MVR14D180K
MVR14D180K
    MERITEK
    Disc 14mm
    VARISTOR 18V 1KA 14MM DISC THRU
MVR14D180K 数据手册
Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series FEATURE  Operating / Storage Temperature: -40°C ~ +105°C / -40°C +125°C  Varistor Voltage: 18V to 1800V  Withstanding Surge Current Rating Up to 15KA  Various Lead Form and Spacing Options  UL/cUL Safety Approved: Certification No: E326004  VDE Safety Approved: Certification No: 40013638 PART NUMBERING SYSTEM MVR 14 D 911 K O (1) (2) (3) (4) (5) (6) No Item Digit (1) Meritek Series MVR (2) Diameter (3) Lead/Package Type (4) Voltage (5) Tolerance (6) Lead Type Description Series Reference Metal Oxide Varistor Leaded Type 14 14: ɸ14mm 5, 7, 10, 14, 20, 25 D D: Round Disk or Dual Square Disk S: Single Square, A: Bare 911: 910VDC 18V~1800V K K: ±10% -10% ~ +10% O O: Out kink Blank: Straight, Y: Y Kink, O:Out Kink, 911 ELECTRICAL CHARACTERISTICS AND DIMENSIONS REFERENCE TABLE Maximun Energy MVR Series Varistor DC Voltage @1mA (10/1Kµs) MVR05 18V~750V 0.4J~16.0J D H H1 L min L1 min d d1 ± 0.4 F 5.0~7.5 5.5~10.0 8.0~13.0 20.0 15.0 0.6±0.05 1.2 5.0±0.8 MVR07 18V~820V 0.9~33.0J 7.0~9.0 7.5~12.0 9.0~13.5 20.0 15.0 0.6±0.05 1.2 5.0±0.8 MVR10 18V~1.1kV 2.1~115.0J 10.0~12.5 10.5~16.0 13.0~17.5 20.0 15.0 0.8±0.05 1.4 7.5±0.8 MVR14 18V~1.8kV 4.0~213.0J 14.0~16.5 14.5~20.0 17.0~21.0 20.0 15.0 0.8±0.05 1.4 7.5±0.8 0.8±0.05 1.4 7.5±0.8 MVR20 18V~1.8kV 11.0J~383J 20.0~23.0 21.0~26.0 24.0~28.0 20.0 15.0 1.0±0.05 1.6 10.0±1.0 1.0 ±0.1 - 10.0±1.0 MVR25 18V~1.8kV 190J~770J 25.0~28.0 27.0~31.5 - 20.0 - 12.5±1.0 (Unit: mm) Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series ELECTRICAL CHARACTERISTICS – MVR05D SERIES MVR05D Series Varistor DC Voltage @1mA Max. Allowable Voltage Max. Clamping Voltage Back to Top Withstanding Surge Current Max. Energy (10/1Kµs) Rated Power Typical Cap. @1kHz (A) (J) (W) (pF) T max e ±0.8 Dimension VDC VAC VDC Vc IP (V) (Vrms) (V) (V) (A) MVR05D180K 18(15~21.6) 11 14 40 0.4 1,400 4.5 1.3 MVR05D220K 22(19.5~26) 14 18 48 0.5 1,150 4.6 1.4 MVR05D270K 27(24~31) 17 22 60 0.6 930 4.7 1.6 MVR05D330K 33(29.5~36.5) 20 26 73 760 4.9 1.5 0.8 1 100 0.01 MVR05D390K 39(35~43) 25 31 80 0.9 640 4.8 1.6 MVR05D470K 47(42~52) 30 38 104 1.1 530 4.9 1.7 MVR05D560K 56(50~62) 35 45 123 1.3 450 5.0 1.9 MVR05D680K 68(61~75) 40 56 145 1.6 370 5.2 2.2 MVR05D820K 82(74~90) 50 65 150 2.5 300 4.1 1.6 MVR05D101K 100(90~110) 60 85 177 3.0 250 4.3 1.8 MVR05D121K 120(108~132) 75 100 210 4.0 210 4.5 2.0 MVR05D151K 150(135~165) 95 125 260 4.1 165 4.8 1.6 MVR05D181K 180(162~198) 115 150 320 4.9 140 4.3 1.7 MVR05D201K 200(180~220) 130 170 355 6.5 125 4.4 1.8 MVR05D221K 220(198~242) 140 180 380 7.5 110 4.5 1.9 MVR05D241K 240(216~264) 150 200 415 8.0 100 4.6 2.0 MVR05D271K 270(243~297) 175 225 475 8.5 95 4.9 2.2 MVR05D301K 300(270~330) 190 250 520 85 5.0 2.3 9.0 5 400 0.10 MVR05D331K 330(297~363) 210 275 570 9.5 75 5.1 2.3 MVR05D361K 360(324~396) 230 300 620 10.0 70 5.2 2.5 MVR05D391K 390(351~429) 250 320 675 12.0 65 5.4 2.6 MVR05D431K 430(387~473) 275 350 745 13.0 60 5.7 2.8 MVR05D471K 470(423~517) 300 385 810 15.0 55 6.0 3.0 MVR05D511K 510(459~561) 320 415 845 16.0 50 6.2 3.2 MVR05D561K 560(504~616) 350 460 920 16.0 45 6.5 3.4 MVR05D621K 620(558~682) 385 505 1025 21.0 40 6.5 3.7 MVR05D681K 680(612~748) 420 560 1120 21.0 35 6.8 4.0 MVR05D751K 750(675~825) 460 615 1240 22.4 30 6.9 4.1 Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%. 2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) IR≤25μA (820K~751K) Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series SURGE CURRENT DERATING CURVES – MVR05D SERIES MVR05D180K ~ MVR05D680K Back to Top MVR05D820K ~ MVR05D751K LEAKAGE CURRENT & CLAMPING VOLTAGE CURVES – MVR05D SERIES Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series ELECTRICAL CHARACTERISTICS - MVR07D SERIES MVR07D Series Varistor DC Voltage @1mA Max. Allowable Voltage Max. Clamping Voltage Back to Top Withstanding Surge Current Max. Energy (10/1Kµs) Rated Power Typical Cap. @1kHz (A) (J) (W) (pF) T max e ±0.8 Dimension VDC VAC VDC Vc IP (V) (Vrms) (V) (V) (A) MVR07D180K 18(15~21.6) 11 14 36 0.9 2800 4.5 1.3 MVR07D220K 22(19.5~26) 14 18 43 1.1 2300 4.6 1.4 MVR07D270K 27(24~31) 17 22 53 1.4 1800 4.7 1.6 MVR07D330K 33(29.5~36.5) 20 26 65 1500 4.9 1.5 1.7 2.5 250 0.02 MVR07D390K 39(35~43) 25 31 77 2.1 1300 4.8 1.6 MVR07D470K 47(42~52) 30 38 93 2.5 1100 4.9 1.7 MVR07D560K 56(50~62) 35 45 110 3.1 890 5.0 1.9 MVR07D680K 68(61~75) 40 56 135 3.6 740 5.2 2.2 MVR07D820K 82(74~90) 50 65 135 5.0 600 4.1 1.6 MVR07D101K 100(90~110) 60 85 165 6.5 500 4.3 1.8 MVR07D121K 120(108~132) 75 100 200 7.8 420 4.5 2.0 MVR07D151K 150(135~165) 95 125 250 9.7 330 4.8 1.6 MVR07D181K 180(162~198) 115 150 300 11.7 280 4.3 1.7 MVR07D201K 200(180~220) 130 170 340 13.0 250 4.4 1.8 MVR07D221K 220(198~242) 140 180 360 14.0 230 4.5 1.9 MVR07D241K 240(216~264) 150 200 395 15.0 210 4.6 2.0 MVR07D271K 270(243~297) 175 225 455 18.0 185 4.9 2.2 MVR07D301K 300(270~330) 190 250 500 20.0 165 5.0 2.3 MVR07D331K 330(297~363) 210 275 550 150 5.1 2.3 23.0 10 1,200 0.25 MVR07D361K 360(324~396) 230 300 595 25.0 140 5.2 2.5 MVR07D391K 390(351~429) 250 320 650 25.0 130 5.4 2.6 MVR07D431K 430(387~473) 275 350 710 28.0 115 5.7 2.8 MVR07D471K 470(423~517) 300 385 775 30.0 105 6.0 3.0 MVR07D511K 510(459~561) 320 415 845 30.0 100 6.2 3.2 MVR07D561K 560(504~616) 350 460 925 30.0 90 6.5 3.4 MVR07D621K 620(558~682) 385 505 1025 33.0 80 7.1 3.7 MVR07D681K 680(612~748) 420 560 1120 33.0 75 7.3 4.0 MVR07D751K 750(675~825) 460 615 1240 67.2 70 7.0 4.1 MVR07D781K 780(702~858) 485 640 1290 67.2 70 7.2 4.2 MVR07D821K 820(738~902) 510 670 1355 67.2 60 7.5 4.4 Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%. 2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) IR≤25μA (820K~821K) Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series SURGE CURRENT DERATING CURVES – MVR07D SERIES MVR07D180K ~ MVR07D680K MVR07D820K ~ MVR07D471K Back to Top MVR07D511K~ MVR07D821K LEAKAGE CURRENT & CLAMPING VOLTAGE CURVES – MVR07D SERIES Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series ELECTRICAL CHARACTERISTICS - MVR10D SERIES MVR10D Series Varistor DC Voltage @1mA Max. Allowable Voltage Max. Clamping Voltage Back to Top Withstanding Surge Current Max. Energy (10/1Kµs) Rated Power Typical Cap. @1kHz (A) (J) (W) (pF) T max e ±0.8 Dimension VDC VAC VDC Vc IP (V) (Vrms) (V) (V) (A) MVR10D180K 18(15~21.6) 11 14 36 2.1 5600 4.6 1.5 MVR10D220K 22(19.5~26) 14 18 43 2.5 4500 4.7 1.6 MVR10D270K 27(24~31) 17 22 53 3.0 3700 4.8 1.8 MVR10D330K 33(29.5~36.5) 20 26 65 3000 5.0 1.7 4.0 5 500 0.05 MVR10D390K 39(35~43) 25 31 77 4.6 2400 5.3 1.8 MVR10D470K 47(42~52) 30 38 93 5.5 2100 5.4 1.9 MVR10D560K 56(50~62) 35 45 110 7.0 1800 5.5 2.1 MVR10D680K 68(61~75) 40 56 135 8.2 1500 5.6 2.4 MVR10D820K 82(74~90) 50 65 135 12.0 1200 4.7 1.8 MVR10D101K 100(90~110) 60 85 165 15.0 1000 4.9 2.0 MVR10D121K 120(108~132) 75 100 200 18.0 830 5.1 2.2 MVR10D151K 150(135~165) 95 125 250 22.0 670 5.4 1.8 MVR10D181K 180(162~198) 115 150 300 27.0 560 4.8 1.9 MVR10D201K 200(180~220) 130 170 340 30.0 500 5.0 2.0 MVR10D221K 220(198~242) 140 180 360 32.0 450 5.1 2.1 MVR10D241K 240(216~264) 150 200 395 35.0 420 5.2 2.2 MVR10D271K 270(243~297) 175 225 455 40.0 370 5.4 2.4 MVR10D301K 300(270~330) 190 250 500 40.0 330 5.5 2.5 MVR10D331K 330(297~363) 210 275 550 43.0 300 5.8 2.5 MVR10D361K 360(324~396) 230 300 595 47.0 280 6.0 2.7 MVR10D391K 390(351~429) 250 320 650 260 6.2 2.8 MVR10D431K 430(387~473) 275 350 710 65.0 230 6.5 3.0 MVR10D471K 470(423~517) 300 385 775 67.0 210 6.7 3.2 MVR10D511K 510(459~561) 320 415 845 69.0 200 6.8 3.4 MVR10D561K 560(504~616) 350 460 925 70.0 180 7.0 3.6 MVR10D621K 620(558~682) 385 505 1025 72.0 160 7.3 3.9 MVR10D681K 680(612~748) 420 560 1120 75.0 150 7.6 4.2 MVR10D751K 750(675~825) 460 615 1240 77.0 130 8.0 4.3 MVR10D781K 780(702~858) 485 640 1290 80.0 130 8.1 4.4 MVR10D821K 820(738~902) 510 670 1355 85.0 120 8.3 4.6 MVR10D911K 910(819~1001) 550 745 1500 93.0 110 8.8 5.0 MVR10D102K 1000(900~1100) 625 825 1650 102.0 100 9.3 5.0 MVR10D112K 1100(990~1210) 680 895 1815 115.0 90 9.9 5.4 25 2,500 60.0 0.4 Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%. 2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) IR≤25μA (820K~112K) Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series SURGE CURRENT DERATING CURVES – MVR10D SERIES MVR10D180K ~ MVR10D680K MVR10D820K ~ MVR10D751K Back to Top MVR10D781K ~ MVR10D112K LEAKAGE CURRENT & CLAMPING VOLTAGE CURVES – MVR10D SERIES Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series ELECTRICAL CHARACTERISTICS - MVR14D SERIES MVR14D Series Varistor DC Voltage @1mA Max. Allowable Voltage Max. Clamping Voltage Back to Top Withstanding Surge Current Max. Energy (10/1Kµs) Rated Power Typical Cap. @1kHz (A) (J) (W) (pF) T max e ±0.8 Dimension VDC VAC VDC Vc IP (V) (Vrms) (V) (V) (A) MVR14D180K 18(15~21.6) 11 14 36 4.0 11100 3.9 1.5 MVR14D220K 22(19.5~26) 14 18 43 5.0 9100 4.0 1.6 MVR14D270K 27(24~31) 17 22 53 6.0 7400 4.1 1.8 MVR14D330K 33(29.5~36.5) 20 26 65 6100 4.3 1.7 MVR14D390K 39(35~43) 25 31 77 5100 4.1 1.8 MVR14D470K 47(42~52) 30 38 93 10.0 4300 4.3 19 MVR14D560K 56(50~62) 35 45 110 11.0 3600 4.6 2.1 MVR14D680K 68(61~75) 40 56 135 14.0 2900 4.8 2.4 MVR14D820K 82(74~90) 50 65 135 22.0 2400 4.1 1.8 MVR14D101K 100(90~110) 60 85 165 28.0 2000 4.2 2.0 MVR14D121K 120(108~132) 75 100 200 32.0 1700 4.4 2.2 MVR14D151K 150(135~165) 95 125 250 40.0 1300 4.1 1.8 MVR14D181K 180(162~198) 115 150 300 50.0 1100 4.2 1.9 MVR14D201K 200(180~220) 130 170 340 57.0 1000 4.3 2.0 MVR14D221K 220(198~242) 140 180 360 60.0 900 4.4 2.1 MVR14D241K 240(216~264) 150 200 395 63.0 830 4.5 2.2 MVR14D271K 270(243~297) 175 225 455 70.0 740 4.6 2.4 MVR14D301K 300(270~330) 190 250 500 77.0 670 4.6 2.5 MVR14D331K 330(297~363) 210 275 550 85.0 610 5.0 2.5 MVR14D361K 360(324~396) 230 300 595 93.0 560 5.2 2.7 MVR14D391K 390(351~429) 250 320 650 100 510 5.4 2.8 MVR14D431K 430(387~473) 275 350 710 460 5.6 3.0 MVR14D471k 470(423~517) 300 385 775 430 5.8 3.2 10 1,000 7.5 8.6 0.1 115 50 4,500 125 0.6 MVR14D511K 510(459~561) 320 415 845 125 390 6.1 3.4 MVR14D561K 560(504~616) 350 460 925 125 360 6.4 3.6 MVR14D621K 620(558~682) 385 505 1025 125 320 6.8 3.9 MVR14D681K 680(621~748) 420 560 1120 130 290 7.1 4.2 MVR14D751K 750(675~825) 460 615 1240 143 270 7.2 4.3 MVR14D781K 780(702~858) 485 640 1290 148 260 7.3 4.4 MVR14D821K 820(738~902) 510 670 1355 157 240 7.5 4.6 MVR14D911K 910(819~1001) 550 745 1500 175 220 7.5 5.0 MVR14D102K 1000(900~1100) 625 825 1650 190 200 8.0 5.0 MVR14D112K 1100(990~1210) 680 895 1815 213 180 8.5 5.4 MVR14D122K 1200(1080~1320) 750 990 1980 232 160 9.0 5.8 MVR14D142K 1400(1260~1540) 880 1140 2310 238 150 10.5 6.6 MVR14D162K 1600(1440~1760) 1000 1280 2640 243 140 11.0 7.4 MVR14D182K 1800(1620~1980) 1100 1465 2970 250 130 12.0 8.2 Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%. 2. Varistor voltage≥1200V, structure diagram is F type. 3. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) ; IR≤25μA (820K~182K) Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series SURGE CURRENT DERATING CURVES - MVR14D SERIES MVR14D180K ~ MVR14D680K MVR14D820K ~ MVR14D751K Back to Top MVR14D781K ~ MVR14D182K LEAKAGE CURRENT & CLAMPING VOLTAGE CURVES – MVR14D SERIES Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series ELECTRICAL CHARACTERISTICS - MVR20D SERIES MVR20D Series Varistor DC Voltage @1mA Max. Allowable Voltage Max. Clamping Voltage Back to Top Withstanding Surge Current Max. Energy (10/1Kµs) Rated Power Typical Cap. @1kHz (A) (J) (W) (pF) T max e ±0.8 Dimension VDC VAC VDC Vc IP (V) (Vrms) (V) (V) (A) MVR20D180K 18(15~21.6) 11 14 36 11 28500 4.3 1.7 MVR20D220K 22(19.5~26) 14 18 43 14 18500 4.4 1.8 MVR20D270K 27(24~31) 17 22 53 16 13000 4.6 2.0 MVR20D330K 33(29.5~36.5) 20 26 65 11500 4.8 1.9 MVR20D390K 39(35~43) 25 31 77 8500 4.5 2.0 MVR20D470K 47(42~52) 30 38 93 30 7400 4.7 2.1 MVR20D560K 56(50~62) 35 45 110 41 6500 5.0 2.3 MVR20D680K 68(61~75) 40 56 135 46 5800 5.3 2.6 MVR20D820K 82(74~90) 50 65 135 38 4900 4.5 2.0 MVR20D101K 100(90~110) 60 85 165 45 4000 4.6 2.2 MVR20D121K 120(108~132) 75 100 200 55 3300 4.8 2.4 MVR20D151K 150(135~165) 95 125 250 70 2700 4.5 2.0 MVR20D181K 180(162~198) 115 150 300 85 2200 4.6 2.1 MVR20D201K 200(180~220) 130 170 340 95 2000 4.7 2.2 MVR20D221K 220(198~242) 140 180 360 100 1800 4.8 2.3 MVR20D241K 240(216~264) 150 200 395 108 1650 4.9 2.4 MVR20D271K 270(243~297) 175 225 455 127 1500 5.0 2.6 MVR20D301K 300(270~330) 190 250 500 136 1300 5.0 2.7 MVR20D331K 330(297~363) 210 275 550 150 1200 5.2 2.7 MVR20D361K 360(324~396) 230 300 595 163 1100 5.4 2.9 MVR20D391K 390(351~429) 250 320 650 180 1000 5.5 3.0 MVR20D431K 430(387~473) 275 350 710 930 5.7 3.2 MVR20D471k 470(423~517) 300 385 775 850 6.0 3.4 20 2,000 23 26 0.2 190 100 6,500 220 1.0 MVR20D511K 510(459~561) 320 415 845 220 780 6.2 3.6 MVR20D561K 560(504~616) 350 460 925 220 710 6.5 3.8 MVR20D621K 620(558~682) 385 505 1025 220 650 6.8 4.1 MVR20D681K 680(612~748) 420 560 1120 230 600 7.1 4.4 MVR20D751K 750(675~825) 460 615 1240 255 530 7.5 4.5 MVR20D781K 780(702~858) 485 640 1290 265 510 7.7 4.6 MVR20D821K 820(738~902) 510 670 1355 282 500 7.9 4.8 MVR20D911K 910(819~1001) 550 745 1500 310 440 8.1 5.2 MVR20D102K 1000(900~1100) 625 825 1650 342 400 8.6 5.2 MVR20D112K 1100(990~1210) 680 895 1815 383 360 9.1 5.6 MVR20D122K 1200(1080~1320) 750 990 1980 408 350 9.7 6.0 MVR20D142K 1400(1260~1540) 880 1140 2310 532 340 11.2 6.8 MVR20D162K 1600(1440~1760) 1000 1280 2640 606 330 11.8 7.6 MVR20D182K 1800(1620~1980) 1100 1465 2970 625 320 12.8 8.4 Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%. 2. Varistor voltage≥1200V, structure diagram is F type. 3. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) ; IR≤25μA (820K~182K) Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series SURGE CURRENT DERATING CURVES - MVR20D SERIES MVR20D180K ~ MVR20D680K MVR20D820K ~ MVR20D751K Back to Top MVR20D781K~ MVR20D182K LEAKAGE CURRENT & CLAMPING VOLTAGE CURVES - MVR20D SERIES Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series ELECTRICAL CHARACTERISTICS - MVR25D SERIES MVR25D Series Varistor DC Voltage @1mA Max. Allowable Voltage Max. Clamping Voltage VDC VAC VDC Vc IP (V) (Vrms) (V) (V) (A) Back to Top Withstanding Surge Current Max. Energy (10/1Kµs) Rated Power Typical Cap. @1kHz (A) (J) (W) (pF) T max e ±0.8 Dimension MVR25D180K 18(15~21.6) 11 14 36 20 45000 4.8 1.7 MVR25D220K 22(19.5~26) 14 18 43 25 29000 4.9 1.8 MVR25D270K 27(24~31) 17 22 53 30 26500 5.0 2.0 MVR25D330K 33(29.5~36.5) 20 26 65 18000 5.2 1.9 MVR25D390K 39(35~43) 25 31 77 13500 5.5 2.0 MVR25D470K 47(42~52) 30 38 93 50 11500 5.1 2.1 MVR25D560K 56(50~62) 35 45 110 60 10500 5.4 2.3 MVR25D680K 68(61~75) 40 56 135 70 9050 5.7 2.6 MVR25D820K 82(74~90) 50 65 135 80 7700 4.5 2.0 MVR25D101K 100(90~110) 60 85 165 100 6300 4.6 2.2 MVR25D121K 120(108~132) 75 100 200 120 5200 4.8 2.4 MVR25D151K 150(135~165) 95 125 250 160 4300 4.9 2.0 MVR25D181K 180(162~198) 115 150 300 175 3500 5.2 2.1 MVR25D201K 200(180~220) 130 170 340 190 3200 5.2 2.2 MVR25D221K 220(198~242) 140 180 360 200 2900 5.3 2.3 MVR25D241K 240(216~264) 150 200 395 220 2650 5.8 2.4 MVR25D271K 270(243~297) 175 225 455 255 2400 5.3 2.6 MVR25D301K 300(270~330) 190 250 500 275 2100 5.5 2.7 MVR25D331K 330(297~363) 210 275 550 300 1900 5.7 2.7 MVR25D361K 360(324~396) 230 300 595 330 1750 5.9 2.9 MVR25D391K 390(351~429) 250 320 650 360 1600 6.1 3.0 MVR25D431K 430(387~473) 275 350 710 380 1500 6.4 3.2 MVR25D471k 470(423~517) 300 385 775 1400 6.7 3.4 30 150 4,500 15,000 35 40 400 0.25 1.2 MVR25D511K 510(459~561) 320 415 845 420 1250 7.0 3.6 MVR25D561K 560(504~616) 350 460 925 440 1150 7.3 3.8 MVR25D621K 620(558~682) 385 505 1025 450 1050 7.6 4.1 MVR25D681K 680(612~748) 420 560 1120 460 950 7.8 4.4 MVR25D751K 750(675~825) 460 615 1240 510 850 8.0 4.5 MVR25D781K 780(702~858) 485 640 1290 530 850 8.1 4.6 MVR25D821K 820(738~902) 510 670 1355 570 800 8.4 4.8 MVR25D911K 910(819~1001) 550 745 1500 620 700 8.9 5.2 MVR25D102K 1000(900~1100) 625 825 1650 685 650 9.5 5.2 MVR25D112K 1100(990~1210) 680 895 1815 720 600 10.1 5.6 MVR25D122K 1200(1080~1320) 750 990 1980 792 550 10.7 6.0 MVR25D142K 1400(1260~1540) 880 1140 2310 850 500 12.6 6.8 MVR25D162K 1600(1440~1760) 1000 1280 2640 970 450 13.2 7.6 MVR25D182K 1800(1620~1980) 1100 1465 2970 1092 400 14.5 8.4 Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%. 2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K) ; IR≤40μA (820K~182K) Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series SURGE CURRENT DERATING CURVES – MVR25D SERIES MVR25D180K ~ MVR25D680K MVR25D820K ~ MVR25D751K Back to Top MVR25D781K ~ MVR25D182K LEAKAGE CURRENT & CLAMPING VOLTAGE CURVES - MVR25D SERIES Meritek Electronics Corporation | www.meritekusa.com Rev. 8b 04/12/18 Metal Oxide Varistor Leaded Disk Type, 5~25mm MVR Series RELIABILITY TEST CONDITIONS AND REQUIREMENTS Item Test Conditions / Method Back To Top Specifications Gradually apply the specified force and keep the unit fixed for 10±1s. Tensile Strength of Terminals Terminal diameter (mm) 0.5
MVR14D180K 价格&库存
很抱歉,暂时无法提供与“MVR14D180K”相匹配的价格&库存,您可以联系我们找货
