NSi8260W1-DSWR
NSi8260W1-DSWR
    NOVOSENSE(纳芯微)
    SOP16_300MIL
    数字隔离器 高可靠性增强型六通道数字隔离器 6Channel 5KVrms
NSi8260W1-DSWR 数据手册
NSi826x High Reliability Reinforced Six-Channel Digital Isolators Datasheet (EN) 1.6 Product Overview The NSi826x devices are high reliability six-channel digital isolators. The NSi826x device is safety certified by UL1577 support several insulation withstand voltage(3kV,3.75kV,5kV), while providing high electromagnetic immunity and low emissions at low power consumption. The data rate of the NSi826x is up to 150Mbps, and the common-mode transient immunity (CMTI) is up to 200kV/us. The NSi826x device provides digital channel direction configuration and the default output level configuration when the input power is lost. Wide supply voltage of the NSi826x device supports to connect with most digital interface directly, easy to do the level shift. High system level EMC performance enhance reliability and stability of use. Key Features  Up to 5000Vrms Insulation voltage Safety Regulatory Approvals  UL recognition: up to 5000Vrms for 1 minute per UL1577  CQC certification per GB4943.1-2011  CSA component notice 5A  DIN VDE V 0884-11:2017-01 Applications  Industrial automation system  Isolated SPI, RS232, RS485  General-purpose multichannel isolation Device Information  Date rate: DC to 150Mbps Part Number NSi826x-DSWR  Power supply voltage: 2.5V to 5.5V  High CMTI: 200kV/us  Chip level ESD: HBM: ±8kV  High system level EMC performance: Body Size 10.30mm × 7.50mm NSi826x-DSSR Package SOP16(300mil) SSOP16 NSi826x-DSPNR SOP16(150mil) 9.90mm x 3.90mm 4.90mm × 3.90mm Functional Block Diagrams Enhanced system level ESD, EFT, Surge immunity  Default output high level or low level option  Low power consumption: 1.5mA/ch (1 Mbps)  Low propagation delay: 600 Comparative Tracking Index DIN EN 60112 (VDE 0303-11) Material Group IEC 60112 um V I Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 150Vrms I to III I to IV I to IV For Rated Mains Voltage ≤ 300Vrms I to II I to IV I to III For Rated Mains Voltage ≤ 600Vrms I I to IV I to II For Rated Mains Voltage ≤ 1000Vrms / I to III I to II Insulation Specification per DIN VDE V 0884-11:2017-011) Climatic Category 40/125/21 Pollution Degree per DIN VDE 0110, Table 1 Maximum Working Isolation Voltage AC voltage 2 VIOWM 400 1500 400 VRMS 565 2121 565 VDC VIORM 565 2121 565 Vpeak Vpd (m) 847 / 847 Vpeak DC voltage Maximum Repetitive Isolation Voltage Input to Output Test Voltage, Method B1 Vini. b = VIOTM, Vpd(m) = VIORM × 1.5, tini = tm = 1 sec, qpd ≤ 5 pC, Copyright © 2023, NOVOSENSE Page 16 NSi8260/NSi8261/NSi8262/NSi8263 Description Test Condition Datasheet (EN) 1.6 Symbol Value Unit 100% production test Vini. b = VIOTM, Vpd(m) = VIORM × 1.875, Vpd (m) / 3977 / Vpeak V pd (m) 678 / 678 Vpeak V pd (m) / 3394 / Vpeak V pd (m) 678 2545 678 Vpeak tini = tm =1 sec, qpd≤ 5 pC, 100% production test Input to Output Test Voltage, Method A. After Environmental Tests Subgroup 1 Vini. a = VIOTM, Vpd(m) = VIORM × 1.3, tini = 60 sec, tm = 10 sec, qpd ≤ 5 pC Vini. a = VIOTM, Vpd(m) = VIORM × 1.6, tini = 60 sec, tm = 10 sec, qpd ≤ 5 pC Input to Output Test Voltage, Method A. After Input and Output Safety Test Subgroup 2 and Subgroup 3 Vini. a = VIOTM, Vpd(m) = VIORM × 1.2, Maximum Transient Isolation Voltage t = 60 sec VIOTM 5000 8000 6500 Vpeak Maximum Surge Isolation Voltage Test method per IEC62368-1, VIOSM 5384 / 5384 Vpeak / 6250 / Vpeak tini = 60 sec, tm = 10 sec, qpd ≤ 5 pC 1.2/50us waveform, VTEST = 1.3 × VIOSM Test method per IEC62368-1, 1.2/50us waveform, VTEST = 1.6 × VIOSM Isolation Resistance VIO = 500 V, Tamb = TS RIO >109 VIO = 500 V, 100 °C ≤ Tamb ≤ 125 °C Isolation Capacitance Ω Ω >1011 f = 1MHz CIO VTEST = 1.2 × VISO, t = 1 sec, VISO 1.2 pF Insulation Specification per UL1577 Withstand Isolation Voltage 3000 5000 3750 100% production test 1) This coupler is suitable for “safe electrical insulation” only within the safety ratings. Compliance with the safety ratings shall be ensured by means of suitable protective circuits. Safety-Limiting Values Reinforced isolation safety-limiting values as outlined in VDE-0884-11 of NSi826x-DSWR Description Copyright © 2023, NOVOSENSE Test Condition Value Unit Page 17 Vrms NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 Safety Supply Power RθJA = 60.3 °C/W, TJ = 150 °C, TA = 25 °C 2073 mW Safety Supply Current RθJA = 60.3 °C/W, VI = 5V, TJ = 150 °C, TA = 25 °C 414 mA 150 °C Safety Temperature2) 1) Calculate with the junction-to-air thermal resistance, RθJA, of SOP16(300mil) package (Thermal Information Table) which is that of a device installed on a low effective thermal conductivity test board (1s) according to JESD51-3. 2) The maximum safety temperature has the same value as the maximum junction temperature (TJ) specified for the device. 2000 1500 1000 500 0 0 50 100 150 Ambient Temperature (°C) 200 900 800 700 600 500 400 300 200 100 0 Safety Limiting Current per Channel (mA) Safety Limiting Power (mW) 2500 5V 3.3V 2.5V 0 50 100 150 Ambient Temperature (°C) 200 Figure 6.1 NSi826x-DSWR Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Basic isolation safety-limiting values as outlined in VDE-0884-11 of NSi826x-DSSR Description Test Condition Value Unit Safety Supply Power RθJA =86.5 °C/W, TJ = 150 °C, TA = 25 °C 1445 mW Safety Supply Current RθJA = 86.5 °C/W, VI = 5V, TJ = 150 °C, TA = 25 °C 289 mA 150 °C Safety Temperature2) 1) Calculate with the junction-to-air thermal resistance, RθJA, of SSOP16 package (Thermal Information Table) which is that of a device installed on a low effective thermal conductivity test board (1s) according to JESD51-3. 2) The maximum safety temperature has the same value as the maximum junction temperature (TJ) specified for the device. Copyright © 2023, NOVOSENSE Page 18 1600 700 1400 1200 1000 800 600 600 5V 500 3.3V 400 2.5V 300 400 200 200 0 Datasheet (EN) 1.6 Safety Limiting Current per Channel (mA) Safety Limiting Power (mW) NSi8260/NSi8261/NSi8262/NSi8263 100 0 50 100 150 Ambient Temperature (°C) 200 0 0 50 100 150 200 Ambient Temperature (°C) Figure 6.2 NSi826x-DSSR Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Copyright © 2023, NOVOSENSE Page 19 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 Basic isolation safety-limiting values as outlined in VDE-0884-11 of NSi826x-DSPNR Description Test Condition Value Unit Safety Supply Power RθJA = 78.9°C/W 1), TJ = 150 °C, TA = 25 °C 1584 mW Safety Supply Current RθJA = 78.9°C/W 1), VI = 5V, TJ = 150 °C, TA = 25 °C 316 mA 150 °C Safety Temperature2) Calculate with the junction-to-air thermal resistance, RθJA, of SOP16(150mil) package (Thermal Information Table) which is that of a device installed on a low effective thermal conductivity test board (1s) according to JESD51-3. 2) The maximum safety temperature has the same value as the maximum junction temperature (TJ) specified for the device. 1800 1600 1400 1200 1000 800 600 400 200 0 700 Safety Limiting Current per Channel (mA) Safety Limiting Power (mW) 1) 600 5V 500 3.3V 400 2.5V 300 200 100 0 50 100 150 200 Ambient Temperature (°C) 0 0 50 100 150 200 Ambient Temperature (°C) Figure 6.3 NSi826x-DSPNR Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 Regulatory Information The NSi826xW-DSWR are approved or pending approval by the organizations listed in table. CUL UL 1577 Component Recognition Program Single Protection, 5000Vrms Isolation voltage File (UL-US-L500602-1161808102-1) Copyright © 2023, NOVOSENSE VDE Approved under CSA Component Acceptance Notice 5A Single Protection, 5000Vrms Isolation voltage File (UL-US-L500602-1161808102-1) CQC DIN VDE V 088411(VDE V 088411):2017-01 Certified by CQC11471543-2012 Reinforce Insulation 2121Vpeak, VIOSM=6250Vpeak Reinforced insulation File (50245794880-0002 / 276211) File (CQC20001264939) GB4943.1-2011 Page 20 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 The NSi826xS-DSSR are approved or pending approval by the organizations listed in table. CUL UL 1577 Component Recognition Program Single Protection, 3000Vrms Isolation voltage File (UL-US-L500602-1161808102-1) Approved under CSA Component Acceptance Notice 5A VDE CQC DIN VDE V 088411(VDE V 088411):2017-01 Certified by CQC11471543-2012 GB4943.1-2011 Single Protection, 3000Vrms Isolation voltage Basic Insulation 565Vpeak, VIOSM=5384Vpeak Basic insulation File (UL-US-L500602-1161808102-1) File (5024579-48800001 / 283544) File (CQC19001233128) The NSi826xN-DSPNR are approved or pending approval by the organizations listed in table. CUL UL 1577 Component Recognition Program Single Protection, 3750Vrms Isolation voltage File (pending) Copyright © 2023, NOVOSENSE VDE CQC DIN VDE V 088411(VDE V 088411):2017-01 Certified by CQC11471543-2012 Single Protection, 3750Vrms Isolation voltage Basic Insulation 565Vpeak, VIOSM=5384Vpeak Basic insulation File (pending) File (pending) File (pending) Approved under CSA Component Acceptance Notice 5A GB4943.1-2011 Page 21 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 7. Function Description Overview The NSi826x is a Six-channel digital isolator based on a capacitive isolation barrier technique. The digital signal is modulated with RF carrier generated by the internal oscillator at the Transmitter side. Then it is transferred through the capacitive isolation barrier and demodulated at the Receiver side. The NSi826x devices are high reliability six-channel digital isolator. The NSi826x device is safety certified by UL1577 support 5kVrms insulation withstand voltages, while providing high electromagnetic immunity and low emissions at low power consumption. The data rate of the NSi826x is up to 150Mbps, and the common-mode transient immunity (CMTI) is up to 200kV/us. The NSi826x device provides digital channel direction configuration and the default output level configuration when the input power is lost. Wide supply voltage of the NSi826x device support to connect with most digital interface directly, easy to do the level shift. High system level EMC performance enhance reliability and stability of use. The NSi826x has a default output status when VDDIN is unready and VDDOUT is ready as shown in Table 7.1, which helps for diagnosis when power is missing at the transmitter side. The output B follows the same status with the input A after powering up. Table 7.1 Output status vs. power status Input VDD1 status VDD2 status Output Comment H Ready Ready H Normal operation. L Ready Ready L X Unready Ready L(NSi826xW0) H(NSi826xW1) X Ready Unready X The output follows the same status with the input after input side VDD is powered on. The output follows the same status with the input after output side VDD2 is powered on. Note: H=Logic high; L=Logic low; X=Logic low or logic high VDD1 is input side power; VDD2 is out side power. Copyright © 2023, NOVOSENSE Page 22 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 OOK Modulation NSi8266 is based on a capacitive isolation barrier technique and the digital signal is modulated with RF carrier generated by the internal oscillator at the transmitter side, as shown in Figure 7.1 to Figure 7.2, then it is transferred through the capacitive isolation barrier and demodulated at the receiver side. The modulation uses OOK modulation technique with key benefits of high noise immunity and low radiation EMI. Figure 7.1 Single Channel Function Block Diagram Figure 7.2 OOK Modulation Copyright © 2023, NOVOSENSE Page 23 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 8. Application Note Typical Application Circuit Figure 8.1 Typical PWM isolation circuit for IPM PCB Layout The NSi826x requires a 0.1 µF bypass capacitor between VDD1 and GND1, VDD2 and GND2. The capacitor should be placed as close as possible to the package. Figure 8.2 to Figure 8.3 show the recommended PCB layout, make sure the space under the chip should keep free from planes, traces, pads and via. To enhance the robustness of a design, the user may also include resistors (50–300 Ω) in series with the inputs and outputs if the system is excessively noisy. The series resistors also improve the system reliability such as latch-up immunity. The typical output impedance of an isolator driver channel is approximately 50 Ω, ±40%. When driving loads where transmission line effects will be a factor, output pins should be appropriately terminated with controlled impedance PCB traces. Figure 8.2 Recommended PCB Layout — Top Layer Copyright © 2023, NOVOSENSE Figure 8.3 Recommended PCB Layout — Bottom Layer Page 24 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 High Speed Performance Typical Supply Current Equations The typical supply current of NSi826x can be calculated using below equations. IDD1 and IDD2 are typical supply currents measured in mA, f is data rate measured in Mbps, CL is the capacitive load measured in pF NSi8260: IDD1 = 0.19 *a1+1.45*b1+0.82*c1. IDD2 = 1.36+ VDD2*f* CL *c1*10-9 When a1 is the channel number of default state input at side 1, b1 is the channel number of non-default state input at side 1, c1 is the channel number of switch signal input at side 1. NSi8261: IDD1 = 0.87 +1.26*b1+0.63*c1+ VDD1*f* CL *c2*10-9 IDD2 = 0.87 +1.26*b2+0.63*c2+ VDD2*f* CL *c1*10-9 When b1 is the channel number of non-default state input at side 1, c1 is the channel number of switch signal input at side 1, b2 is the channel number of non-default state input at side 2, c2 is the channel number of switch signal input at side 2. NSi8262: IDD1 = 0.87 +1.26*b1+0.63*c1+ VDD1*f* CL *c2*10-9 IDD2 = 0.87 +1.26*b2+0.63*c2+ VDD2*f* CL *c1*10-9 When b1 is the channel number of non-default state input at side 1, c1 is the channel number of switch signal input at side 1, b2 is the channel number of non-default state input at side 2, c2 is the channel number of switch signal input at side 2. NSi8263: IDD1 = 0.87 +1.26*b1+0.63*c1+ VDD1*f* CL *c2*10-9 IDD2 = 0.87 +1.26*b2+0.63*c2+ VDD2*f* CL *c1*10-9 When b1 is the channel number of non-default state input at side 1, c1 is the channel number of switch signal input at side 1, b2 is the channel number of non-default state input at side 2, c2 is the channel number of switch signal input at side 2. Copyright © 2023, NOVOSENSE Page 25 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 9. Package Information Figure 9.1 SOP16(300mil)/SOW16 Package Shape and Dimension in millimeters Figure 9.2 SOP16(300mil)/SOW16 Package Board Layout Example Copyright © 2023, NOVOSENSE Page 26 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 Figure 9.3 SSOP16 Package Shape and Dimension in millimeters Figure 9.4 SSOP16 Package Board Layout Example Copyright © 2023, NOVOSENSE Page 27 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 Figure 9.5 SOP16(150mil) Package Shape and Dimension in millimeters Figure 9.6 SOP16(150mil) Package Board Layout Example Copyright © 2023, NOVOSENSE Page 28 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 10. Order Information Part Number NSi8260W 0-DSWR NSi8260W 1-DSWR NSi8261W 0-DSWR NSi8261W 1-DSWR NSi8262W 0-DSWR NSi8262W 1-DSWR NSi8263W 0-DSWR NSi8263W 1-DSWR NSi8260S 0-DSSR NSi8260S 1-DSSR NSi8261S 0-DSSR NSi8261S 1-DSSR NSi8262S 0-DSSR NSi8262S 1-DSSR NSi8263S 0-DSSR NSi8263S 1-DSSR NSi8260N 0-DSPNR NSi8260N 1- DSPNR NSi8261N 0- DSPNR NSi8261N 1- DSPNR NSi8262N 0- DSPNR NSi8262N 1- DSPNR NSi8263N 0- DSPNR NSi8263N 1- DSPNR Isolatio n Rating (kV) 5 Number of side 1 inputs 6 Number of side 2 inputs 0 Max Data Rate (Mbps) 150 Default Output State Low Temperature MSL Package Type Package Drawing SPQ -55 to 125℃ 2 SOW16 1000 5 6 0 150 High -55 to 125℃ 2 SOW16 1000 5 5 1 150 Low -55 to 125℃ 2 SOW16 1000 5 5 1 150 High -55 to 125℃ 2 SOW16 1000 5 4 2 150 Low -55 to 125℃ 2 SOW16 1000 5 4 2 150 High -55 to 125℃ 2 SOW16 1000 5 3 3 150 Low -55 to 125℃ 2 SOW16 1000 5 3 3 150 High -55 to 125℃ 2 SOW16 1000 3 6 0 150 Low -55 to 125℃ 1 SOP16 (300mil) SOP16 (300mil) SOP16 (300mil) SOP16 (300mil) SOP16 (300mil) SOP16 (300mil) SOP16 (300mil) SOP16 (300mil) SSOP16 SSOP16 2500 3 6 0 150 High -55 to 125℃ 1 SSOP16 SSOP16 2500 3 5 1 150 Low -55 to 125℃ 1 SSOP16 SSOP16 2500 3 5 1 150 High -55 to 125℃ 1 SSOP16 SSOP16 2500 3 4 2 150 Low -55 to 125℃ 1 SSOP16 SSOP16 2500 3 4 2 150 High -55 to 125℃ 1 SSOP16 SSOP16 2500 3 3 3 150 Low -55 to 125℃ 1 SSOP16 SSOP16 2500 3 3 3 150 High -55 to 125℃ 1 SSOP16 SSOP16 2500 3 6 0 150 Low -55 to 125℃ 1 SOP16 2500 3 6 0 150 High -55 to 125℃ 1 SOP16 2500 3 5 1 150 Low -55 to 125℃ 1 SOP16 2500 3 5 1 150 High -55 to 125℃ 1 SOP16 2500 3 4 2 150 Low -55 to 125℃ 1 SOP16 2500 3 4 2 150 High -55 to 125℃ 1 SOP16 2500 3 3 3 150 Low -55 to 125℃ 1 SOP16 2500 3 3 3 150 High -55 to 125℃ 1 SOP16 (150mil) SOP16 (150mil) SOP16 (150mil) SOP16 (150mil) SOP16 (150mil) SOP16 (150mil) SOP16 (150mil) SOP16 (150mil) SOP16 2500 Copyright © 2023, NOVOSENSE Page 29 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 NOTE: All packages are RoHS-compliant with peak reflow temperatures of 260 °C according to the JEDEC industry standard classifications and peak solder temperatures. Part Number Rule: NSi(82)(6)(1)(W)(1)-DSWR Series Number 6=6Channels Reverse Channel Amount: N=N Channels N=0,1,2… Package Type: S= SSOP W= WB N=NB Package Type: SS=SSOP16 SW=SOP16(300mil) SPN=SOP16(150mil) D = Industrial Q1 = Auto Fail-Safe Output State: 0 = Logic Low 1 = Logic High 11. Documentation Support Part Number Product Folder Datasheet NSi826x tbd tbd Copyright © 2023, NOVOSENSE Technical Documents tbd Isolator selection guide tbd Page 30 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 12. Tape and Reel Information Figure 12.1 Reel Information (for all packages) Copyright © 2023, NOVOSENSE Page 31 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 Direction of Feed 1 2 3 4 Quadrant Designations Copyright © 2023, NOVOSENSE Figure 12.2 Tape Information of SOP16(300mil) Page 32 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 Direction of Feed 1 2 3 4 Quadrant Designations Copyright © 2023, NOVOSENSE Figure 12.3 Tape Information of SSOP16 Page 33 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 Direction of Feed 1 2 3 4 Quadrant Designations Copyright © 2023, NOVOSENSE Figure 12.4 Tape Information of SOP16(150mil) Page 34 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 13. Revision history Revision 1.0 1.1 1.2 1.3 1.4 1.5 1.6 Description Initial version Changed tape and reel information Updated Safety Regulatory Updated Safety-Limiting Values. Update SSOP16 Package Shape and Dimension in millimeters. Changed AEC-Q100 description. Update SOW16\SSOP16 Package Board Layout Example Update SSOP16 CTI and VDE file. Update SOP16 Package, Typical Supply Current Equations Copyright © 2023, NOVOSENSE Date 2020/11/13 2020/12/20 2021/6/28 2022/4/25 2022/6/6 2023/1/12 2023/3/22 Page 35 NSi8260/NSi8261/NSi8262/NSi8263 Datasheet (EN) 1.6 IMPORTANT NOTICE The information given in this document shall in no event be regarded as any warranty or authorization of, express or implied, including but not limited to accuracy, completeness, merchantability, fitness for a particular purpose or infringement of any third party’s intellectual property rights. You are solely responsible for your use of Novosense’ products and applications, and for the safety thereof. You shall comply with all laws, regulations and requirements related to Novosense’s products and applications, although information or support related to any application may still be provided by Novosense. The resources are intended only for skilled developers designing with Novosense’ products. Novosense reserves the rights to make corrections, modifications, enhancements, improvements or other changes to the products and services provided. Novosense authorizes you to use these resources exclusively for the development of relevant applications designed to integrate Novosense’s products. Using these resources for any other purpose, or any unauthorized reproduction or display of these resources is strictly prohibited. Novosense shall not be liable for any claims, damages, costs, losses or liabilities arising out of the use of these resources. For further information on applications, products and technologies, please contact Novosense (www.novosns.com ). Suzhou Novosense Microelectronics Co., Ltd Copyright © 2023, NOVOSENSE Page 36
NSi8260W1-DSWR 价格&库存
很抱歉,暂时无法提供与“NSi8260W1-DSWR”相匹配的价格&库存,您可以联系我们找货
