ROTARY CODED SWITCHES
S-8000
INTERNAL STRUCTURE
RoHS compliant
①
③
②
⑦
④
⑤
⑥
Part name
Material
■ FEATURES
①
Rotor
②
“O” ring
③
Base
④
Terminal pin
⑤
contact
⑥
P.C.B.
⑦
Housing
RoHS compliant
3 bits 8 positions type
Protection against dust and washable after soldering
DIP-pin configuration: 2.54 mm pitch
Resin material is UL Recognized 94HB
Polyoxymethylene
Silicone rubber
Polybutyleneterephthalate
Copper alloy, Gold-plated
Gold-plated epoxy board
■ PART NUMBER DESIGNATION
S - 8 0 1 0 W
Series name
Form of packaging
Shape of rotor
W:Tray packaging
Blank:Plastic bag
0:Without knob
1:With knob (extended shaft)
Setting position
0:Top setting
1:Side setting
Code format
1:Real code
3:Complementary code
■ LIST OF PART NUMBERS
Binary coded octal
Shape
Form of packaging
Tray packaging
Plastic bag
Top setting
Tray packaging
With knob
Plastic bag
Tray packaging
Without knob
Plastic bag
Side setting
Tray packaging
With knob
Plastic bag
Without knob
※ Verify the above part numbers when placing orders.
Tray version can be supplied only in tray units.
Real code
Complementary code
S-8010W
S-8010
S-8110W
S-8110
S-8011W
S-8011
S-8111W
S-8111
S-8030W
S-8030
S-8130W
S-8130
S-8031W
S-8031
S-8131W
S-8131
Packaging quantity
50 pcs./tray
100 pcs./pack
50 pcs./tray
100 pcs./pack
50 pcs./tray
100 pcs./pack
50 pcs./tray
100 pcs./pack
S-8000
■ STANDARD SPECIFICATIONS
Circuit type
■ ELECTRICAL CHARACTERISTICS
BCO (Real code, complementary code)
Operating temp. range
Contact rating
Non-switching
Switching
Minimum
−25 ~ 70 °C
Storage temp. range
Contact resistance
Sealing
Washable by “O” ring
※ Please refer to page 150,151
Insulation resistance
Dielectric strength
Net weight
Approx. 0.27 g (S-8010, S-8030)
Approx. 0.34 g (S-8110, S-8130)
Approx. 0.33 g (S-8011, S-8031)
Approx. 0.40 g (S-8111, S-8131)
■ MECHANICAL CHARACTERISTICS
No. of positions
490 m/s2, 11 ms
6 directions for 3 times each
10000 steps minimum
DC5 V, 100 mA
Load life
10 N {1.02 kgf} minimum
Humidity (Steady state)
245 ± 3 °C, 2 ~ 3 s
Solderability
AC250 V, 60 s
10-500-10 Hz, 3 directions for 2 h each
Shock
45°
Terminal strength
1000 MΩ (DC100 V) minimum
(Amplitude)1.5 mm or
2
(Acceleration)98 m/s ,
Vibration
36 mN·m {367 gf·cm} maximum
Stepping angle
100 mΩ maximum
■ ENVIRONMENTAL CHARACTERISTICS
8
Adjustment torque
Soldering heat
DC50 V 100 mA
DC5 V 100 mA
DC20 mV 1 μA
Flow : 260 ± 3 °C as the temperature in a
pot of molten solder, immersion from head
of terminal to backside of board, 5 ~ 6 s,
two times maximum
40 °C, Relative humidity 90 ~ 95 %, 240 h
High temp. exposure
70 °C, 96 h
Low temp. exposure
−25 °C, 96 h
Thermal shock
−25 (0.5 h) ~ 70 °C ( 0.5 h ), 5 cycles
Manual soldering:380 ± 10 °C, 3 ~ 4 s
{ } : Reference only
■ CODE FORMAT
No. of positions
8 positions
Positions
1
2
3
4
Real code 2
Code
1
4
Complementary code 2
1
4
5
7
6
● … Contact closed
S-8000
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance: ± 0.3 (Unit: mm)
0.6 W × 2.6 L × 1.2 D
3.9
40.5
4
4
C
2
7.2
7.62
C
1
2.54 2.54
7.2
4–0.6±0.1
t = 0.15
● S-8010 (Real code)
● S-8030 (Complementary code)
2
1
Part No. & Production date code
● S-8011 (Real code)
● S-8031 (Complementary code)
6.5
3.5±0.5
7.2
7.2
4
2
1
3.5
4–0.6±0.1
t = 0.15
2.54 2.54
2.54
C
3.9
6
7.2
40.5
7.62
4
4
φ3.6
2
7.2
2
C
C
1
5.9
● S-8111 (Real code)
● S-8131 (Complementary code)
0.7 W × 1D
7.2
3.5±0.5
6.5
6
φ3.6
7.2
5.9
4
2
2.54 2.54
1
4–0.6±0.1
t = 0.15
C
9.5
2.54
1
2.54 2.54
0.7 W × 1 D
4–0.6±0.1
t = 0.15
● S-8110 (Real code)
● S-8130 (Complementary code)
S-8000
S-8000端子接続
■ TERMINAL CONNECTION / P.C.B. THROUGH HOLE DIMENSIONS
Top setting
Real code
4 2 1
Complementary code
4 2 1
Side setting
Operating face
of real code
Terminal pin layout
(Bottom view)
P.C.B. dimensions
(Bottom view)
S–8000 case
4 2 1
C
C
2.54±0.1
4–φ0.8 hole
7.62±0.1
2.54±0.1
C
4 2 1
Operating face
4–φ0.8 hole
2.54±0.1
C
Operating face of
complementary code
S–8000 case
■ PACKAGING SPECIFICATIONS
● Tray version is packaged in 50 pcs. per tray. Orders will be accepted for units of 50 pcs., i. e., 50, 100, 150 pcs. etc.
● Tray version is boxed with 10 trays.
● The smallest unit of bulk pack in a plastic bag is 10 pcs. per pack.
Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs., etc.
● Boxing of bulk in a plastic bag is performed with 50 pcs. (standard 100 pcs.) per box.
(Unit: mm)
很抱歉,暂时无法提供与“S-8110”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+30.55956100+3.97265
