CFP2
■Terminal Pins: Straight
■Actuator Color: Gray
Ultra-Miniature
Pushbutton Switches
Washable
RoHS Compliant
■Features
■ Specifications
1. Ultra-miniature pushbutton switch for high density mounting.
2. Washable.
Rating
3. Terminal pin pitch: 2.54 mm.
Max.
0.4VA(28VDC max.)
Min.
1μA 20mVDC
Initial contact resistance 100m Ω max.
4. Independent detent mechanism ensures light operational feel.
5. Clip contact mechanism for long-term contact reliability.
6. Gold-plated contacts.
250VAC 1 minute
Insulation resistance
500MΩ min.(250VDC)
Electrical life
10,000 operations at max.rating,
30,000 operations at min.rating,
Mechanical life
30,000 cycles
Operating force
1.47±0.98N
Operating
temperature range
Storage
temperature range
■Part Numbering
CFP2
2
Series Actuator
Number of poles
Code
Type
Fig.
Number of poles
P
Pushbutton
1
1 pole
2
2 poles
R
R
−40∼+85℃
ON -(ON)
A
Terminal style
1 pole 2 poles Switching function
F
−40∼+85℃
C4
Switching function
(1.5mA 200μVAC)
Dielectric strength
Actuator shape
Fig.
Terminal style
Code
Actuator shape
C
P/C
A
Standard
C4
Right angle
W
Packaging spec
Code Packaging spec
W
Tray
C6 Vertical mounting
(ON)
:Momentary.
CFP2
SPDT
PC
Switching
function
Part No.
5-φ0.6~0.8
CFP2-1FC-AW
ON
(ON)
Connecting terminals
5−6
5−4
ON
2−3
5−6
(ON)
2−1
5−4
CFP2-1FC4-AW
ON
(ON)
5−6
5−4
ON
2−3
5−6
(ON)
2−1
5−4
(Top view)
PC Hole Layouts
Terminal numbers are not shown on the switch.
DPDT
PC
Switching
function
Part No.
☆CFP2-2RC-AW
6-φ0.6~0.8
(Top view)
PC Hole Layouts
SPDT
R/A
Switching
function
Part No.
5-φ0.6~0.8
(Top view)
PC Hole Layouts
DPDT
R/A
Switching
function
Part No.
☆CFP2-2RC4-AW
8-φ0.6~0.8
(Top view)
PC Hole Layouts
※ The above PC Hole Layouts are top view drawings.
■Optional Accessories
Part Name
Dimension
Gloss finish
Color Cap
ABS resin
:Optional Accessories.
《Sold separately》
Color
Part Number
White
140000481453
Red
140000481452
Black
140000481451
Gray
140000481450
The blue line shows the outline of the switch.
■Color Cap Mounting
(ON)
:Momentary.
☆:Semi-standard products.
CFP2
SPDT
V/M
Switching
function
Part No.
CFP2-1FC6-AW
ON
(ON)
5−6
5−4
ON
2−3
5−6
(ON)
2−1
5−4
5-φ0.8
(Top view)
PC Hole Layouts
DPDT
V/M
Switching
function
Part No.
☆CFP2-2RC6-AW
8-φ0.8
(Top view)
PC Hole Layouts
※ The above pcb hole dimengion, it is a top view drawiing when we fix the switch.
■Handling Specifications(CFP2)
1. Soldering Specifications
⑴Manual Soldering
Device:Soldering iron
350°
C, Max.; 3 seconds, Max.
⑵Auto Soldering
Device:Jet wave type or dip type
260°
C, Max.; 3-5 seconds, Max. (One time)
Total dip time: Within 10 seconds
・Pre-heating should be done at temperatures from
80°
C to 120°
C and within 120 seconds
⑶When soldering two or more terminals to a common
land, use solder resist to separate them
2. Flux Cleaning
⑴Solvents : Fluorine or Alcohol type
⑵Cleaning after soldering should be done after the
PC board is exposed to room temperature (30℃
or below) for 1 to 2 hours.
⑶Do not use ultrasonic cleaning.
■Packaging Specifications
Plastic Pack
100 pcs./pack
U
15
OK
SO
IS
JI
FU
J
FU
KU
231
(ON)
:Momentary.
196
很抱歉,暂时无法提供与“CFP2-2RC6-AW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+35.01360
- 10+30.31560
- 30+27.51840
- 国内价格 香港价格
- 1+51.421891+6.65603
- 10+44.4153510+5.74911
- 25+41.8900925+5.42224
- 50+40.0682650+5.18642
- 100+38.32336100+4.96056
- 300+35.70693300+4.62189
- 500+34.54980500+4.47212
- 1000+33.036741000+4.27627
