSi1312 Datasheet (EN) 1.2 VDD1 VDD2 VDD1 detection INP Σ-Δ modulator TX INN Isolation Barrier Reference Retiming and 4thOrder Active Low-Pass Filter RX OUTP OUTN Reference Oscillator GND1 GND2 Figure 7.1 Function Block Diagram of Differential Output Version VDD1 VDD2 VDD1 detection INP Σ-Δ modulator INN Oscillator GND1 TX Isolation Barrier Reference RX Retiming and 4thOrder Active Low-Pass Filter OUT Reference REFIN GND2 Figure 7.2 Function Block Diagram of Single-ended Output Version 7.2. Analog Input There are two restrictions on the analog input signals (VINP and VINN).  If the input voltage exceeds the range AGND – 6 V to AVDD + 0.5 V, the input current must be limited to 10 mA because the device input electrostatic discharge (ESD) diodes turn on.  The linearity and noise performance of the device are ensured only when the analog input voltage remains within the specified linear full-scale range (FSR) and within the specified common-mode input voltage range. 7.3. Analog Output For linear input range, the analog output of NSI1312 has a fixed gain of 1. If a full-scale input signal is applied to the NSI1312 (VIN ≥ VClipping), the differential analog output (VOUTP -VOUTN for NSI1312D and VOUT -REFIN for NSI1312S) will be clipped (typically, 1.44V for positive clipping and -1.44V for negative clipping). The negative clipping differential output waveform is shown in Figure 7.3. Copyright © 2022, NOVOSENSE Page 14 NSi1312 Datasheet (EN) 1.2 Vout 1V/div Vneg_clip=-1.44V Figure 7.3 Typical negative clipping output For differential output version (NSI1312D), the differential output pins have a common-mode voltage of 1.44V (typ). The differential output Vout of the NSI1312D is expressed as: 𝑉𝑜𝑢𝑡 = 𝐺𝑎𝑖𝑛 ∗ (𝑉 −𝑉 ) For single-ended output version (NSI1312S), the REFIN pin with high input impedance needs external reference input. The output voltage Vout of the NSI1312S is expressed as: 𝑉𝑜𝑢𝑡 = 𝐺𝑎𝑖𝑛 ∗ (𝑉 −𝑉 ) + 𝑅𝐸𝐹𝐼𝑁 In addition, NSI1312 integrates some diagnostic measures and offers a fail-safe output to simplify system-level design. The failsafe output is a negative differential output voltage that does not occur under normal device operation, and it will only be activated when the undervoltage of VDD1 is detected (VDD1< VDD1UV). For NSI1312D, the typical failsafe output is -1.8V when VDD1 undervoltage, as is shown in Figure 7.4. For NSI1312S, the typical failsafe output is Vfailsafe= 0V if VREF
NSI1312S-DSWVR 价格&库存
很抱歉,暂时无法提供与“NSI1312S-DSWVR”相匹配的价格&库存,您可以联系我们找货
