PAT3060H-C-5DB-T1
PAT3060H-C-5DB-T1
    SUSUMU
    SMD-2
    HIGH POWER CHIP ATTENUATOR, 5DB,
PAT3060H-C-5DB-T1 数据手册
High Precision Chip Attenuators ■PAT Series W type Features ・ Single attenuating element realizes excellent attenuating characteristics ・ Wide frequency range makes it possible to handle circuits with different frequency with ease ・ The distribution of the terminals, signal terminals in the middle and ground terminal at ends, are designed for easy integration to coaxial connectors Applications ・ Attenuator for coaxial lines/circuit ・ Attenuator for measuring instrumentation ◆Part numbering system PAT 3042 - C - 3dB - A - T1 Series code Packing quantity: T=Tape (T1/T2), B=Bulk Size :PAT3042,PAT4556,PAT3060H Attenuation tolerance(PAT3042/4556) Impedance: C=50Ω Attenuation ◆Electrical Specification PAT3042 Type PAT s eries W t y p e High frequency surface mount components Attenuation 0-10 (1dB step), 0-10(1dB step), 16,20dB 13,16,20dB Refer table1 Attenuation tolerance 50Ω (C) Impedance VSWR PAT4556 1,2,3,5,6,10dB Attenuuation* Rank DC∼ 2GHz 2 ∼ 5GHz 5 ∼ 10GHz 0~10dB A ±0.1dB ±0.2dB ±0.4dB 0~10dB B ±0.2dB ±0.3dB ±0.5dB B ±0.2dB ±0.3dB ±0.5dB ±0.5dB 50Ω (C) <1.1(DC-2GHz) <1.2(2-5GHz), <1.3(5-10GHz) 50Ω (C)
PAT3060H-C-5DB-T1 价格&库存
很抱歉,暂时无法提供与“PAT3060H-C-5DB-T1”相匹配的价格&库存,您可以联系我们找货
PAT3060H-C-5DB-T1
  • 1+47.489521+6.15156
  • 10+41.1159510+5.32596
  • 25+38.8920925+5.03789
  • 100+35.83521100+4.64192
  • 250+34.00463250+4.40479
  • 500+32.71164500+4.23731
库存:253
PAT3060H-C-5DB-T1
  • 1000+31.493591000+4.07952
  • 2000+30.346302000+3.93091
库存:253
