PIANO SWITCHES (HALF PITCH)
RoHS compliant
CHP
INTERNAL STRUCTURE
⑧
⑦
②
⑤
①
⑥
Part name
③
④
Material
■ FEATURES
①
Cover
Polyphenylenesulfide
②
Slider
Polyamide
③
Housing
④
Slider contact
⑤
Fixed contact
⑥
Terminal pin
⑦
Piano lever
Polyamide
⑧
Piano cover
Polyphenylenesulphide
RoHS compliant
High-reliability
Resin material is UL Recognized 94V-0
■ APPLICATIONS
● Communication
devices, AV • OA equipment and
computer peripherals
Stainless steel, Gold-plated
Copper alloy, Gold-plated
■ PART NUMBER DESIGNATION
C H P - 0 4 0 T B
Series name
No. of bits
02:2 bits
04:4 bits
08:8 bits
ON direction
0:Upper
1:Lower
※ Please refer to the LIST OF PART NUMBERS when placing orders.
Shape of terminal
A:J-hook
B:Gull wing
Form of packaging
T:Taping (Reel)
Blank:Bulk in plastic bag
CHP
■ LIST OF PART NUMBERS
No. of bits ON direction
Upper
2
Lower
Upper
4
Lower
Upper
8
Lower
Form of packaging
Taping
Plastic
Taping
Plastic
Taping
Plastic
Taping
Plastic
Taping
Plastic
Taping
Plastic
bag
bag
bag
bag
bag
bag
Shape of terminals
B(Gull wing)
CHP-020TA
CHP-020TB
CHP-020A
CHP-020B
CHP-021TA
CHP-021TB
CHP-021A
CHP-021B
CHP-040TA
CHP-040TB
CHP-040A
CHP-040B
CHP-041TA
CHP-041TB
CHP-041A
CHP-041B
CHP-080TA
CHP-080TB
CHP-080A
CHP-080B
CHP-081TA
CHP-081TB
CHP-081A
CHP-081B
A(J-hook)
Packaging quantity
500 pcs./reel
50 pcs./pack
500 pcs./reel
50 pcs./pack
500 pcs./reel
50 pcs./pack
500 pcs./reel
50 pcs./pack
500 pcs./reel
50 pcs./pack
500 pcs./reel
50 pcs./pack
※ Verify the above part numbers when placing orders.
Taping version can be supplied only in reel units.
■ STANDARD SPECIFICATIONS
Operating temp. range
− 40 ~ 85 °C
Contact rating
Non-switching
Switching
Minimum
Non-washable
Contact resistance
50 mΩ maximum
Approx. 0.16 g (CHP-02), Approx. 0.25 g (CHP-04),
Approx. 0.43 g (CHP-08)
Insulation resistance
1000 MΩ (DC100 V) minimum
Dielectric strength
AC500 V, 60 s
Storage temp. range
Sealing
Net weight
■ ELECTRICAL CHARACTERISTICS
■ MECHANICAL CHARACTERISTICS
Operation angle
22 °
Operating force
5 N {0.51 kgf} maximum
DC50 V 100 mA
DC6 V, 100 mA DC24 V, 25 mA
DC20 mV 1 μA
■ ENVIRONMENTAL CHARACTERISTICS
Vibration
(Amplitude) 1.5 mm or (Acceleration) 98 m/s2,
10-500 Hz, 3 directions for 10 cycles each
Shock
490 m/s2, 11 ms
6 directions for 3 times each
Stop strength
10 N {1.02 kgf} 60 s
Load life
Continuous load 1000 cycles,
DC6 ± 0.5 V, 100 ± 10 mA
Solderability
245 ± 3 °C, 2 ~ 3 s
Humidity
−10 ~ 65 °C, Relative humidity 0 ~ 96 %,
24 h for 10 cycles
Soldering heat
Reflow:255 °C (Peak temperature)
Please refer to the profile below)
Manual soldering:
350 ± 10 °C, 3 ~ 4 s
Shear (Adhesion)
5 N {0.51 kgf} 10 s
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
Pull-off strength
5 N {0.51 kgf} 10 s
{ } : Reference only
High temp. exposure
85 °C, 96 h
Low temp. exposure
−40 °C, 96 h
Thermal shock
−40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles
CHP
〈Reflow profile for soldering heat evaluation〉
Temperature
250
Peak : 250 0 ℃
+5
Over 230℃
200
Pre Heating Zone
180℃
150℃
150
90 ± 30 s
100
30 ± 10 s
50
Heating time
Soldering Zone
リフロー回数:2回 Reflow : two times maximum
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit : mm)
● CHP-021A
4.6
4.6
3.8
0.75
0.6
0.8
0.15 +0.1
–0.05
5.9
3.8
0.75
5.9
5.6 +0.3
–0.05
0.8
0.6
22°
22
Producion date code
Schematic
22°
4.6
0.1 ± 0.1
0.1 ± 0.1
4.6
Producion date code
Schematic
1.65 ± 0.2
0.6
22°
Producion date code
0.4 +0.1
–0.05
1.27 ± 0.15
8
0.75
0.8
0.4 min
0.75
8
5.9
0.6
0.8
0.15 +0.1
–0.05
4.6
Schematic
0.4 +0.1
–0.05
1.27 ± 0.15
1.65 ± 0.2
0.4 min
0.15 +0.1
–0.05
4.6
1.65 ± 0.2
● CHP-021B
0.4 min
● CHP-020B
0.4 +0.1
–0.05
1.27 ± 0.15
0.4 min
1.65 ± 0.2
5.9
0.4 +0.1
–0.05
1.27 ± 0.15
0.1 ± 0.1
0.1 ± 0.1
4.6
Schematic
4.6
Producion date code
5.6 +0.3
● CHP-020A
CHP
● CHP-041A
7.1
3.8
0.75
0.6
0.8
0.15 +0.1
–0.05
5.9
3.8
0.75
5.9
5.6 +0.3
–0.05
0.8
0.6
22°
22°
Producion date code
Producion date code
0.4 +0.1
–0.05
0.1 ± 0.1
1.65 ± 0.2
8
0.75
0.75
0.8
0.4 min
22°
Producion date code
4.6
4.6
Schematic
0.1 ± 0.1
0.4 +0.1
–0.05
1.65 ± 0.2
Schematic
0.4 +0.1
–0.05
1.27 ± 0.15
1.65 ± 0.2
● CHP-081A
12.2
12.2
3.8
0.6
0.8
0.15 +0.1
–0.05
0.75
3.8
0.75
5.9
5.6 +0.3
–0.05
0.8
0.6
22°
22°
Producion date code
0.4 +0.1
–0.05
1.27 ± 0.15
1.65 ± 0.2
Schematic
4.6
Schematic
0.1 ± 0.1
0.1 ± 0.1
4.6
Producion date code
0.4 +0.1
–0.05
1.27 ± 0.15
1.65 ± 0.2
5.6 +0.3
● CHP-080A
5.9
0.1 ± 0.1
0.6
22°
Producion date code
1.27 ± 0.15
0.15 +0.1
–0.05
7.1
8
5.9
0.6
0.8
0.4 min
0.15
7.1
+0.1
–0.05
1.65 ± 0.2
● CHP-041B
0.4 min
● CHP-040B
1.27 ± 0.15
5.9
0.1 ± 0.1
0.4 +0.1
–0.05
1.27 ± 0.15
Schematic
4.6
4.6
Schematic
0.4 min
7.1
5.6 +0.3
● CHP-040A
CHP
0.6
Producion date code
4.6
4.6
Schematic
0.1 ± 0.1
0.1 ± 0.1
22°
8
0.8
Producion date code
0.4 +0.1
–0.05
1.27 ± 0.15
0.4 min
22°
0.15 +0.1
–0.05
0.75
0.6
0.8
0.4 min
0.75
8
5.9
12.2
0.4 min
● CHP-081B
5.9
0.15
12.2
+0.1
–0.05
0.4 min
● CHP-080B
1.65 ± 0.2
Schematic
0.4 +0.1
–0.05
1.27 ± 0.15
1.65 ± 0.2
■ RECOMMENDED P.C.B. PAD DIMENSIONS
● 2 bits A type
B type
1.27
1.27
1.6
7.62
5.08
1.27
0.76
● 4 bits A type
0.76
B type
1.27 N (N = 1
3) = 3.81
3) = 3.81
1.27
1.6
7.62
5.08
1.27 N (N = 1
0.76
0.76
● 8 bits A type
B type
1.27 N (N = 1
7.62
1.27
1.6
0.76
7) = 8.89
7) = 8.89
5.08
1.27 N (N = 1
0.76
CHP
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs.,
etc.
● Taping version is boxed with two reels.
Maximum number of consecutive missing pieces=2
Leader length and reel dimension are shown in the diagrams below:
● Reel dimensions
Empty
Filled
End
Head
40 mm min.
17.4±1 (2, 4 bits)
25.4±1 (8 bits)
20 pitches min.
Leader
400 mm min.
Direction of feed
(Unit: mm)
(Conforms to JIS C 0806-3)
(In accordance with EIAJ ET-7200A)
φ 21±0.8
φ 50 min. (2, 4 bits)
φ 100±1 (8 bits)
Empty
2±0.5
φ 13±0.2
21.4±1 (2, 4 bits)
29.4±1 (8 bits)
φ 254±2
5.3
12±0.1
4±0.1
2±0.1
Ҿ͖ग़͠ํ
Direction of feed
Ҿ͖ग़͠ํ
Direction of feed
0.4±0.1
ணྫ (CHP-041A)
Installation example
16
2±0.1
5.3
〈Bulk pack specifications〉
● The smallest unit of bulk pack in a plastic bag is 10 pcs.
ணྫ (CHP-081B)
per pack. Orders will be accepted for unit of minimum
10 pcs., i.e., 10, 20, 30 pcs., etc.
● Boxing of bulk in a plastic bag is performed with 50 pcs.
(Standard 100 pcs.) per box.
0.4±0.1
24
φ 1.5 +0.1
11.5±0.1
● 8 bits
1.75±0.1
Ҿ͖ग़͠ํ
Direction of feed
12±0.1
4±0.1
1.75±0.1
ணྫ (CHP-021B)
φ 1.5 +0.1
(Unit : mm)
7.5±0.1
2±0.1
0.4±0.1
16
12±0.1
4±0.1
7.5±0.1
φ 1.5 +0.1
● 4 bits
1.75±0.1
● 2 bits
5.3
很抱歉,暂时无法提供与“CHP-040B”相匹配的价格&库存,您可以联系我们找货
