MPIA4020V2-6R8-R
MPIA4020V2-6R8-R
    EATON(伊顿)
    SMD,4.4x4.2mm
    6.8 µH 屏蔽 模制 电感器 2 A 192 毫欧最大 2-SMD,J 形引线
MPIA4020V2-6R8-R 数据手册
Technical Data 10652 Effective April 2017 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Applications • • Product features • AEC-Q200 Grade 3 qualified • High current carrying capacity • Magnetically shielded, Low EMI • Rugged flexible construction • Self resonant frequency (SRF) greater than 9.5 MHz • Inductance range from 0.1 μH to 22 μH • Current range from 1.2 A to 22 A • 4.75 mm x 4.45 mm footprint surface mount package in 1.2 mm, 1.5 mm, and 2.0 mm heights • • Moisture Sensitivity Level (MSL): 1 • Body electronics • Central body control module • Vehicle access control system • Headlamps, tail lamps and interior lighting • Doors, window lift and seat control Advanced driver assistance systems • 77 GHz radar system • Basic and smart surround, and rear and front view camera • Adaptive cruise control (ACC) • Automatic parking control • Car black box system Infotainment and cluster electronics • Active noise cancellation (ANC) • Audio subsystem: head unit and trunk amp • Digital instrument cluster • In-vehicle infotainment (IVI) and navigation Chassis and safety electronics • Airbag control unit Environmental data • Storage temperature range (Component): -55 °C to +125 °C • Operating temperature range: -55 °C to +125 °C (ambient plus self-temperature rise) • Solder reflow temperature: J-STD-020 (latest revision) compliant • Halogen free, lead free, RoHS compliant HALOGEN Pb HF FREE Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Product specifications OCL1 (μH) ±20% Part marking designator Irms2 (A) Isat3 (A) DCR (mΩ) typical @ +20 °C DCR (mΩ) maximum @ +20 °C SRF (MHz) typical K-factor4 MPIA4012V2-R33-R 0.33 A 7.5 11 11 13.5 128 2480 MPIA4012V2-R47-R 0.47 B 5.6 6.8 19 23 106 2470 MPIA4012V2-R68-R 0.68 C 4.5 6.7 28 33.5 98 2223 MPIA4012V2-1R0-R 1.0 D 4.3 6.5 38.5 46.5 64 1477 MPIA4012V2-1R5-R 1.5 E 3.3 4.3 55 66 63 1264 MPIA4012V2-2R2-R 2.2 F 2.9 4.2 75 90 35 1143 MPIA4012V2-4R7-R 4.7 G 1.8 2.8 175 210 29 890 MPIA4015V2-R22-R 0.22 A 10.5 14 6.0 7.5 153 2649 MPIA4015V2-R33-R 0.33 B 9.5 11 7.0 8.5 120 2158 MPIA4015V2-R47-R 0.47 C 7.8 9.0 11 14 98 1991 MPIA4015V2-R56-R 0.56 D 7.5 8.3 12 14 84 1942 MPIA4015V2-R68-R 0.68 E 6.8 8.0 16 19 81 1437 MPIA4015V2-1R0-R 1.0 F 5.5 6.0 23 27 56 1382 MPIA4015V2-1R5-R 1.5 G 4.2 4.6 48 58 48 1468 MPIA4015V2-2R2-R 2.2 H 2.9 4.5 65 78 42 920 MPIA4015V2-3R3-R 3.3 I 3.0 3.2 77 92 31 854 MPIA4015V2-4R7-R 4.7 J 2.2 3.0 108 130 22 791 MPIA4015V2-6R8-R 6.8 K 2.0 2.3 172 207 21 609 MPIA4015V2-100-R 10 L 1.8 2.1 245 294 14 766 MPIA4020V2-R10-R 0.10 A 16 22 3.5 4.5 343 2692 MPIA4020V2-R22-R 0.22 B 13 17 5.5 6.6 165 2036 MPIA4020V2-R33-R 0.33 C 9.5 12 7.5 9.0 113 1268 MPIA4020V2-R47-R 0.47 D 8.5 11 10.5 13 95 1219 MPIA4020V2-R56-R 0.56 E 8.0 10 12 15 87 1205 MPIA4020V2-R68-R 0.68 F 7.5 9.0 12.5 16 80 1201 MPIA4020V2-1R0-R 1.0 G 6.5 7.0 20 24 65 1168 MPIA4020V2-1R2-R 1.2 H 6.5 6.8 23 28 52 1110 MPIA4020V2-1R5-R 1.5 I 5.0 6.0 25 30 45 1038 MPIA4020V2-2R2-R 2.2 J 3.8 5.5 40 48 33 711 MPIA4020V2-3R3-R 3.3 K 3.3 4.0 71 85 25 643 MPIA4020V2-4R7-R 4.7 L 2.7 3.2 98 118 24 453 MPIA4020V2-6R8-R 6.8 M 2.0 2.6 167 192 23 482 MPIA4020V2-100-R 10 N 1.7 2.2 245 281 17 307 MPIA4020V2-150-R 15 O 1.5 1.8 320 384 13 257 MPIA4020V2-220-R 22 P 1.2 1.65 350 402 9.5 215 Part Number 5 1.2 mm height 1.5 mm height 2.0 mm height 1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 1.0 Vrms, 0.0 Adc, +25 °C. 2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating conditions verified in the end application. 3. Isat : Peak current for approximately 30% rolloff @ +25 °C. 2 www.eaton.com/electronics 4. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p :(Gauss), K: (K-factor from table), L: (Inductance in uH), ΔI (Peak to peak ripple current in Amps). 5. Part Number Definition: MPIA40xxV2-xxx-R MPIA40 = Product code xx= Height indicator V2=Version indicator xxx= inductance value in μH, R= decimal point, If no R is present then last character equals number of zeros -R suffix = RoHS compliant MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Technical Data 10652 Effective April 2017 Dimensions (mm) Dimension A MPIA4012V2 1.00 ±0.20 MPIA4015V2 1.30 ±0.20 MPIA4020V2 1.80 ±0.20 Part marking: 2xx (2 = version, x = inductance value per “Part marking designator” listed in Product specification table, x = bi-weekly date code) All soldering surfaces to be coplanar within 0.10 millimeters Tolerances are ±0.3 millimeters unless stated otherwise Pad layout tolerances are ±0.1 millimeters unless stated otherwise Do not route traces or vias underneath the inductor Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging , 3000 parts per 13” diameter reel KO MPIA4012V2 1.4 MPIA4015V2 1.8 MPIA4020V2 2.5 www.eaton.com/electronics 3 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Core loss vs Bp-p MPIA4012V2-R33-R 100 MPIA4012V2-R47-R 100 500 kHz 300 kHz 10 500 kHz 300 kHz 10 1 Core Loss (mW) Core Loss (mW) 100 kHz 50 kHz 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 3.0 MHz 0.1 2.0 MHz 1.0 MHz 700 kHz 10 100 1000 10000 0.001 Bp-p (Gauss) MPIA4012V2-R68-R 100 10 500 kHz 300 kHz 1 50 kHz 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 10 100 1000 100 kHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.001 10000 10 100 Core Loss (mW) 100 kHz 25 kHz 3.5 MHz 3.0 MHz 0.1 500 kHz 300 kHz 10 50 kHz 1 2.0 MHz 10000 MPIA4012V2-2R2-R 100 500 kHz 300 kHz 10 1000 Bp-p (Gauss) MPIA4012V2-1R5-R 100 Core Loss (mW) 10000 500 kHz 300 kHz Bp-p (Gauss) 100 kHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 0.1 2.0 MHz 1.0 MHz 700 kHz 1.0 MHz 700 kHz 0.01 0.01 10 100 1000 Bp-p (Gauss) 4 1000 0.01 0.01 0.001 Bp-p (Gauss) MPIA4012V2-1R0-R 1.0 MHz 700 kHz 0.001 100 10 100 kHz 0.1 10 100 Core Loss (mW) Core Loss (mW) 25 kHz 3.5 MHz 0.01 0.01 0.001 100 kHz 50 kHz 1 www.eaton.com/electronics 10000 0.001 10 100 1000 Bp-p (Gauss) 10000 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Core loss vs Bp-p MPIA4012V2-4R7-R 100 500 kHz 300 kHz 100 kHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 0.1 500 kHz 300 kHz 10 Core Loss (mW) Core Loss (mW) 10 MPIA4015V2-R22-R 100 2.0 MHz 100 kHz 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 1.0 MHz 700 kHz 0.01 0.01 0.001 0.001 10 100 Bp-p (Gauss) 1000 10000 MPIA4015V2-R33-R 100 10 100 Bp-p (Gauss) 1000 MPIA4015V2-R47-R 100 500 kHz 300 kHz 10 500 kHz 300 kHz 10 1 Core Loss (mW) Core Loss (mW) 100 kHz 50 kHz 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.001 100 kHz 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 10 100 Bp-p (Gauss) 1000 0.001 10000 MPIA4015V2-R56-R 100 10 100 Bp-p (Gauss) MPIA4015V2-R68-R 100 500 kHz 300 kHz 10 100 kHz Core Loss (mW) 100 kHz Core Loss (mW) 10000 1000 500 kHz 300 kHz 10 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.001 10000 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 10 100 1000 Bp-p (Gauss) 10000 0.001 10 100 Bp-p (Gauss) 1000 www.eaton.com/electronics 10000 5 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Core loss vs Bp-p MPIA4015V2-1R0-R 100 500 kHz Core Loss (mW) Core Loss (mW) 300 kHz 100 kHz 100 kHz 50 kHz 1 500 kHz 10 300 kHz 10 25 kHz 3.5 MHz 3.0 MHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 0.1 2.0 MHz 1.0 MHz 700 kHz 2.0 MHz 0.1 0.01 1.0 MHz 700 kHz 0.01 MPIA4015V2-1R5-R 100 10 100 Bp-p (Gauss) 1000 10000 0.001 MPIA4015V2-2R2-R 100 10 100 Bp-p (Gauss) 1000 MPIA4015V2-3R3-R 100 500 kHz 100 kHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 100 kHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 0.1 2.0 MHz 1.0 MHz 700 kHz 0.01 0.001 300 kHz 10 Core Loss (mW) Core Loss (mW) 500 kHz 300 kHz 10 0.01 10 100 Bp-p (Gauss) 1000 10000 0.001 10 MPIA4015V2-4R7-R 100 100 Bp-p (Gauss) 1000 500 kHz 100 kHz 50 kHz 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 100 kHz 50 kHz 1 0.01 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 1.0 MHz 700 kHz 0.01 10 100 1000 Bp-p (Gauss) 6 300 kHz 10 Core Loss (mW) Core Loss (mW) 500 kHz 300 kHz 1 10000 MPIA4015V2-6R8-R 100 10 0.001 10000 www.eaton.com/electronics 10000 0.001 10 100 1000 Bp-p (Gauss) 10000 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Core loss vs Bp-p MPIA4015V2-100-R MPIA4020V2-R10-R 100 100 500 kHz 300 kHz 500 kHz 10 50 kHz Core Loss (mW) Core Loss (mW) 100 kHz 50 kHz 1 25 kHz 3.5 MHz 3.0 MHz 0.1 2.0 MHz 1.0 MHz 700 kHz 100 Bp-p (Gauss) 1000 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 10000 100 kHz Core Loss (mW) 25 kHz 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 1000 100 kHz 50 kHz 25 kHz 3.5 MHz 1 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 0.01 0.01 0.001 10 100 Bp-p (Gauss) 1000 10000 MPIA4020V2-R47-R 100 10 100 Bp-p (Gauss) 1000 100 kHz 500 kHz 300 kHz 50 kHz 25 kHz 1 3.5 MHz 0.1 1.0 MHz 700 kHz 100 kHz 10 Core Loss (mW) Core Loss (mW) 10 3.0 MHz 2.0 MHz 0.01 10000 MPIA4020V2-R56-R 100 500 kHz 300 kHz 0.001 10000 500 kHz 300 kHz 10 50 kHz 3.5 MHz 100 MPIA4020V2-R33-R 100 500 kHz 300 kHz 1 10 Bp-p (Gauss) MPIA4020V2-R22-R 10 Core Loss (mW) 1 0.001 10 100 0.001 25 kHz 3.5 MHz 0.01 0.01 0.001 100 kHz 10 300 kHz 50 kHz 25 kHz 1 3.5 MHz 0.1 1.0 MHz 700 kHz 3.0 MHz 2.0 MHz 0.01 10 100 Bp-p (Gauss) 1000 10000 0.001 10 100 Bp-p (Gauss) 1000 www.eaton.com/electronics 10000 7 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Core loss vs Bp-p MPIA4020V2-R68-R 100 500 kHz 300 kHz 100 kHz 10 MPIA4020V2-1R0-R 100 500 kHz 300 kHz 10 100 kHz 25 kHz 3.5 MHz 1 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 50 kHz Core Loss (mW) Core Loss (mW) 50 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.01 0.001 0.001 25 kHz 1 10 100 Bp-p (Gauss) 1000 100 1000 MPIA4020V2-1R5-R 100 500 kHz 300 kHz 500 kHz 300 kHz 10 100 kHz 50 kHz Core Loss (mW) Core Loss (mW) 10 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 100 kHz 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.01 0.001 10 100 Bp-p (Gauss) 1000 0.001 10000 MPIA4020V2-2R2-R 100 10 100 Bp-p (Gauss) 1000 10 500 kHz 300 kHz 10 100 kHz 100 kHz 50 kHz 25 kHz Core Loss (mW) Core Loss (mW) 50 kHz 3.5 MHz 1 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 1 25 kHz 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.01 0.001 10000 MPIA4020V2-3R3-R 100 500 kHz 300 kHz 0.001 10 100 1000 Bp-p (Gauss) 8 10000 Bp-p (Gauss) MPIA4020V2-1R2-R 100 10 10000 www.eaton.com/electronics 10000 10 100 1000 Bp-p (Gauss) 10000 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Core loss vs Bp-p MPIA4020V2-4R7-R MPIA4020V2-6R8-R 100 100 500 kHz 300 kHz 10 100 kHz 50 kHz 25 kHz 3.5 MHz 1 Core Loss (mW) Core Loss (mW) 10 500 kHz 300 kHz 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 0.01 0.001 100 kHz 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 10 100 Bp-p (Gauss) 1000 10000 0.001 MPIA4020V2-100-R 100 10 100 Bp-p (Gauss) 1000 MPIA4020V2-150-R 100 500 kHz 300 kHz 500 kHz 300 kHz 50 kHz 50 kHz 25 kHz 1 3.5 MHz 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 25 kHz 3.5 MHz 1 3.0 MHz 2.0 MHz 0.1 1.0 MHz 700 kHz 0.01 0.01 0.001 100 kHz 10 100 kHz Core Loss (mW) Core Loss (mW) 10 10000 0.001 10 100 1000 10000 Bp-p (Gauss) 10 100 1000 10000 Bp-p (Gauss) MPIA4020V2-220-R 100 500 kHz 300 kHz 100 kHz 10 Core Loss (mW) 50 kHz 25 kHz 3.5 MHz 1 3.0 MHz 2.0 MHz 1.0 MHz 700 kHz 0.1 0.01 0.001 10 100 1000 10000 Bp-p (Gauss) www.eaton.com/electronics 9 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance vs. Frequency MPIA4012V2-R47-R 0.8 0.4 0.7 0.35 0.6 0.3 Inductance (µH) Inductance (µH) MPIA4012V2-R33-R 0.45 0.25 0.2 0.15 0.5 0.4 0.3 0.2 0.1 0.1 0.05 0 0 0.1 1 10 100 1000 0.1 1 10 MPIA4012V2-R68-R 2 1 1.8 0.9 1.6 Inductance (µH) Inductance (µH) 0.8 0.7 0.6 0.5 0.4 0.3 1.4 1.2 1 0.8 0.6 0.2 0.4 0.1 0.2 0.1 1 10 100 0 1000 Frequency (MHz) 0.1 1 MPIA4012V2-1R5-R MPIA4012V2-2R2-R 2.7 2.4 2.4 Inductance (µH) 2.1 Inductance (µH) 100 3 2.7 1.8 1.5 1.2 0.9 2.1 1.8 1.5 1.2 0.9 0.6 0.6 0.3 0 10 Frequency (MHz) 3 0.3 0.1 1 10 Frequency (MHz) 10 1000 MPIA4012V2-1R0-R 1.1 0 100 Frequency (MHz) Frequency (MHz) www.eaton.com/electronics 100 0 0.1 1 10 Frequency (MHz) 100 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance vs. Frequency MPIA4012V2-4R7-R MPIA4015V2-R22-R 11 0.35 10 0.3 8 Inductance (µH) Inductance (µH) 9 7 6 5 4 0.2 0.15 0.1 3 2 0.05 1 0 0.25 0.1 1 10 0 100 0.1 1 10 Frequency (MHz) MPIA4015V2-R33-R 0.9 0.45 0.8 0.7 0.35 Inductance (µH) Inductance (µH) 0.4 0.3 0.25 0.2 0.15 0.6 0.5 0.4 0.3 0.1 0.2 0.05 0.1 0.1 1 10 100 0 1000 Frequency (MHz) 0.1 1 10 1000 MPIA4015V2-R68-R MPIA4015V2-R56-R 1.2 1 1.1 0.9 1 0.8 0.9 Inductance (µH) Inductance (µH) 100 Frequency (MHz) 1.1 0.7 0.6 0.5 0.4 0.3 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.2 0.1 0 1000 MPIA4015V2-R47-R 0.5 0 100 Frequency (MHz) 0.1 0.1 1 Frequency (MHz) 10 100 0 0.1 1 Frequency (MHz) 10 www.eaton.com/electronics 100 11 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance vs. Frequency MPIA4015V2-1R5-R MPIA4015V2-1R0-R 2.2 3.2 2 2.8 1.6 Inductance (µH) Inductance (µH) 1.8 1.4 1.2 1 0.8 0.6 2 1.6 1.2 0.8 0.4 0.4 0.2 0 2.4 0.1 1 10 0 100 0.1 1 Frequency (MHz) 10 100 Frequency (MHz) MPIA4015V2-2R2-R MPIA4015V2-3R3-R 8 5.5 5 7 4 Inductance (µH) Inductance (µH) 4.5 3.5 3 2.5 2 1.5 5 4 3 2 1 1 0.5 0 6 0.1 1 10 0 100 0.1 1 Frequency (MHz) 10 10 Inductance (µH) Inductance (µH) 12 8 6 4 2 8 6 4 2 0.1 1 10 Frequency (MHz) 12 100 MPIA4015V2-6R8-R MPIA4015V2-4R7-R 12 0 10 Frequency (MHz) www.eaton.com/electronics 100 0 0.1 1 10 Frequency (MHz) 100 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance vs. Frequency MPIA4020V2-R10-R 24 0.12 20 0.1 Inductance (µH) Inductance (µH) MPIA4015V2-100-R 16 12 8 0.06 0.04 0.02 4 0 0.08 0.1 1 10 0 100 0.1 1 10 Frequency (MHz) 100 1000 0.5 0.45 Inductance (µH) 0.3 Inductance (µH) 1000 MPIA4020V2-R33-R MPIA4020V2-R22-R 0.35 0.25 0.2 0.15 0.4 0.35 0.3 0.25 0.2 0.15 0.1 0.1 0.05 0 100 Frequency (MHz) 0.05 0.1 1 10 100 0 1000 0.1 1 10 Frequency (MHz) Frequency (MHz) MPIA4020V2-R47-R MPIA4020V2-R56-R 1 1.2 1 0.8 0.7 Inductance (µH) Inductance (µH) 0.9 0.6 0.5 0.4 0.3 0.2 0.8 0.6 0.4 0.2 0.1 0 0.1 1 10 Frequency (MHz) 100 1000 0 0.1 1 10 100 Frequency (MHz) www.eaton.com/electronics 13 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance vs. Frequency MPIA4020V2-1R0-R MPIA4020V2-R68-R 2.2 1.4 2 1.8 1.6 1 Inductance (µH) Inductance (µH) 1.2 0.8 0.6 0.4 1.2 1 0.8 0.6 0.4 0.2 0 1.4 0.2 0.1 1 Frequency (MHz) 10 0 100 0.1 10 100 4 3.5 Inductance (µH) 2.4 Inductance (µH) 100 MPIA4020V2-1R5-R MPIA4020V2-1R2-R 2 1.6 1.2 0.8 3 2.5 2 1.5 1 0.4 0.5 0 0.1 1 Frequency (MHz) 10 100 0.1 1 Frequency (MHz) MPIA4020V2-2R2-R MPIA4020V2-3R3-R 2.4 4 3.5 Inductance (µH) 2 Inductance (µH) 10 Frequency (MHz) 2.8 0 1 1.6 1.2 0.8 3 2.5 2 1.5 1 0.4 0 0.5 0.1 1 10 Frequency (MHz) 14 www.eaton.com/electronics 100 0 0.1 1 Frequency (MHz) 10 100 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance vs. Frequency MPIA4020V2-6R8-R MPIA4020V2-4R7-R 16 12 14 10 Inductance (µH) Inductance (µH) 12 8 6 4 10 8 6 4 2 0 2 0 0.1 1 10 100 0.1 1 MPIA4020V2-100-R MPIA4020V2-150-R 24 Inductance (µH) 20 Inductance (µH) 100 28 24 16 12 8 20 16 12 8 4 0 10 Frequency (MHz) Frequency (MHz) 4 0.1 1 10 100 Frequency (MHz) 0 0.1 1 10 100 www.eaton.com/electronics 15 Frequency (MHz) MPIA4020V2-220-R 70 Inductance (µH) 60 50 40 30 20 10 0 0.1 1 10 100 Frequency (MHz) Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance and temperature rise vs. Current 100 0.45 80 0.4 80 70 0.35 70 60 0.2 50 0.15 40 30 Temperature Rise 0.05 0 2 4 6 8 10 12 14 16 18 0.3 60 0.25 50 0.2 40 0.15 30 20 0.1 10 0.05 0 0 Idc (A) MPI4012V2-R68-R 70 60 0.4 50 0.3 40 30 0.2 Inductance (µH) Temperature Rise (°C) Inductance (µH) 0.5 4 6 6 8 10 12 1.4 90 80 0.7 70 0.6 60 0.5 50 0.4 40 30 Temperature Rise 0 1 2 3 4 5 50 40 30 Temperature Rise 20 0.2 7 8 9 0 MPI4012V2-2R2-R 2.4 100 90 Inductance Inductance (µH) 60 0.6 6 2 Temperature Rise (°C) Inductance (µH) 70 0.8 20 10 90 1 100 Idc (A) 80 80 70 1.6 60 1.2 50 40 0.8 30 Temperature Rise 20 0.4 10 0 1 2 3 4 Idc (A) 16 0 0.8 0 0 1.2 0 12 0.1 100 Inductance 0.4 10 MPI4012V2-1R0-R Idc (A) MPI4012V2-1R5-R 1.6 8 Inductance 0.2 10 2 4 0.3 20 Temperature Rise 0 2 0.9 90 Inductance 80 0 0 1 100 0.1 10 Idc (A) 0.7 0.6 20 Temperature Rise www.eaton.com/electronics 5 6 7 8 Temperature Rise (°C) 0 90 0 10 0 0 1 2 3 4 Idc (A) 5 6 7 0 Temperature Rise (°C) 0.1 Inductance (µH) Inductance (µH) 0.25 100 Inductance 90 Temperature Rise (°C) Inductance 0.3 MPI4012V2-R47-R 0.5 Temperature Rise (°C) MPI4012V2-R33-R 0.35 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance and temperature rise vs. Current 100 0.2 80 0.18 3.5 70 3 60 2.5 50 2 40 30 Temperature Rise 2.5 3 3.5 4 4.5 5 30 0.06 0.02 2 40 0.08 10 1.5 50 0.1 0.5 1 60 0.12 0.04 0.5 70 0.14 20 0 80 0.16 1 0 0 0 Temperature Rise 0 2 4 6 8 10 0 20 100 60 0.2 50 0.15 40 30 Temperature Rise 60 0.3 50 40 0.2 30 20 0.05 80 70 Inductance (µH) 70 90 0.4 Temperature Rise (°C) Inductance (µH) 18 Inductance 90 Inductance 0.1 Temperature Rise 0.1 20 10 0 2 4 6 8 10 12 14 16 10 0 0 Idc (A) 100 Inductance 50 0.3 40 0.2 30 Temperature Rise 10 Idc (A) 10 12 14 MPIA4015V2-R68-R 0 10 12 14 0 100 90 80 0.5 70 60 0.4 50 0.3 40 30 0.2 Temperature Rise 20 0.1 8 8 0.6 Inductance (µH) 60 6 6 Inductance Temperature Rise (°C) 70 0.4 4 4 0.7 80 2 2 90 0.5 0 0 Idc (A) MPIA4015V2-R56-R 0.6 Inductance (µH) 16 0.5 80 0 14 MPIA4015V2-R47-R 100 0.25 0 12 Idc (A) MPIA4015V2-R33-R 0.3 20 10 Idc (A) 0.35 90 Temperature Rise (°C) 1.5 100 Inductance 20 0.1 0 Temperature Rise (°C) Inductance (µH) 4 90 Inductance (µH) Inductance Temperature Rise (°C) 4.5 MPIA4015V2-R22-R 0.22 Temperature Rise (°C) MPIA4012V2-4R7-R 5 10 0 2 4 6 8 10 12 0 Idc (A) www.eaton.com/electronics 17 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance and temperature rise vs. Current MPIA4015V2-1R0-R MPIA4015V2-1R5-R 1.4 60 0.6 50 0.5 40 0.4 30 Temperature Rise 0.2 1 2 3 4 5 6 7 8 9 10 60 50 40 0.6 30 0.4 0 0 10 0 1 2 3 4 MPIA4015V2-2R2-R 90 Inductance 60 1.2 50 1 40 0.8 30 Temperature Rise 20 0 1 2 3 4 5 6 7 70 60 2 50 1.5 40 30 1 20 Temperature Rise 0.5 0 0 100 4.5 10 0 0.5 1 1.5 2 2.5 Inductance 60 2.5 50 2 40 Temperature Rise 30 1 20 0.5 10 1 1.5 2 2.5 Idc (A) www.eaton.com/electronics 3 3.5 4 4.5 5 0 Inductance (µH) 3 0.5 4 4.5 5 5.5 6 0 100 90 6 Temperature Rise (°C) 70 0 3.5 6.5 80 3.5 1.5 3 MPIA4015V2-6R8-R 7 90 4 Inductance (µH) 80 Idc (A) MPIA4015V2-4R7-R 5 18 100 Inductance Idc (A) 0 0 10 0.2 0 8 2.5 Inductance (µH) Inductance (µH) 1.4 Temperature Rise (°C) 70 1.6 0.4 7 90 3 80 1.8 0.6 6 MPIA4015V2-3R3-R 3.5 100 2.2 2 5 Idc (A) Idc (A) 2.4 20 Temperature Rise 0.2 10 0 70 0.8 20 0.1 80 Inductance 5.5 80 5 70 4.5 60 4 3.5 50 3 40 2.5 2 30 Temperature Rise 1.5 20 1 10 0.5 0 0 0.5 1 1.5 2 Idc (A) 2.5 3 3.5 4 0 Temperature Rise (°C) 0.3 90 Inductance 1 Inductance (µH) 70 0.7 100 1.2 Temperature Rise (°C) Inductance (µH) 90 80 0.8 0 1.6 Temperature Rise (°C) Inductance 1 0.9 100 Temperature Rise (°C) 1.1 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance and temperature rise vs. Current 80 7 70 6 60 5 50 4 40 30 Temperature Rise Inductance 0.07 70 0.06 60 0.05 50 0.04 40 Temperature Rise 0.03 30 2 20 0.02 20 1 10 0.01 10 0 0.5 1 1.5 2 2.5 3 3.5 0 0 0 5 10 15 20 Idc (A) 100 50 0.12 40 Temperature Rise 30 Inductance (µH) 60 Temperature Rise (°C) 70 10 15 20 25 30 80 0.25 70 60 0.2 50 0.15 40 30 Temperature Rise 20 0.05 0 0 10 0 2 4 6 8 10 12 14 16 18 20 MPIA4020V2-R47-R MPIA4020V2-R56-R 0.6 100 100 90 90 0.5 50 0.3 40 0.2 30 Temperature Rise 20 0.1 Inductance (µH) Inductance (µH) 60 Temperature Rise (°C) 70 0.4 Inductance 0.5 80 Inductance 80 70 0.4 60 0.3 50 40 0.2 30 Temperature Rise 20 0.1 10 10 0 0 2 4 6 8 10 Idc (A) 0 Idc (A) Idc (A) 0.6 100 0.1 10 5 0 Inductance 20 0.04 0 40 90 0.3 80 0.16 0 35 MPIA4020V2-R33-R 0.35 90 Inductance 0.2 0.08 30 Idc (A) MPIA4020V2-R22-R 0.24 25 Temperature Rise (°C) 0 Inductance (µH) 80 12 14 16 18 0 0 0 2 4 6 8 10 12 14 16 0 Idc (A) www.eaton.com/electronics 19 Temperature Rise (°C) 3 90 0.08 Inductance (µH) 8 100 0.09 90 Inductance Temperature Rise (°C) Inductance (µH) 9 MPIA4020V2-R10-R 0.1 100 Temperature Rise (°C) MPIA4015V2-100-R 10 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance and temperature rise vs. Current Inductance 90 1 60 0.4 50 0.3 40 Temperature Rise 30 0.2 Inductance (µH) 70 Temperature Rise (°C) 80 0.5 Inductance 80 70 0.8 60 0.6 50 40 0.4 30 Temperature Rise 20 0.1 2 4 6 8 10 12 14 10 0 0 Idc (A) 1.2 1.6 90 1.4 70 60 0.8 50 0.6 40 30 Temperature Rise 1 2 3 4 5 Idc (A) 6 7 8 9 10 12 MPIA4020V2-2R2-R 90 Inductance 80 70 60 50 40 0.6 30 Temperature Rise 20 0.2 0 10 60 1.2 50 40 0.8 30 Temperature Rise 2 3 4 5 6 7 8 9 MPIA4020V2-3R3-R 90 Inductance 80 3 70 2.5 60 2 50 40 1.5 30 Temperature Rise 1 20 20 0.4 10 1 2 3 4 Idc (A) www.eaton.com/electronics 5 6 7 8 0 0 100 3.5 Temperature Rise (°C) 70 1 4 80 1.6 0 Idc (A) 100 Inductance 0 0 100 0.8 0 90 Inductance (µH) 10 MPIA4020V2-1R5-R 0.4 Inductance (µH) 0 2 20 8 10 2.4 0 6 1 20 0.2 0 4 1.2 Inductance (µH) 1 Temperature Rise (°C) Inductance (µH) 100 80 Inductance 0.4 2 Idc (A) MPIA4020V2-1R2-R 1.4 0 Temperature Rise (°C) 0 20 0.2 10 0.5 0 10 0 0.5 1 1.5 2 2.5 3 Idc (A) 3.5 4 4.5 5 5.5 6 0 Temperature Rise (°C) 0 100 90 0.6 Inductance (µH) MPIA4020V2-1R0-R 1.2 100 Temperature Rise (°C) MPIA4020V2-R68-R 0.7 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Inductance and temperature rise vs. Current MPIA4020V2-4R7-R MPIA4020V2-6R8-R 90 80 3.5 70 3 60 2.5 50 2 40 1.5 30 Temperature Rise 1 20 0.5 10 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 80 5 70 60 4 50 3 40 2 30 Temperature Rise 20 1 0 0 Idc (A) 10 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 0 Idc (A) MPIA4020V2-100-R 12 Inductance MPIA4020V2-150-R 100 16 100 90 10 50 6 40 4 30 Temperature Rise 0 0.5 1 1.5 2 2.5 3 3.5 4 MPIA4020V2-220-R 50 40 6 Temperature Rise 30 2 0 0 20 10 0 0.4 0.8 1.2 1.6 2 2.4 0 100 90 80 Inductance 16 70 14 60 12 50 10 40 8 6 30 Temperature Rise 4 20 2 10 0 0.4 0.8 1.2 1.6 2 2.4 2.8 Temperature Rise (°C) 18 Inductance (µH) 60 8 Idc (A) 20 0 70 10 10 Idc (A) 22 80 4 20 2 90 Inductance 12 Inductance (µH) 60 Temperature Rise (°C) Inductance (µH) 70 8 0 14 80 Inductance Temperature Rise (°C) 0 90 6 Inductance (µH) Inductance 4 Temperature Rise (°C) Inductance (µH) 4.5 100 7 100 Temperature Rise (°C) 5 0 Idc (A) www.eaton.com/electronics 21 Technical Data 10652 MPIA40-V2 Automotive grade High current, low profile, miniature power inductors Effective April 2017 Solder reflow profile TP TC -5°C tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s Temperature TL Preheat A T smax t Table 1 - Standard SnPb Solder (Tc) Package Thickness Volume mm3
MPIA4020V2-6R8-R 价格&库存
很抱歉,暂时无法提供与“MPIA4020V2-6R8-R”相匹配的价格&库存,您可以联系我们找货
MPIA4020V2-6R8-R
  • 3000+8.956353000+1.16390
库存:12000
MPIA4020V2-6R8-R
  • 3000+6.69842
库存:14850
MPIA4020V2-6R8-R
  • 1+10.756121+1.39779
  • 10+8.8596710+1.15134
  • 25+8.1946925+1.06492
  • 50+7.7258650+1.00400
  • 100+7.28335100+0.94649
  • 250+6.73851250+0.87569
  • 500+6.35383500+0.82570
  • 1000+5.991421000+0.77860
库存:6661
MPIA4020V2-6R8-R
MPIA4020V2-6R8-R
