SLG7NT4375VTR
SLG7NT4375VTR
    DIALOGSEMICONDUCTOR(戴乐格)
    STQFN12_1.6X1.6MM
    CMIC, SKL AIO POWER SEQUENCING
SLG7NT4375VTR 数据手册
SLG7NT4375 GreenPAK™ SKLAIO Pin Configuration NC Silego SLG7NT4375 is a low power and small form device. The SoC is housed in a 1.6 x 1.6 mm STQFN package which is optimal for using with small devices. Features • 3 Outputs — Push Pull 1X • 1 Output — Push Pull 2X Silego Technology, Inc. SLG7NT4375_DS_r101 SLG7NT4375_GP_r004 10 1 VPP (2.5V) 2 9 VDDQ_EN SLP_S3#/DDR_VTT_CNTL 3 8 VDDQ_BLEED VPP_EN 4 7 GND 5 6 VDDQ(1.2V) Output Summary 12 11 VDD VTT_EN • Low Power Consumption • Pb-Free / RoHS Compliant • Halogen-Free • STQFN-12 Package • MSL “1” +V3P3A General Description SLP_S4# STQFN-12 TOP VIEW Rev 1.01 Revised February 23, 2015 SLG7NT4375 SKLAIO Block Diagram SLG7NT4375_DS_r101 Page 2 2 SLG7NT4375 SKLAIO Pin Configuration Pin # 1 2 Pin Name VDD VPP (2.5V) 3 SLP_S3#/DDR_VTT_CNTL 4 5 VPP_EN VTT_EN 6 VDDQ(1.2V) 7 8 9 10 11 12 GND VDDQ_BLEED VDDQ_EN SLP_S4# +V3P3A NC Type PWR Digital Input Analog Input/Output Digital Output Digital Output Analog Input/Output GND Digital Output Digital Output Digital Input Digital Input -- Pin Description Supply Voltage Low Voltage Digital input Analog Input/Output Push Pull 1X Push Pull 1X Analog Input/Output Ground Push Pull 1X Push Pull 2X Digital Input without Schmitt trigger Digital Input without Schmitt trigger Keep Floating or Connect to GND Ordering Information Part Number SLG7NT4375V SLG7NT4375VTR SLG7NT4375_DS_r101 Package Type V=STQFN-12 STQFN-12 – Tape and Reel (3k units) Page 3 3 SLG7NT4375 SKLAIO Absolute Maximum Conditions Parameter Min. Max. Unit VHIGH to GND -0.3 7 V Voltage at input pins -0.3 7 V Current at input pin -1.0 1.0 mA Storage temperature range -65 150 °C Junction temperature -- 150 °C Electrical Characteristics (@ 25°C, unless otherwise stated) Symbol Parameter VDD Supply Voltage TA Operating Temperature IQ Quiescent Current Maximal Voltage Applied to VO any PIN in High-Impedance State Maximal Average or DC IO Current VIH HIGH-Level Input Voltage VIL LOW-Level Input Voltage IIH IIL HIGH-Level Input Current LOW-Level Input Current VOH VOL IOH IOL HIGH-Level Output Voltage LOW-Level Output Voltage HIGH-Level Output Current LOW-Level Output Current VACMP0 Analog Comparator Threshold Voltage VACMP1 Analog Comparator Threshold Voltage TSU Start up Time SLG7NT4375_DS_r101 Condition/Note Static inputs and outputs Per Each Chip Side Logic Input, at VDD=3.3V Low-Level Logic Input, at VDD=3.3V Logic Input, at VDD=3.3V Low-Level Logic Input, at VDD=3.3V Logic Input PINs; VIN = VDD Logic Input PINs; VIN = 0V Push Pull, IOH = 3mA, 1X Driver, at VDD=3.3 V Push Pull, IOH = 3mA, 2X Driver, at VDD=3.3 V Push Pull, IOL = 3mA, 1X Driver, at VDD=3.3 V Push Pull, IOL = 3mA, 2X Driver, at VDD=3.3 V Push Pull & PMOS OD, VOH = 2.4 V, 1X Driver, at VDD=3.3 V Push Pull & PMOS OD, VOH = 2.4 V, 2X Driver, at VDD=3.3 V Push Pull, VOL =0.4V, 1X Driver, at VDD=3.3 V Push Pull, VOL =0.4V, 2X Driver, at VDD=3.3 V ACMP0 threshold including input offset, reference voltage variation and hysteresis. ACMP1 threshold including input offset, reference voltage variation and hysteresis. From VDD rising past 1.6V Min. 3 -40 -- Typ. 3.3 25 70 Max. 3.6 85 -- Unit V °C µA -- -- VDD V -- -- 90 mA 1.4 0.91 ---1.0 -1.0 ------- VDD VDD 1.65 0.95 1.0 1.0 2.73 3.13 -- 2.87 3.22 -- -- 0.15 0.28 -- 0.07 0.13 6.01 12.07 -- 12.01 24.13 -- 4.06 6.92 -- 8.13 13.84 -- 620 -- 677 mV 186 -- 214 mV -- 1 -- ms V V µA µA V V mA mA Page 4 4 SLG7NT4375 SKLAIO Functionality Waveforms Channel 1 (yellow/top line) – PIN#3 (SLP_S3#/DDR_VTT_CNTL) Channel 2 (light blue/2nd line) – PIN#6 (VDDQ(1.2V)) D0 – PIN#2 (VPP (2.5V)) D1 – PIN#11 (+V3P3A) D2 – PIN#10 (SLP_S4#) D3 – PIN#9 (VDDQ_EN) D4 – PIN#8 (VDDQ_BLEED) D5 – PIN#5 (VTT_EN) D6 – PIN#4 (VPP_EN) 1. Device general operation SLG7NT4375_DS_r101 Page 5 5 SLG7NT4375 SKLAIO D0 – PIN#10 (SLP_S4#) D1 – PIN#11 (+V3P3A) D2 – PIN#4 (VPP_EN) Channel 1 (yellow/top line) – PIN#3 (SLP_S3#/DDR_VTT_CNTL) D3 – PIN#9 (VDDQ_EN) Channel 2 (light blue/2nd line) – PIN#6 (VDDQ(1.2V)) D4 – PIN#8 (VDDQ_BLEED) 2. Enable PIN: SLP_S4# D0 – PIN#11 (+V3P3A) Channel 1 (yellow/top line) – PIN#3 (SLP_S3#/DDR_VTT_CNTL) D1 – PIN#5 (VTT_EN) 3. VTT_EN operation SLG7NT4375_DS_r101 Page 6 6 SLG7NT4375 SKLAIO Package Top Marking Datasheet Revision 1.01 Programming Code Number 004 Locked Status L Part Code Revision Date YV B 02/23/2015 The IC security bit is locked/set for code security for production unless otherwise specified. Revision number is not changed for bit locking. SLG7NT4375_DS_r101 Page 7 7 SLG7NT4375 SKLAIO Package Drawing and Dimensions 12 Lead STQFN Package JEDEC MO-220 SLG7NT4375_DS_r101 Page 8 8 SLG7NT4375 SKLAIO Tape and Reel Specification # of Package Type Pins STQFN 12L FCA 0.4P Green 12 Max Units Nominal Package Size (mm) per reel 1.6x1.6x0.55 3000 Trailer A per box Reel & Hub Size (mm) Pockets 3000 178/60 100 Leader B Pocket (mm) Length Length Pockets (mm) (mm) 400 100 400 Width Pitch 8 4 Carrier Tape Drawing and Dimensions Package Type STQFN 12L FCA 0.4P Green Pocket BTM Length (mm) Pocket BTM Width (mm) Pocket Depth (mm) Index Hole Pitch (mm) Pocket Pitch (mm) Index Hole Diameter (mm) Index Hole Index Hole to Tape to Pocket Tape Width Edge Center (mm) (mm) (mm) A0 B0 K0 P0 P1 D0 E F W 1.9 1.9 0.8 4 4 1.5 1.75 3.5 8 Refer to EIA-481 Specifications Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 1.408 mm3 (nominal). More information can be found at www.jedec.org. SLG7NT4375_DS_r101 Page 9 9 SLG7NT4375 SKLAIO Datasheet Revision History Date 03/27/2014 03/28/2014 04/02/2014 04/24/2014 04/28/2014 05/05/2014 05/23/2014 07/25/2014 08/25/2014 Version 0.10 0.11 0.12 0.13 0.14 0.15 0.16 0.17 0.18 09/03/2014 09/05/2014 09/25/2014 10/02/2014 10/03/2014 10/03/2014 11/06/2014 02/23/2015 0.19 0.20 0.21 0.22 0.23 0.24 1.00 1.01 SLG7NT4375_DS_r101 Change New designSLG46120 Corrected device functionality Change PIN5 name VTT to VTT_EN, correctedElectrical Characteristics Removed LATCH from VPP_EN, ACMP1 Vref changed to 200mV Added one more Functionality Waveform Added additional Functionality Waveforms Version update Updated Device Revision Table Added MSL “1” Renamed Package to FCA package Changed PIN11 name, updated functionality waveforms Removed one functionality waveform Updated Device Revision Table Changed Lock status Updated VIH, VIL logic levels Updated Device Revision Table Production Release Corrected VDDQ_EN output type Page 10 10 SLG7NT4375 SKLAIO Silego Website & Support Silego Technology Website Silego Technology provides online support via our website at http://www.silego.com/.This website is used as a means to make files and information easily available to customers. For more information regarding Silego Green products, please visit: http://greenpak.silego.com/ http://greenpak2.silego.com/ http://greenfet.silego.com/ http://greenfet2.silego.com/ http://greenclk.silego.com/ Products are also available for purchase directly from Silego at the Silego Online Store at http://store.silego.com/. Silego Technical Support Datasheets and errata, application notes and example designs, user guides, and hardware support documents and the latest software releases are available at the Silego website or can be requested directly at info@silego.com. For specific GreenPAK design or applications questions and GreenPAK@silego.com support please send email requests to Users of Silego products can receive assistance through several channels: Contact Your Local Sales Representative Customers can contact their local sales representative or field application engineer (FAE) for support. Local sales offices are also available to help customers. More information regarding your local representative is available at the Silego website or send a request to info@silego.com Contact Silego Directly Silego can be contacted directly via e-mail at info@silego.com or user submission form, located at the following URL: http://support.silego.com/ Other Information The latest Silego Technology press releases, listing of seminars and events, listings of worldwide Silego Technology offices and representatives are all available at http://www.silego.com/ THIS PRODUCT HAS BEEN DESIGNED AND QUALIFIED FOR THE CONSUMER MARKET. APPLICATIONS OR USES AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS ARE NOT AUTHORIZED. SILEGO TECHNOLOGY DOES NOT ASSUME ANY LIABILITY ARISING OUT OF SUCH APPLICATIONS OR USES OF ITS PRODUCTS. SILEGO TECHNOLOGY RESERVES THE RIGHT TO IMPROVE PRODUCT DESIGN, FUNCTIONS AND RELIABILITY WITHOUT NOTICE. SLG7NT4375_DS_r101 Page 11 11
SLG7NT4375VTR 价格&库存
很抱歉,暂时无法提供与“SLG7NT4375VTR”相匹配的价格&库存,您可以联系我们找货
