SDCHA1V8040-150-R
SDCHA1V8040-150-R
    EATON(伊顿)
    SMD,8x8mm
    15 µH 半屏蔽 电感器 3.6 A 50 毫欧 非标准
SDCHA1V8040-150-R 数据手册
Technical Data ELX1097 Effective December 2022 Supersedes September 2021 SDCHA1V80 Automotive grade semi-shielded power inductors Applications Product features • AEC-Q200 qualified • High current carrying capacity • High power density, low core losses • Magnetically semi-shielded • Inductance range from 1 μH to 100 μH • Current range from 1.2 A to 8.5 A • 8.3 mm x 8.3 mm surface mount package in a maximum 4.0 mm height • NiZn ferrite magnetic material • Moisture sensitivity level (MSL): 1 • LED lighting • Advanced driver assistance systems (ADAS) • Adaptive cruise control (ACC) • Collision avoidance • Infotainment and cluster electronics • Electronic control unit (ECU) Environmental compliance and general specifications • Storage temperature range (component): -55 °C to +125 °C • Operating temperature range: -55 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant HALOGEN Pb HF FREE SDCHA1V80 Automotive grade semi-shielded power inductors  Technical Data ELX1097 Effective December 2022 Product specifications Part number5 OCL1 (µH) Tolerance FLL2 (µH) minimum Irms3 (A) Isat4 (A) DCR (mΩ) ±20% @ +25 °C SRF (MHz) typical SDCHA1V8040-1R0-R 1.0 ±20% 0.56 8.5 13.8 8.2 85 SDCHA1V8040-1R5-R 1.5 ±20% 0.84 8.0 11.5 10 66 SDCHA1V8040-2R2-R 2.2 ±20% 1.23 7.4 9.8 11.5 57 SDCHA1V8040-3R3-R 3.3 ±20% 1.85 6.6 8.0 15 48 SDCHA1V8040-4R7-R 4.7 ±20% 2.63 5.8 6.7 19.5 38 SDCHA1V8040-5R6-R 5.6 ±20% 3.14 5.4 6.2 22 33 SDCHA1V8040-6R8-R 6.8 ±20% 3.81 5.1 5.6 25 29 SDCHA1V8040-100-R 10 ±20% 5.60 4.6 5.0 33 25 SDCHA1V8040-150-R 15 ±20% 8.40 3.6 4.0 50 20 SDCHA1V8040-220-R 22 ±20% 12.32 2.9 3.1 73 18 SDCHA1V8040-330-R 33 ±20% 18.48 2.3 2.6 100 15 SDCHA1V8040-470-R 47 ±20% 26.32 2.0 2.2 135 12 SDCHA1V8040-560-R 56 ±20% 31.36 1.75 1.9 160 10.5 SDCHA1V8040-680-R 68 ±20% 38.08 1.65 1.75 205 9.5 SDCHA1V8040-820-R 82 ±20% 45.92 1.4 1.6 230 8.5 SDCHA1V8040-101-R 100 ±20% 56 1.2 1.45 300 8.0 1. Open circuit inductance (OCL) test parameters: 100 kHz, 1.0 Vrms, 0.0 Adc, +25 °C 2. Full load inductance (FLL) test parameters: 100 kHz, 1.0 Vrms, Isat, +25 °C 3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. 2 www.eaton.com/electronics 4. Isat : Peak current for approximately 30% maximum rolloff @ +25 °C 5. Part number definition: SDCHA1V8040-xxx-R SDCHA1V8040 = Product code and size xxx= Inductance value in μH, R=decimal point, If no R is present last digit indicates number of zeros -R suffix = RoHS compliant 6. Rated operating voltage (across inductor) 20 V ref. SDCHA1V80 Automotive grade semi-shielded power inductors Technical Data ELX1097 Effective December 2022  Dimensions-mm 8040 xxx yyyy Recommended PCB Layout Dimension SDCHA1V8040-xxx-R A 8.0 ± 0.3 B 8.0 ± 0.3 C 3.7 ± 0.3 D 2.4 ± 0.3 E 6.3 ± 0.3 L 8.5 G 2.8 H 6.6 Schematic Part marking: 8040, xxx= inductance value in uH, R= decimal point. If no R is present then last character equals number of zeros, yyyy= lot code All soldering surfaces to be coplanar within 0.1 millimeters PCB layout reference only Recommend solder paste thickness at 0.15 mm and above Traces or vias underneath the inductor is not recommended www.eaton.com/electronics 3 Technical Data ELX1097 Effective December 2022 SDCHA1V80 Automotive grade semi-shielded power inductors  Packaging information- mm SDCHA1V8040 Supplied in tape and reel packaging, 1000 parts per 13” diameter reel (EIA-481 compliant) Drawing not to scale 4 www.eaton.com/electronics Dimension Value W 16.0 ± 0.3 F 7.5 ± 0.1 E 1.75 ± 0.1 P0 4.0 ± 0.1 P 12.0 ± 0.1 P2 2.0 ± 0.1 D 1.5 ± 0.1 A0 8.4 ± 0.1 B0 8.4 ± 0.1 K0 4.3 ± 0.1 T 0.4 ± 0.1 SDCHA1V80 Automotive grade semi-shielded power inductors Technical Data ELX1097 Effective December 2022  Inductance and temperature rise vs current SDCHA1V8040 www.eaton.com/electronics 5 Technical Data ELX1097 Effective December 2022 Inductance and temperature rise vs current 6 www.eaton.com/electronics SDCHA1V80 Automotive grade semi-shielded power inductors  SDCHA1V80 Automotive grade semi-shielded power inductors Technical Data ELX1097 Effective December 2022  Inductance and temperature rise vs current www.eaton.com/electronics 7 Technical Data ELX1097 Effective December 2022 Inductance and impedance vs. frequency curve 8 www.eaton.com/electronics SDCHA1V80 Automotive grade semi-shielded power inductors  SDCHA1V80 Automotive grade semi-shielded power inductors Technical Data ELX1097 Effective December 2022  Inductance and impedance vs. frequency curve www.eaton.com/electronics 9 Technical Data ELX1097 Effective December 2022 Inductance and impedance vs. frequency curve 10 www.eaton.com/electronics SDCHA1V80 Automotive grade semi-shielded power inductors  Technical Data ELX1097 SDCHA1V80 Automotive grade semi-shielded power inductors Effective December 2022  Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax Package thickness Volume mm3
SDCHA1V8040-150-R 价格&库存
很抱歉,暂时无法提供与“SDCHA1V8040-150-R”相匹配的价格&库存,您可以联系我们找货
SDCHA1V8040-150-R
  • 1000+2.305741000+0.29746
  • 2000+2.174092000+0.28048
  • 3000+2.100703000+0.27101
  • 5000+2.011805000+0.25954
  • 7000+1.955387000+0.25226
  • 10000+1.8973210000+0.24477
库存:2522
SDCHA1V8040-150-R
    • 1+0.70017
    • 200+0.27940
    • 500+0.27011
    • 1000+0.26547
    SDCHA1V8040-150-R
    • 1+4.160391+0.53673
    • 10+3.4138710+0.44042
    • 25+3.1554825+0.40709
    • 50+2.9734550+0.38360
    • 100+2.80372100+0.36171
    • 250+2.59352250+0.33459
    • 500+2.44548500+0.31549
    库存:2522
