CM1213-04SO
LOW CAPACITANCE TVS DIODE ARRAY
Features
Ultra low leakage: nA level
Operating voltage: 5V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±20kV
Contact discharge: ±20kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 5A (8/20 μs)
RoHS Compliant
Dimensions SOT-26
AEC -Q101 qualified.
Pin Configuration
Applications
USB 2.0 power and data line
Set-top box and digital TV
Digital video interface (DVI)
Notebook Computers
SIM Ports
10/100/1000 Ethernet
Mechanical Characteristics
Package: SOT-26
Lead Finish: Lead Free
UL Flammability Classification Rating 94V-0
Quantity Per Reel:3,000pcs
Reel Size:7inch
Device Marking: V05
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Symbol
Peak Pulse Power (8/20µs)
Ppp
Value
Unit
350
W
±20
ESD per IEC 61000−4−2 (Air)
Kv
VESD
±20
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2014
1/7
www.leiditech.com
CM1213-04SO
Electrical Characteristics(TA=25°C unless otherwise specified)
Parameter
Symbol Test Condition
Min
Typ
VRWM
Reverse Working Voltage
Breakdown Voltage
VBR
Max
Unit
5
V
6
IT = 1mA
V
Reverse Leakage Current
IR
VRWM = 5V
1
µA
Clamping Voltage
VC
IPP = 1A (8 x 20 μs pulse)
15
V
Clamping Voltage
VC
IPP = 5A (8 x 20 μs pulse)
28
V
Junction Capacitance
CJ
VR = 0V, f = 1MHz
0.5
pF
Characteristic Curves
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
Percent of Peak Pulse Current %
tr
60
40
td=t IPP/2
10
15
30
10%
tr = 0.7~1ns
Time (ns)
30ns
60ns
t - Time ( s)
Fig3.
90%
Power Derating Curve
% of Rated Power
110
100
90
80
70
60
50
40
30
50
75
100
125
150
Ambient Temperature –TA (ºC)
Rev : 01.06.2014
2/7
www.leiditech.com
CM1213-04SO
Applications Information
Figure 1. Data Line and Power Supply Protection
Using VCC as reference
Figure 2. Data Line Protection with Bias and Power
Supply Isolation Resistor
Device Connection Options for Protection of
Four High-Speed Data Lines
The C M 1 2 1 3 - 0 4 S O is designed to protect four data
lines from transient over-voltages by clamping them
to a fixed reference.
When the voltage on the
protected line exceeds the reference voltage (plus
diode VF) the steering diodes are forward biased,
conducting the transient current away from the
sensitive circuitry. Data lines are connected at pins 1, 3,
4 and 6.
The negative reference (REF1) is
connected at pin 2.
This pin should be connected
directly to a ground plane on the board for best results.
The path length is kept as short as possible to minimize
parasitic inductance. The positive reference (REF2) is
connected at pin 5. The options for connecting the
positive reference are as follows:
1. To protect data lines and the power line, connect pin 5
directly to the positive supply rail (VCC).
In this
configuration the data lines are referenced to the
supply voltage.
The internal TVS diode prevents
over-voltage on the supply rail (See Figure1).
2. The CM1213-04SO can be isolated from the power
supply by adding a series resistor between pin 5
and VCC. A value of 100kΩ is recommended.
The internal TVS and steering diodes remain biased,
providing the advantage of lower capacitance (See
Figure2).
Figure 3. Data Line Protection Using Internal TVS
Diode as Reference
Rev : 01.06.2014
3/7
3. In applications where no positive supply reference is
available, or complete supply isolation is desired, the
internal TVS may be used as the reference. In this
case, pin 5 is not connected.
The steering diodes
will begin to conduct when the voltage on the
protected line exceeds the working voltage of the TVS
(plus one diode drop) (See Figure3).
www.leiditech.com
CM1213-04SO
Applications Information (Continue)
Video Interface Protection
Figure 4.Video Interface Protection
Video interfaces are susceptible to transient voltages
resulting from electrostatic discharge (ESD) and “hot
plugging” cables. If left unprotected, the video interface
IC may be damaged or even destroyed. Protecting a
high-speed video port presents some unique challenges.
SRV05-4
First, any added protection device must have extremely
low capacitance and low leakage current so that the
integrity of the video signal is not compromised. Second,
the protection component must be able to absorb high
voltage transients without damage or degradation.
As a
minimum, the device should be rated to handle ESD
voltages per IEC61000-4-2, level 4 (±15kV air, ±8kV
contact). The clamping voltage of the device (when
conducting high current ESD pulses) must be sufficiently
SRV05-4
low enough to protect the sensitive CMOS IC. If the
Figure 5 - Dual USB Port Protection
clamping voltage is too high, the “protected” device may
latch-up or be destroyed. Finally, the device must take up
a relatively small amount of board space, particularly in
portable applications such as notebooks and handhelds.
The CM1213-04SO is designed to meet or exceed all
of the above criteria. A typical video interface protection
circuit is shown in Figure 4. All exposed lines are
SRV05-4
protected including R, G, B, H-Sync, V-Sync, and the
ID lines for plug and play monitors.
Universal Serial Bus ESD Protection
The CM1213-04SO may also be used to protect the
USB ports on monitors, computers, peripherals or
portable systems. Each device will protect up to two
Figure 6 - SIM Port
USB ports (Figure5). When the voltage on the data
lines exceed the bus voltage (plus one diode drop),
the internal rectifiers are forward biased conducting
the transient current away from the protected controller
chip. The TVS diode directs the
surge
to
ground.
The TVS diode also acts to suppress ESD strikes
SRV05-4
directly on the voltage bus. Thus, both power and
data pins are protected with a single device.
Rev : 01.06.2014
4/7
www.leiditech.com
CM1213-04SO
DVI Protection
The small geometry of a typical digital-visual interface (DVI)
graphic chip will make it more susceptible to electrostatic
discharges (ESD) and cable discharge events (CDE).
Transient protection of a DVI port can be challenging.
Digital-visual interfaces can often transmit and receive at a
rate equal to or above 1Gbps. The high-speed data
transmission requires the protection device to have low
capacitance to maintain signal integrity and low clamping
voltage to reduce stress on the protected IC. The
CM1213-04SO has a low typical insertion loss of 1.5kV. If more common mode protection
is needed, figure 9 shows how to design the CM1213-04SO
on the IC side of the 10/100.
www.leiditech.com
CM1213-04SO
Figure 8 - 10/100 Ethernet Differential Protection
Figure 9 - 10/100 Ethernet Differential and Common Mode Protection
Rev : 01.06.2014
6/7
www.leiditech.com
CM1213-04SO
SOT-26 Package Outline & Dimensions
Inches
Symbol
Min.
A
θ
Nom. Max. Min. Nom. Max.
0.035
0.057 0.90
1.45
A1
0.000
0.006 0.00
0.15
A2
0.035 0.045 0.051 0.90 1.15 1.30
b
0.010
0.020 0.25
0.50
0.009 0.08
0.22
c
0.003
D
0.110 0.114 0.122 2.80 2.90 3.10
E1
0.060 0.063 0.069 1.50 1.60 1.75
E
0.110 BSC
2.80 BSC
e
0.037 BSC
0.95 BSC
e1
0.075 BSC
1.90 BSC
L
0.012 0.018 0.024 0.30 0.45 0.60
L1
θ
Soldering Footprint
Millimeters
(0.024)
0°
(0.60)
10°
0°
10°
aaa
0.004
0.10
bbb
0.008
0.20
ccc
0.008
0.20
Symbol
Inches
Millimeters
C
(0.098)
(2.50)
G
0.055
1.40
P
0.037
0.95
X
0.024
0.60
Y
0.043
1.10
Z
0.141
3.60
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
7/7
www.leiditech.com
很抱歉,暂时无法提供与“CM1213-04SO”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.40222
- 100+0.32009
- 300+0.27904
- 3000+0.23798
- 6000+0.21337
- 9000+0.20101
