Technical Data ELX1097
Effective December 2022
Supersedes September 2021
SDCHA1V80
Automotive grade semi-shielded power inductors
Applications
Product features
AEC-Q200 qualified
High current carrying capacity
High power density, low core losses
Magnetically semi-shielded
Inductance range from 1 μH to 100 μH
Current range from 1.2 A to 8.5 A
8.3 mm x 8.3 mm surface mount package in a
maximum 4.0 mm height
NiZn ferrite magnetic material
Moisture sensitivity level (MSL): 1
LED lighting
Advanced driver assistance systems (ADAS)
Adaptive cruise control (ACC)
Collision avoidance
Infotainment and cluster electronics
Electronic control unit (ECU)
Environmental compliance and general
specifications
Storage temperature range (component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
SDCHA1V80
Product specifications
Part number5
OCL1
(µH)
Tolerance
FLL2
(µH) minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ) ±20%
@ +25 °C
SRF (MHz)
typical
SDCHA1V8040-1R0-R
1.0
±20%
0.56
8.5
13.8
8.2
85
SDCHA1V8040-1R5-R
1.5
±20%
0.84
8.0
11.5
10
66
SDCHA1V8040-2R2-R
2.2
±20%
1.23
7.4
9.8
11.5
57
SDCHA1V8040-3R3-R
3.3
±20%
1.85
6.6
8.0
15
48
SDCHA1V8040-4R7-R
4.7
±20%
2.63
5.8
6.7
19.5
38
SDCHA1V8040-5R6-R
5.6
±20%
3.14
5.4
6.2
22
33
SDCHA1V8040-6R8-R
6.8
±20%
3.81
5.1
5.6
25
29
SDCHA1V8040-100-R
10
±20%
5.60
4.6
5.0
33
25
SDCHA1V8040-150-R
15
±20%
8.40
3.6
4.0
50
SDCHA1V8040-220-R
22
±20%
12.32
2.9
3.1
73
18
SDCHA1V8040-330-R
33
±20%
18.48
2.3
2.6
100
15
SDCHA1V8040-470-R
47
±20%
26.32
2.0
2.2
135
12
SDCHA1V8040-560-R
56
±20%
31.36
1.75
1.9
160
10.5
SDCHA1V8040-680-R
68
±20%
38.08
1.65
1.75
205
9.5
SDCHA1V8040-820-R
82
±20%
45.92
1.4
1.6
230
8.5
SDCHA1V8040-101-R
100
±20%
56
1.2
1.45
300
8.0
1. Open circuit inductance (OCL) test parameters: 100 kHz, 1.0 Vrms, 0.0 Adc, +25 °C
2. Full load inductance (FLL) test parameters: 100 kHz, 1.0 Vrms, Isat, +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
2
www.eaton.com/electronics
4. Isat : Peak current for approximately 30% maximum rolloff @ +25 °C
5. Part number definition: SDCHA1V8040-xxx-R
SDCHA1V8040 = Product code and size
xxx= Inductance value in μH, R=decimal point, If no R is present last digit indicates number of zeros
-R suffix = RoHS compliant
6. Rated operating voltage (across inductor) 20 V ref.
SDCHA1V80
Dimensions-mm
8040
xxx
yyyy
Recommended PCB Layout
Dimension
SDCHA1V8040-xxx-R
A
8.0 ± 0.3
B
8.0 ± 0.3
C
3.7 ± 0.3
D
2.4 ± 0.3
E
6.3 ± 0.3
L
8.5
G
2.8
H
6.6
Schematic
Part marking: 8040, xxx= inductance value in uH, R= decimal point. If no R is present then last character equals number of zeros, yyyy= lot code
All soldering surfaces to be coplanar within 0.1 millimeters
PCB layout reference only
Recommend solder paste thickness at 0.15 mm and above
Traces or vias underneath the inductor is not recommended
3
SDCHA1V80
Packaging information- mm
SDCHA1V8040
Supplied in tape and reel packaging, 1000 parts per 13” diameter reel (EIA-481 compliant)
Drawing not to scale
4
Dimension
Value
W
16.0 ± 0.3
F
7.5 ± 0.1
E
1.75 ± 0.1
P0
4.0 ± 0.1
P
12.0 ± 0.1
P2
2.0 ± 0.1
D
1.5 ± 0.1
A0
8.4 ± 0.1
B0
8.4 ± 0.1
K0
4.3 ± 0.1
T
0.4 ± 0.1
SDCHA1V80
Inductance and temperature rise vs current
SDCHA1V8040
5
6
SDCHA1V80
SDCHA1V80
7
Inductance and impedance vs. frequency curve
8
SDCHA1V80
SDCHA1V80
9
10
SDCHA1V80
SDCHA1V80
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“SDCHA1V8040-101-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.047711+0.52532
- 10+3.3297810+0.43215
- 25+3.0830825+0.40013
- 50+2.9069050+0.37727
- 100+2.74126100+0.35577
- 250+2.53545250+0.32906
- 国内价格 香港价格
- 750+1.45553750+0.18890
- 1500+1.372321500+0.17810
- 2250+1.325912250+0.17208
- 3750+1.269733750+0.16479
- 5250+1.234045250+0.16016
- 7500+1.197347500+0.15540
- 国内价格
- 1+0.73008
- 200+0.29128
- 500+0.28156
- 1000+0.27681
