CHS-01B
CHS-01B
    NIDEC(尼得科)
    SMD,2.5x5.4mm
    DIP 开关 SPST 1 位置 表面贴装型 滑动式(标准) 触动器 100mA 6VDC
CHS-01B 数据手册
SLIDE SWITCHES (HALF PITCH) RoHS compliant CHS INTERNAL STRUCTURE ① ② ③ ⑤ ④ ⑥ Part name ■ FEATURES ● ● ● ● ● ● RoHS compliant Meets EIAJ SOP standard outline dimensions (B type) Low profile design of 2.5 mm 12 types of 1, 2, 4, 6, 8 or 10 bit with either gull wing or J-hook available Excellent contact stability by twin Gold-plated contact Resin material is UL Recognized 94V-0 Material ① Cover Polyphenylenesulfide ② Slider Polyamide ③ Housing ④ Slider contact ⑤ Fixed contact ⑥ Terminal pin Polyphenylenesulfide Copper alloy, Gold-plated ■ PART NUMBER DESIGNATION CHS - 06 T A 1 Series name No. of bits 01:1 bit 02: 2 bits 04:4 bits 06:6 bits 08:8 bits 10:10 bits Structure 1:Non-washable type (Without seal tape) Standard type 2:Non-washable type (With seal tape) Blank : Washable type (With seal tape) Form of packaging Shape of terminal T:Taping (Reel) M:Magazine Blank:Bulk in plastic bag A:J-hook B:Gull wing ※ Please refer to the LIST OF PART NUMBERS when placing orders. CHS SLIDE SWITCHES (HALF PITCH) ■ LIST OF PART NUMBERS No. of bits 1 2 4 6 8 10 No. of bits 1 2 4 6 8 10 Form of packaging Shape of terminals Non-washable type (Without seal tape) A Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Form of packaging Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Taping Magazine Plastic bag Shape of terminals J-hook B Gull wing A J-hook B Gull wing Packaging quantity CHS-01TA1 CHS-01TB1 CHS-01TA2 CHS-01TB2 1000 pcs./reel CHS-01A1 CHS-02TA1 CHS-01B1 CHS-02TB1 CHS-02TA2 CHS-02TB2 50 pcs./pack 500 pcs./reel CHS-02A1 CHS-04TA1 CHS-04MA1 CHS-04A1 CHS-06TA1 CHS-06MA1 CHS-06A1 CHS-08TA1 CHS-08MA1 CHS-08A1 CHS-10TA1 CHS-10MA1 CHS-10A1 CHS-02B1 CHS-04TB1 CHS-04MB1 CHS-04B1 CHS-06TB1 CHS-06MB1 CHS-06B1 CHS-08TB1 CHS-08MB1 CHS-08B1 CHS-10TB1 CHS-10MB1 CHS-10B1 CHS-04TA2 CHS-04TB2 CHS-06TA2 CHS-06TB2 CHS-08TA2 CHS-08TB2 CHS-10TA2 CHS-10TB2 Washable type (With seal tape) A Non-washable type (With seal tape) J-hook B Gull wing Packaging quantity CHS-01TA CHS-01TB 1000 pcs./reel CHS-01A CHS-02TA CHS-01B CHS-02TB 50 pcs./pack 500 pcs./reel CHS-02A CHS-04TA CHS-04MA CHS-04A CHS-06TA CHS-06MA CHS-06A CHS-08TA CHS-08MA CHS-08A CHS-10TA CHS-10MA CHS-10A CHS-02B CHS-04TB CHS-04MB CHS-04B CHS-06TB CHS-06MB CHS-06B CHS-08TB CHS-08MB CHS-08B CHS-10TB CHS-10MB CHS-10B 50 pcs./pack 500 pcs./reel 70 pcs./stick 50 pcs./pack 500 pcs./reel 50 pcs./stick 50 pcs./pack 500 pcs./reel 40 pcs./stick 50 pcs./pack 500 pcs./ree 30 pcs./stick 50 pcs./pack : Not manufactured ※ Verify the above part numbers when placing orders. Taping and magazine version can be supplied only in reel or stick units. 50 pcs./pack 500 pcs./reel 70 pcs./stick 50 pcs./pack 500 pcs./reel 50 pcs./stick 50 pcs./pack 500 pcs./reel 40 pcs./stick 50 pcs./pack 500 pcs./ree 30 pcs./stick 50 pcs./pack CHS SLIDE SWITCHES (HALF PITCH) ■ STANDARD SPECIFICATIONS ■ ELECTRICAL CHARACTERISTICS Contact rating Non-switching Switching Minimum Operating temp. range Storage temp. range Sealing Net weight − 40 ~ 85 °C Washable type available with seal tape Approx. 0.05 g (CHS-01) Approx. 0.08 g (CHS-02) Approx. 0.12 g (CHS-04) Approx. 0.17 g (CHS-06) Approx. 0.22 g (CHS-08) Approx. 0.25 g (CHS-10) ■ MECHANICAL CHARACTERISTICS Operating force 0.5 ~ 5 N {0.05 ~ 0.51 kgf} DC50 V 100 mA DC6 V, 100 mA DC24 V, 25 mA DC20 mV 1 μA Contact resistance 50 mΩ maximum Insulation resistance 1000 MΩ (DC100 V) minimum Dielectric strength AC500 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS Vibration (Amplitude) 1.5 mm or (Acceleration) 98 m/s2, 10-500 Hz, 3 directions for 10 cycles each Stop strength 10 N {1.02 kgf}, 60 s Shock 490 m/s2, 11 ms 6 directions for 3 times each Solderability 245 ± 3 °C, 2 ~ 3 s Load life Continuous load 2000 cycles, DC6 ± 0.5 V, 100 ± 10 mA Reflow:255 °C (Peak temperature) (Please refer to the profile below) Humidity −10 ~ 65 °C, Relative humidity 0 ~ 96 %, 24 h for 10 cycles Soldering heat Manual soldering:350 ± 10 °C, 3 ~ 4 s Shear (Adhesion) 5 N {0.51 kgf} 10 s Substrate bending Width 90 mm, bend 3 mm, 5 s, 1 time Pull-off strength High temp. exposure 85 °C, 96 h Low temp. exposure −40 °C, 96 h Thermal shock −40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles 5 N {0.51 kgf} 10 s { } : Reference only Temperature 〈Reflow profile for soldering heat evaluation〉 (℃) 250 Peak : 250 0 ℃ 200 Pre Heating Zone 150 100 50 +5 Over 230℃ 180℃ 150℃ 90 ± 30 s 30 ± 10 s Heating time Soldering Zone リフロー回数:2回 Reflow : two times maximum CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-01A1 ● CHS-01B1 0.1 0.15 +–0.05 8 5.4 O N 0.1 0.15 +–0.05 2.5 max. 0.3 2.5 0.6 እᙧᅗ CHS-02B1 0.1 0.6 +–0.05 0.1 + 0.1 –0.05 2.5 0 –0.1 Schematic Schematic ● CHS-02B1 (In accordance with EIAJ ED-7402-1) ● CHS-02A1 Non-washable type (Without seal tape) Non-washable type (Without seal tape) 8 5.4 O N - C Stroke 0.6 0. 5 0.1 0.15 +–0.05 0.1 0.4 +–0.05 1.27±0.15 0.3 4.1 2.5 max. 0.1±0.1 0.3 2 3.8 5.6 +0.3 0 5.4 O N - C Stroke 0.6 0. 5 2.5 max. 0.1±0.1 2 + 0.1 0.15 –0.05 4.1 0.1 0.4+–0.05 1.27±0.15 1.4±0.15 Schematic 0.4 min. Production date code Production date code 1.4±0.15 Schematic 0.4 min. 2.5 max. 0 0.1–0.1 0.3 2 2 – C Stroke 0.6 0. 5 3.8 5.6 +0.3 0 5.4 O N Production date code – C Stroke 0.6 0. 5 Production date code 0.4 min. Non-washable type (Without seal tape) 0.4 min. Non-washable type (Without seal tape) CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS CHS-04B1 እᙧᅗ Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-04B1  (In accordance with EIAJ ED-7402-1) ● CHS-04A1 Non-washable type (Without seal tape) Non-washable type (Without seal tape) 2.5 max. 0.1±0.1 1.4±0.15 Schematic CHS-06B1 እᙧᅗ Non-washable type (Without seal tape) Non-washable type (Without seal tape) 8 5.4 O N - C Stroke 0.6 0. 5 3.8 5.6 +0.3 0 5.4 O N 0.1 0.15 +–0.05 2.5 max. 1.4±0.15 Schematic 0.1±0.1 9.2 0.3 2 - C Stroke 0.6 0. 5 Production date code 2 0.3 0.1±0.1 0.4 min. ● CHS-06B1  (In accordance with EIAJ ED-7402-1) + 0.1 0.15 –0.05 0.1 0.4 +–0.05 1.27±0.15 0.4 min. O N Schematic Production date code 2.5 max. 1.4±0.15 0.4 min. ● CHS-06A1 0.1 0.4 +–0.05 1.27±0.15 9.2 0.1 0.4 +–0.05 1.27±0.15 1.4±0.15 Schematic 0.4 min. 0.1 0.4 +–0.05 1.27±0.15 6.6 0.3 2 6.6 0.3 2.5 max. 0.1±0.1 0.1 0.15 +–0.05 2 0.1 0.15 +–0.05 8 5.4 3.8 - C Stroke 0.6 0. 5 Production date code 5.6 +0.3 0 5.4 O N - C Stroke 0.6 0. 5 Production date code SLIDE SWITCHES (HALF PITCH) CHS-08B1 እᙧᅗ ■ OUTLINE DIMENSIONS ● CHS-08A1 Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-08B1 (In accordance with EIAJ ED-7402-1) Non-washable type (Without seal tape) 1.4±0.15 Schematic እᙧᅗ Non-washable type (Without seal tape) Schematic ● CHS-10B1 (In accordance with EIAJ ED-7402-1) CHS-10B1 እᙧᅗ Non-washable type (Without seal tape) 8 5.4 O N - C Stroke 0.6 0. 5 + 0.1 0.15 –0.05 2 2 0.1 0.15 +–0.05 Production date code 3.8 5.6 +0.3 0 5.4 O N Production date code - C Stroke 0.6 0. 5 1.4±0.15 + 0.1 0.4 –0.05 1.27±0.15 14.3 1.4±0.15 Schematic 2.5 max. 0.1±0.1 2.5 max. 14.3 0.4 min. ● CHS-10A1 + 0.1 0.4 –0.05 1.27±0.15 + 0.1 0.4 –0.05 1.27±0.15 1.4±0.15 Schematic 0.4 min. 0.1 0.4 +–0.05 1.27±0.15 11.7 0.4 min. 8 5.4 O N + 0.1 0.15 –0.05 2 11.7 2.5 max. 0.1±0.1 0.3 2.5 max. 0.1±0.1 0.3 - C Stroke 0.6 0. 5 3.8 5.6 +0.3 0 5.4 O N 0.1 0.15 +–0.05 2 - C Stroke 0.6 0. 5 Production date code 0.4 min. Non-washable type (Without seal tape) Production date code 0.1±0.1 ᅗ CHS CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-01A Washable type (With seal tape) ● CHS-01B Washable type (With seal tape) ● CHS-01TA2 Non-washable type (With seal tape) ● CHS-01TB2 Non-washable type (With seal tape) 2.5 + 0.1 0.6 –0.05 0.1 + 0.1 0.6 –0.05 0.3 2 2.5 max. 2.5 Schematic CHS-02B እᙧᅗ 0.4 min. 8 5.4 – + 0.1 0.15 –0.05 Seal tape 0 –0.1 2 Seal tape 2.5 max. 0 0.1–0.1 0.3 O N C Stroke 0.6 0. 5 3.8 5.6 +0.3 0 5.4 O N C Stroke 0.6 0. 5 – 0.1 0.15 +–0.05 0.4 min. Production date code Production date code Schematic ● CHS-02A Washable type (With seal tape) ● CHS-02B Washable type (With seal tape) ● CHS-02TA2 Non-washable type (With seal tape) ● CHS-02TB2 Non-washable type (With seal tape) (In accordance with EIAJ ED-7402-1) 0.1 0.4 +–0.05 1.27±0.15 Seal tape 0.3 テープシール 4.1 + 0.1 0.4 –0.05 1.27±0.15 1.4±0.15 Schematic テープシール Seal tape 1.4±0.15 Schematic 0.4 min. 8 5.4 O N - C Stroke 0.6 0. 5 0.1 0.15 +–0.05 2 4.1 2.5 max. 0.1±0.1 0.3 2 2.5 max. 0.1±0.1 3.8 5.6 +0.3 0 5.4 O N - C Stroke 0.6 0. 5 + 0.1 0.15 –0.05 0.4 min. Production date code Production date code CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS CHS-04B እᙧᅗ Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-04A Washable type (With seal tape) ● CHS-04B Washable type (With seal tape) ● CHS-04TA2 Non-washable type (With seal tape) ● CHS-04TB2 Non-washable type (With seal tape) (In accordance with EIAJ ED-7402-1) 6.6 2.5 max. 0.1±0.1 0.3 0.1 0.4 +–0.05 1.27±0.15 Seal tape + 0.1 0.4 –0.05 1.27±0.15 1.4±0.15 Schematic CHS-06B እᙧᅗ Seal tape 0.4 min. 8 5.4 0.1 0.15 +–0.05 2 2 6.6 0.3 2.5 max. 0.1±0.1 O N - C Stroke 0.6 0. 5 3.8 5.6 +0.3 0 5.4 O N - C Stroke 0.6 0. 5 + 0.1 0.15 –0.05 0.4 min. Production date code Production date code 1.4±0.15 Schematic ● CHS-06A Washable type (With seal tape) ● CHS-06B Washable type (With seal tape) ● CHS-06TA2 Non-washable type (With seal tape) ● CHS-06TB2 Non-washable type (With seal tape) (In accordance with EIAJ ED-7402-1) 2 + 0.1 0.4 –0.05 1.27±0.15 1.4±0.15 Schematic 0.3 Seal tape 2.5 max. 9.2 0.4 min. 0.1 0.15 +–0.05 9.2 + 0.1 0.4 –0.05 1.27±0.15 Seal tape 1.4±0.15 Schematic 0.4 min. 8 5.4 O N - C Stroke 0.6 0. 5 + 0.1 0.15 –0.05 0.1±0.1 0.3 0.1±0.1 2.5 max. 3.8 5.6 +0.3 0 5.4 O N Production date code 2 - C Stroke 0.6 0. 5 Production date code CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS CHS-08B እᙧᅗ Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-08A Washable type (With seal tape) ● CHS-08B Washable type (With seal tape) ● CHS-08TA2 Non-washable type (With seal tape) ● CHS-08TB2 Non-washable type (With seal tape) 8 5.4 2 0.1 0.15 +–0.05 2.5 max. 0.1±0.1 0.3 + 0.1 0.4 –0.05 1.27±0.15 2.5 max. 0.1±0.1 0.3 Seal tape 11.7 1.4±0.15 Schematic Seal tape 11.7 + 0.1 0.4 –0.05 1.27±0.15 1.4±0.15 Schematic እᙧᅗ● CHS-10A Washable type (With seal tape) ● CHS-10B Washable type (With seal tape) ● CHS-10TA2 Non-washable type (With seal tape) ● CHS-10TB2 Non-washable type (With seal tape) CHS-10B እᙧᅗ 0.4 min. 0.1 0.15 +–0.05 O N - C Stroke 0.6 0. 5 3.8 5.6 +0.3 0 5.4 O N Production date code 2 - C Stroke 0.6 0. 5 Production date code 0.4 min. (In accordance with EIAJ ED-7402-1) + 0.1 0.4 –0.05 1.27±0.15 Seal tape 1.4±0.15 Schematic 14.3 2.5 max. 0.1±0.1 0.1±0.1 2.5 max. 14.3 0.1 0.4 +–0.05 1.27±0.15 Seal tape 1.4±0.15 Schematic 0.4 min. 8 5.4 O N + 0.1 0.15–0.05 2 - C Stroke 0.6 0. 5 Production date code 3.8 5.6 +0.3 0 5.4 O N + 0.1 0.15 –0.05 2 - C Stroke 0.6 0. 5 Production date code 0.4 min. (In accordance with EIAJ ED-7402-1) CHS-08D 外形図 CHS SLIDE SWITCHES (HALF PITCH) ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance : ± 0.3 (Unit : mm) ● CHS-08D 0.4 min. 8 5.4 O N 2.5 max. 2 0 - C Stroke 0.6 0.8 –0.2 0. 5 Production date code 0.4 min. < Reference > The D version with opposite pin direction is available upon receipt of your order. 11.7 + 0.1 0.15 –0.05 + 0.1 0.4 –0.05 1.27±0.15 1.4±0.15 Schematic ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS ● 1 bit (Unit : mm) B type 5.08 0 1.27 1.6 0 7.62 A type 1 1 ● 2 bits A type B type 1.27 1.27 1.27 1.6 0.76 7.62 0 5.08 0 0.76 Note) The zero point is the center of mounting. 1.27N (N=1 3) =3.81 0.76 5.08 0 1.27 1.6 0 0.76 7.62 1.27N (N=1 3) =3.81 CHS 1.27 SLIDE SWITCHES (HALF PITCH) 1.27 0 1.27 1.6 0.76 7.62 7.62 7.62 7.62 1.27N (N=1 5) =6.35 0.760 7.62 0.76 0 7) =8.89 1.27N (N=1 0.76 1.27N (N=1 7) =8.89 1.27N0.76 (N=1 7) =8.89 1.27N (N=1 7) =8.89 0.76 0.76 0.76(N=1 9) =11.43 1.27N 0 0 1.27N (N=1 9) =11.43 0.76 7.62 7.62 1.27N (N=1 9) =11.43 0.76 1.27N (N=1 9) =11.43 0 7.62 1.27 1.27N (N=1 5) =6.35 0 7.62 0.76 1.27 1.27 5.08 5.08 1.27N 0.76 (N=1 9) =11.43 0 0.76 B type 1.27 0 1.27N (N=1 9) =11.43 0 0 7.62 1.27 1.27 1.27 1.27 1.27 1.27 5.08 1.27N (N=1 9) =11.43 0.76 5.08 1.6 1.27 5.08 0 1.6 1.6 1.6 B type 1.27N 0.76(N=1 7) =8.89 0 0.76 1.6 1.6 1.6 0 1.27 5.08 1.27N (N=1 7) =8.89 0.76 0.76 1.27N (N=1 9) =11.43 A type 1.27 0 0.76 1.27N (N=1 7) =8.89 1.27N (N=1 5) =6.35 7.62 7.62 5.08 5.08 1.27N (N=1 5) =6.35 0 7) =8.89 1.27N (N=1 ● 10 bits 0 1.27N (N=1 5) =6.35 0.76 0.76 1.27 A type 0.76 0 1.27N (N=1 5) =6.35 5.08 1.6 ● 8 bits 0.76 0 0.76 B type 5.08 5.08 1.6 0.76 1.27N (N=1 5) =6.35 1.27N (N=1 3) =3.81 0 0.76 7.62 0.76 0 0.761.27N (N=1 3) =3.81 7.62 1.6 1.6 0 1.27N (N=1 5) =6.35 1.27 1.27 0 1.27N (N=1 3) =3.81 5.08 5.08 0.76 1.27N (N=1 3) =3.81 0.76 1.27N (N=1 3) =3.81 0 5.08 0 0.76 0 1.27N (N=1 3) =3.81 5.08 1.6 1.6 1.6 0.76 0 0.76 1.6 A type 0 0 7.62 7.62 1.27N (N=1 3) =3.81 0.76 0 ● 6 bits B type (Unit : mm) 0.76 1.27 0.76 1.27N (N=1 3) =3.81 0 0.76 1.27 0 1.6 A type 5.08 1.6 ● 4 bits 5.08 0.76 7.62 5.08 0 1.27 1.27 ■ RECOMMENDED 1.270.76P.C.B. PAD OUTLINE DIMENSIONS 7.62 0 1.27 0 5.08 5.08 1.6 1.6 0 1.27 7.62 7.62 1.27 1.27 0.76 Note) The zero point is the center of mounting. CHS SLIDE SWITCHES (HALF PITCH) ■ PACKAGING SPECIFICATIONS Taping version (CHS-02 ~ 10 types) are packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc. CHS-01 type is packaged in 1000 pcs. per reel. Orders will be accepted for units of 1000 pcs., i.e., 2000, 3000 pcs., etc. ● Taping version is boxed with two reels. ● Maximum number of consecutive missing pieces=2 Leader length and reel dimension are shown in the diagrams below: ● Embossed tape dimensions ● Reel dimensions (Unit: mm) (Conforms to JIS C 0806-3) (In accordance with EIAJ ET-7200A) 17.41 (1,2,4,6 bits) 25.41 (8,10 bits) Empty Filled φ 21±0.8 End φ 50 min. (1,2,4,6 bits) φ 1001 (8,10 bits) Empty 2±0.5 Head 40 mm min. 20 pitches min. Leader 400 mm min. Direction of feed φ 13±0.2 21.41 (1,2,4,6 bits) 29.41 (8,10 bits) φ 254±2 0.3±0.1 3 Ҿ͖ग़͠ํ޲ Direction of feed 0.3±0.1 ૷ணྫ (CHS-02A) Installation example 16 O N 2±0.1 7.5±0.1 12±0.1 4±0.1 φ 1.5 +0.1 0 1.75±0.1 Ҿ͖ग़͠ํ޲ Direction of feed ● 2 bits (Unit : mm) ૷ணྫ (CHS-01A) Installation example 16 2±0.1 (Conforms to JIS C 0806) 1.75±0.1 4±0.1 7.5±0.1 φ 8±0.1 +0.1 1.5 0 O N ● 1 bit 3 CHS SLIDE SWITCHES (HALF PITCH) ● 4 bits 7.5±0.1 2±0.1 O N (Unit : mm) 0.3±0.1 ૷ணྫ (CHS-04A) Installation example 16 φ 1.5 +0.1 0 1.75±0.1 (Conforms to JIS C 0806) 12±0.1 4±0.1 3 Ҿ͖ग़͠ํ޲ Direction of feed 7.5±0.1 2±0.1 O N 0.3±0.1 ૷ணྫ (CHS-06A) Installation example 16 12±0.1 4±0.1 φ 1.5 +0.1 0 1.75±0.1 ● 6 bits 3 Ҿ͖ग़͠ํ޲ ● 8 bits 12±0.1 4±0.1 2±0.1 0.3±0.1 ૷ணྫ (CHS-08A) Installation example 11.5±0.1 24 φ 1.5 +0.1 0 1.75±0.1 Direction of feed O N $)45BQJOH + 3 Ҿ͖ग़͠ํ޲ ● 10 bits 12±0.1 4±0.1 2±0.1 0.3±0.1 ૷ணྫ(CHS-10A) Installation example 11.5±0.1 φ 1.5 +0.1 0 1.75±0.1 Direction of feed 24 O N Ҿ͖ग़͠ํ޲ Direction of feed 3 CHS SLIDE SWITCHES (HALF PITCH) ● Packing quantities of magazines are different depending on the bit number of the switches. Please order the multiple numbers of the specific packing quantities. (e.g. 70 pcs., 140 pcs., 210 pcs., etc., in case of 4 bits version) Pieces in package : 4 bits, 70pcs./stick 6 bits, 50pcs./stick 8 bits, 40pcs./stick 10 bits, 30pcs./stick CHS マガジン ● Magazine dimensions (Unit : mm) 3.9±0.3 10.4±0.3 ※ The magazine is common to A and B terminal pin. Magazine length : 500 ± 2 mm long 装着例(B type) Installation example ● The smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc. ● Boxing of bulk in a plastic bag is performed with 50 pcs. (standard 200 pcs.) per box.
CHS-01B 价格&库存
很抱歉,暂时无法提供与“CHS-01B”相匹配的价格&库存,您可以联系我们找货
