DR74-821-R
DR74-821-R
    EATON(伊顿)
    IND_7.6X7.6MM_SM
    820 µH 屏蔽 鼓芯,绕线式 电感器 310 mA 2.93 欧姆 非标准
DR74-821-R 数据手册
Technical Data 4315 Effective September 2017 Supersedes April 2014 DR High power density, high efficiency, shielded drum core power inductors Applications • • • • • • • Desktop and servers DVD and media players Portable and handheld devices LCD panels DC-DC converters Buck, boost, forward, and resonant converters Noise filtering and filter chokes Environmental data • Product features • • • • • • Four sizes of shielded drum core inductors Inductance range from 0.33 µH to 1000 µH Current range up to 56 A peak Magnetically shielded Secure mounting Ferrite core material • • Storage temperature range (component): -40 °C to +125 °C Operating temperature range: -40 °C to +125 °C (ambient plus self-temperature rise) Solder reflow temperature: J-STD-020 (latest revision) compliant Pb HF FREE HALOGEN  Technical Data 4315 Effective September 2017 Product specifications Rated Inductance (μH) OCL1 ±20% (μH) Irms2 (A) Isat3 (A) Peak DCR4 (Ω) Typ. Volt-μsec5 Typ. DR73-R33-R 0.33 0.306 6.21 14.4 0.0073 1.98 DR73-1R0-R 1.00 0.992 5.28 7.97 0.0102 3.56 DR73-1R5-R 1.50 1.482 4.67 6.52 0.0130 4.36 DR73-2R2-R 2.20 2.070 4.15 5.52 0.0165 5.15 DR73-3R3-R 3.30 3.540 3.31 4.22 0.0259 6.73 DR73-4R7-R 4.70 4.422 3.09 3.78 0.0297 7.52 DR73-6R8-R 6.80 6.480 2.55 3.12 0.0435 9.11 DR73-8R2-R 8.20 8.930 2.19 2.66 0.0592 10.7 DR73-100-R 10.0 10.30 2.08 2.47 0.0656 11.5 DR73-150-R 15.0 15.01 1.83 2.05 0.0844 13.9 DR73-220-R 22.0 22.65 1.62 1.67 0.107 17.0 DR73-330-R 33.0 34.41 1.31 1.35 0.166 21.0 DR73-470-R 47.0 48.62 1.08 1.14 0.241 24.9 DR73-680-R 68.0 68.91 0.89 0.96 0.358 29.7 DR73-820-R 82.0 80.37 0.86 0.89 0.384 32.1 DR73-101-R 100 101.4 0.73 0.79 0.527 36.0 DR73-151-R 150 150.9 0.58 0.65 0.851 44.0 Part Number DR73-221-R 220 223.3 0.52 0.53 1.05 53.5 DR73-331-R 330 325.5 0.42 0.44 1.59 64.5 DR73-471-R 470 465.8 0.35 0.37 2.36 77.2 DR73-681-R 680 676.5 0.29 0.31 3.47 93.1 DR73-821-R 820 821.7 0.27 0.28 3.93 103 DR73-102-R 1000 995.0 0.26 0.25 4.34 113 1. Open Circuit Inductance Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc. 2. RMS current for an approximate DT of 40 °C without core loss. It is recommended that the temperature of the part not exceed +125 °C. 3. Peak current for approximate 30% roll off at +20 °C. 4. DCR limits @ +20 °C. 5. Applied Volt-Time product (V-μs) across the inductor. This value represent the applied V-μsec 100 kHz necessary to generate a core loss equal to 10% of the total losses for 40 °C temperature rise. 2 www.eaton.com/electronics 6. Part number definition: DRxxx-yyy-R - DRxxx = product code and size, - yyy = inductance value in μH, - R = decimal point. If no R is present, third character = # of zeros - “-R” suffix = RoHS compliant Technical Data 4315 DR High power density, high efficiency, shielded drum core power inductors Effective September 2017 Product specifications Rated Inductance (μH) OCL1 ±20% (μH) Irms2 (A) Isat3 (A) Peak DCR4 (Ω) Typ. Volt-μsec5 Typ. DR74-R33-R 0.33 0.294 6.26 18.4 0.0074 1.71 DR74-1R0-R 1.00 0.952 5.39 10.2 0.0099 3.08 DR74-1R5-R 1.50 1.422 4.94 8.35 0.0118 3.76 DR74-2R2-R 2.20 1.986 4.76 7.06 0.0126 4.45 DR74-3R3-R 3.30 3.396 3.94 5.40 0.0183 5.81 DR74-4R7-R 4.70 5.182 3.34 4.37 0.0254 7.18 DR74-6R8-R 6.80 7.344 2.60 3.67 0.0418 8.55 DR74-8R2-R 8.20 8.566 2.53 3.40 0.0441 9.23 DR74-100-R 10.0 9.882 2.41 3.17 0.0489 9.92 DR74-150-R 15.0 16.09 2.11 2.48 0.0637 12.7 DR74-220-R 22.0 21.73 1.75 2.13 0.0925 14.7 DR74-330-R 33.0 33.01 1.41 1.73 0.143 18.1 DR74-470-R 47.0 49.64 1.15 1.41 0.216 22.2 DR74-680-R 68.0 69.67 1.03 1.19 0.265 26.3 DR74-820-R 82.0 80.95 0.91 1.11 0.345 28.4 DR74-101-R 100 101.6 0.86 0.99 0.383 31.8 DR74-151-R 150 150.0 0.69 0.81 0.591 38.6 DR74-221-R 220 227.0 0.56 0.66 0.907 47.5 DR74-331-R 330 335.6 0.45 0.54 1.41 57.8 DR74-471-R 470 465.3 0.40 0.46 1.74 68.1 Part Number DR74-681-R 680 671.2 0.33 0.38 2.58 81.7 DR74-821-R 820 812.7 0.31 0.35 2.93 89.9 DR74-102-R 1000 1009 0.27 0.31 3.89 100 1. Open Circuit Inductance Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc. 2. RMS current for an approximate DT of 40 °C without core loss. It is recommended that the temperature of the part not exceed +125 °C. 3. Peak current for approximate 30% roll off at +20 °C. 4. DCR limits @ +20 °C. 5. Applied Volt-Time product (V-μs) across the inductor. This value represent the applied V-μsec 100 kHz necessary to generate a core loss equal to 10% of the total losses for 40 °C temperature rise. 6. Part number definition: DRxxx-yyy-R - DRxxx = product code and size, - yyy = inductance value in μH, - R = decimal point. If no R is present, third character = # of zeros - “-R” suffix = RoHS compliant www.eaton.com/electronics 3 DR High power density, high efficiency, shielded drum core power inductors Technical Data 4315 Effective September 2017 Product specifications Part Number Rated Inductance (μH) OCL1 ±20% (μH) Irms2 (A) Isat3 (A) Peak DCR4 (Ω) Typ. Volt-μsec5 Typ. DR125-R47-R 0.47 0.456 17.6 33.0 0.0018 3.17 DR125-1R0-R 1.00 0.894 15.0 23.6 0.0024 4.43 DR125-1R5-R 1.50 1.478 13.8 18.3 0.0029 5.70 DR125-2R2-R 2.20 2.208 10.9 15.0 0.0045 6.97 DR125-3R3-R 3.30 3.084 9.26 12.7 0.0063 8.23 DR125-4R7-R 4.70 5.274 7.18 9.71 0.0105 10.8 DR125-6R8-R 6.80 6.588 6.64 8.68 0.0123 12.0 DR125-8R2-R 8.20 8.048 5.54 7.86 0.0176 13.3 DR125-100-R 10.0 9.654 5.35 7.17 0.0189 14.6 DR125-150-R 15.0 15.35 4.27 5.69 0.0298 18.4 DR125-180-R 18.0 17.70 3.81 5.32 0.0377 19.6 DR125-220-R 22.0 22.36 3.70 4.71 0.0396 22.2 DR125-330-R 33.0 33.74 3.28 3.84 0.0505 27.2 DR125-470-R 47.0 47.47 2.71 3.24 0.0740 32.3 DR125-560-R 56.0 55.24 2.31 3.00 0.102 34.8 DR125-680-R 68.0 67.91 2.22 2.70 0.101 38.6 DR125-820-R 82.0 86.89 2.05 2.39 0.128 43.7 DR125-101-R 100 102.7 1.78 2.20 0.170 47.5 DR125-151-R 150 151.1 1.48 1.81 0.248 57.6 DR125-221-R 220 216.8 1.19 1.51 0.384 69.0 DR125-331-R 330 332.6 1.06 1.22 0.482 85.5 DR125-471-R 470 473.1 0.87 1.02 0.718 102 DR125-681-R 680 679.8 0.70 0.85 1.10 122 DR125-821-R 820 828.0 0.60 0.77 1.49 135 DR125-102-R 1000 1008 0.57 0.70 1.69 149 DR125-472-R 4700 4720 0.268 0.32 7.53 322.4 DR125-124-R 120000 120630 0.060 0.069 150 1521 1. Open Circuit Inductance Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc. 2. RMS current for an approximate DT of 40 °C without core loss. It is recommended that the temperature of the part not exceed +125 °C. 3. Peak current for approximate 30% roll off at +20 °C. 4. DCR limits @ +20 °C. 5. Applied Volt-Time product (V-μs) across the inductor. This value represent the applied V-μsec 100 kHz necessary to generate a core loss equal to 10% of the total losses for 40 °C temperature rise. 4 www.eaton.com/electronics 6. Part number definition: DRxxx-yyy-R - DRxxx = product code and size, - yyy = inductance value in μH, - R = decimal point. If no R is present, third character = # of zeros - “-R” suffix = RoHS compliant Technical Data 4315 DR High power density, high efficiency, shielded drum core power inductors Effective September 2017 Product specifications Part Number Rated Inductance (μH) OCL1 ±20% (μH) Irms2 (A) Isat3 (A) Peak DCR4 (Ω) Typ. Volt-μsec5 Typ. DR127-R47-R 0.47 0.419 17.9 56.0 0.00195 3.50 DR127-1R0-R 1.00 0.821 15.5 40.0 0.00313 4.90 DR127-1R5-R 1.50 1.357 13.5 31.1 0.00341 6.30 DR127-2R2-R 2.20 2.027 12.5 25.5 0.00402 7.70 DR127-3R3-R 3.30 2.831 10.5 21.5 0.00567 9.10 DR127-4R7-R 4.70 4.841 8.25 16.5 0.00917 11.9 DR127-6R8-R 6.80 7.387 7.34 13.3 0.0116 14.7 DR127-8R2-R 8.20 8.861 6.32 12.2 0.0157 16.1 DR127-100-R 10.0 10.47 6.04 11.2 0.0172 17.5 DR127-150-R 15.0 14.09 5.03 9.66 0.0247 20.3 DR127-220-R 22.0 22.93 4.00 7.57 0.0391 25.9 DR127-330-R 33.0 33.92 3.23 6.22 0.0600 31.5 DR127-470-R 47.0 47.05 2.95 5.28 0.0719 37.1 DR127-680-R 68.0 66.48 2.44 4.44 0.105 44.1 DR127-820-R 82.0 79.75 2.09 4.06 0.143 48.3 DR127-101-R 100 99.31 1.96 3.64 0.163 53.9 DR127-151-R 150 144.9 1.59 3.01 0.247 65.1 DR127-221-R 220 221.5 1.29 2.43 0.376 80.5 DR127-331-R 330 323.6 1.04 2.01 0.574 97.3 DR127-471-R 470 467.1 0.85 1.68 0.861 117 DR127-681-R 680 676.7 0.76 1.39 1.08 141 DR127-821-R 820 818.1 0.65 1.27 1.47 155 DR127-102-R 1000 1005 0.61 1.14 1.66 172 1. Open Circuit Inductance Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc. 2. RMS current for an approximate DT of 40 °C without core loss. It is recommended that the temperature of the part not exceed +125 °C. 3. Peak current for approximate 30% roll off at +20 °C. 4. DCR limits @ +20 °C. 5. Applied Volt-Time product (V-μs) across the inductor. This value represent the applied V-μsec 100 kHz necessary to generate a core loss equal to 10% of the total losses for 40 °C temperature rise. 6. Part number definition: DRxxx-yyy-R - DRxxx = product code and size, - yyy = inductance value in μH, - R = decimal point. If no R is present, third character = # of zeros - “-R” suffix = RoHS compliant www.eaton.com/electronics 5 DR High power density, high efficiency, shielded drum core power inductors Technical Data 4315 Effective September 2017 Dimensions - mm DR73 BOTTOM VIEW FRONT VIEW TOP VIEW RECOMMENDED PAD LAYOUT SCHEMATIC 6.0 7.6 Max 2.0 1 2.50 7.6 Max 3.55 Max DR73 ### wllyy R 3.25 2 8.50 1.13 DR74 FRONT VIEW BOTTOM VIEW TOP VIEW RECOMMENDED PAD LAYOUT 7.6 Max 7.6 Max 2.0 1 2.50 4.35 Max DR74 ### wllyy R SCHEMATIC 3.25 2 1.13 8.50 DR125 FRONT VIEW BOTTOM VIEW RECOMMENDED PAD LAYOUT TOP VIEW SCHEMATIC 2.05 Typ. 13.80 1 4.90 2 Typ 1 12.50 Max 6.00 Max 1 DR125-### wwllyy R 2 5.50 2 12.50 Max 3.85 10 DR127 RECOMMENDED PAD LAYOUT TOP VIEW FRONT VIEW BOTTOM VIEW 2.05 Typ. SCHEMATIC 13.80 4.90 2 Typ 1 12.50 Max 10 8.00 Max 1 12.50 Max DR127-### wwllyy R 1 5.50 2 3.85 2 ### = Inductance value per family chart wllyy and wwllyy = (date code) R = revision level 6 www.eaton.com/electronics Technical Data 4315 DR High power density, high efficiency, shielded drum core power inductors Effective September 2017 Packaging information - mm DR73 Supplied in tape and reel packaging, 1350 parts per reel, 13" diameter reel. Ø1.50 +0.1/-0.0 12.00 2.00 ±0.1 Ø1.50 Min. A 4.00 1.75±0.10 1 7.50±0.1 DR73 ### wllyy R Bo ±0.3 ACTUAL SIZE DR73 2 Ao=7.90mm Bo=7.90mm Ko=3.80mm A Ao Ko User direction of feed SECTION A-A DR74 Supplied in tape and reel packaging, 1100 parts per reel, 13" diameter reel. Ø1.50 +0.1/-0.0 12.00 2.00 ±0.1 Ø1.50 Min. A 4.00 1.75±0.10 1 7.50±0.1 DR74 ### wllyy R Bo Ao=7.90mm Bo=7.90mm Ko=4.70mm ±0.3 ACTUAL SIZE DR74 2 A Ao Ko SECTION A-A User direction of feed DR125 4.0 Supplied in tape and reel packaging, 600 parts per reel,13" diameter reel +0.1/-0.0 2.0 1 min A 1.7 1 11.5 DR125-### wwllyy R B0 Ao=13.0mm Bo=13.0mm Ko=6.30mm +/-0.3 ACTUAL SIZE DR125 2 A0 A 16.00 K0 SECTION A-A User direction of feed DR127 4.0 Supplied in tape and reel packaging, 350 parts per reel, 13" diameter reel. +0.1/-0.0 2.0 A min 1.7 1 11.5 Ao=13.0mm Bo=13.0mm Ko=8.30mm DR127-### wwllyy R B0 +/-0.3 ACTUAL SIZE DR127 2 A0 K0 SECTION A-A 20.00 A User direction of feed www.eaton.com/electronics 7 DR High power density, high efficiency, shielded drum core power inductors Technical Data 4315 Effective September 2017 Inductance characteristics OCL vs I sat DR74 OCL vs I sat DR73 100 100 90 80 80 60 60 OCL (%) OCL (%) 70 50 40 40 30 20 20 10 0 0 20 40 60 80 100 120 140 0 160 % of I sat 0 20 40 60 OCL vs I sat DR125 140 160 180 90 80 80 70 70 60 60 OCL (%) OCL (%) 120 100 90 50 40 50 40 30 30 20 20 10 10 0 10 20 30 40 50 60 70 80 90 % of I sat 100 110 120 130 140 0 150 0 Core loss Irms Derating with Core Loss 0 10 30 50 70 z 25 kH kH z 50 Hz 0k 10 0k Hz 30 0k Hz 80 20 % of Losses from Irms (max) 60 90 92 94 95 96 97 98 99 10 20 30 40 60 80 100 200 % of Applied Volt-µsecond 8 100 OCL vs I sat DR127 100 0 80 % of I sat www.eaton.com/electronics 300 400 600 800 1000 10 20 30 40 50 60 70 80 % Isat 90 100 110 120 130 140 150 Technical Data 4315 DR High power density, high efficiency, shielded drum core power inductors Effective September 2017 Solder Reflow Profile TP TC -5°C Temperature TL 25°C Preheat A T smax Table 1 - Standard SnPb Solder (Tc) tP Max. Ramp Up Rate = 3°C/s Max. Ramp Down Rate = 6°C/s t Volume mm3 220°C 220°C Table 2 - Lead (Pb) Free Solder (T c) Tsmin Package Thickness 2.5mm ts Time 25°C to Peak Volume mm3 2000 260°C 245°C 245°C Time Reference JDEC J-STD-020 Profile Feature Preheat and Soak • Temperature min. (Tsmin) • Temperature max. (Tsmax) • Time (Tsmin to Tsmax) (ts) Average ramp up rate Tsmax to Tp Liquidous temperature (TL) Time at liquidous (tL) Peak package body temperature (TP)* Time (tp)** within 5 °C of the specified classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25°C to Peak Temperature Standard SnPb Solder 100°C Lead (Pb) Free Solder 150°C 150°C 200°C 60-120 Seconds 60-120 Seconds 3°C/ Second Max. 3°C/ Second Max. 183°C 60-150 Seconds 217°C 60-150 Seconds Table 1 Table 2 20 Seconds** 30 Seconds** 6°C/ Second Max. 6°C/ Second Max. 6 Minutes Max. 8 Minutes Max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States www.eaton.com/electronics © 2017 Eaton All Rights Reserved Printed in USA Publication No. 4315 BU-SB14112 September 2017 Eaton is a registered trademark. All other trademarks are property of their respective owners.
DR74-821-R
1. 物料型号:文档列出了多种型号的DR系列高功率密度、高效率、屏蔽鼓芯电源电感器。
2. 器件简介:这些电感器具有四种尺寸,电感范围从0.33微亨到1000微亨,峰值电流高达56A,具有磁屏蔽和安全安装的特点,使用铁氧体芯材料。
3. 引脚分配:文档中没有提供具体的引脚分配图,但提供了推荐的焊盘布局图。
4. 参数特性:详细列出了每个型号的额定电感、开路电感测试参数、峰值电流、直流电阻(DCR)、以及施加的电压-微秒产品等参数。
5. 功能详解:电感器适用于桌面和服务器、DVD和媒体播放器、便携和手持设备、LCD面板、DC-DC转换器、降压、升压、正向和共振转换器、噪声滤波和滤波扼流圈等。
6. 应用信息:适用于多种电子设备和转换器,包括但不限于上述功能详解中提到的应用。
7. 封装信息:提供了不同型号的尺寸信息,包括推荐焊盘布局和封装尺寸。
8. 环境数据:包括存储温度范围、操作温度范围和符合J-STD-020标准的焊接回流温度。
9. 符合性声明:产品符合无卤、RoHS标准。
10. 图表:文档包含了电感特性图、OCL与饱和电流的关系图、以及核心损耗与电流的关系图。
11. 焊接回流曲线:提供了不同封装厚度和体积的焊接回流温度曲线。
12. 生命周期支持政策:Eaton公司不授权未经公司官员明确书面批准,将其任何产品用于生命支持设备或系统。
DR74-821-R 价格&库存
很抱歉,暂时无法提供与“DR74-821-R”相匹配的价格&库存,您可以联系我们找货
