http://www.cincon.com/
REVISION: May 30, 2013 V14
EC5A SERIES
6-24WATT WIDE INPUT
DC-DC CONVERTERS
FEATURES
* 6-24W Non-Isolated Output
* DIP-24/SMD Package
* Efficiency to 94%
* Regulated Outputs
* Input LC Filter
MODEL
NUMBER
INPUT
VOLTAGE
OUTPUT
VOLTAGE
OUTPUT
CURRENT
EC5A-05S33
4.7-6 VDC
3.3 VDC
2000 mA
15 mA
1553 mA
85
DIP-24
EC5A-12S33
EC5A-12S05
9-32 VDC
9-32 VDC
3.3 VDC
5 VDC
2000 mA
2000 mA
15 mA
15 mA
655 mA
947 mA
84
88
DIP-24
DIP-24
EC5A-12S12
9-32 VDC
12 VDC
830 mA
954 mA
87
DIP-24
EC5A-12S15
9-32 VDC
15 VDC
666 mA
15 mA
15 mA
957 mA
87
DIP-24
EC5A-24S12
EC5A-24S15
16-32 VDC
19-32 VDC
12 VDC
15 VDC
1600 mA
1600 mA
15 mA
15 mA
860 mA
1064 mA
93
94
DIP-24
DIP-24
NOTE: 1. Nominal Input Voltage: 5, 12 or 24 VDC
1
INPUT CURRENT
CASE
NO LOAD FULL LOAD EFF.
SPECIFICATIONS
All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
NOTE:
Input Voltage Range ....……………..........….......... 5.0V ....................... 4.7-6V
12V ......................... 9-32V
24V ....................... 16-32V
24V ....................... 19-32V
Input Filter ………………………………………………….…….……..... LC Type
1. Measured from high line to low line.
2. Measured from full load to 10% load.
3. Suffix “S” to the model number with SMD packages.
4. Maximum case temperature under any operating condition should
not be exceeded 100℃ .
OUTPUT SPECIFICATIONS:
Voltage Accuracy .......................................................................... ±2.0% max.
Temperature Coefficient ………………………………………..…… ±0.05%/℃
Ripple & Noise, 20MHz BW ………… 3.3V/5V ……..…… 100mV pk-pk max.
12V/15V ……….……. 1% pk-pk max.
Over Current Protection …………………………….……………… 120 ~ 160%
Line Regulation (note1) …………………………………….........…±0.5% max.
Load Regulation (note2) …………..………….…….......……….... ±0.5% max.
Typical Derating curve for Natural Convection
120%
GENERAL SPECIFICATIONS:
71
-25
LOAD(%)
Efficiency .......................................................................................... See Table
Switching Frequency .................................................................. 150KHz typ.
Isolation Voltage (Input/Output) …………………………………… Non-Isolation
Operating Ambient Temperature Range .................................. -25℃ to +71℃
De-rating, Above 71℃ …………………… Linearly to Zero power at 100℃
Case Temperature (note4) ……………........................................ 100℃ max.
Cooling ……………………………………………….. Natural Convection
Storage Temperature Range ………....….......……........ -40℃ to +100℃
Dimensions …… DIP ….……..… 1.25x0.80x0.40 inches(31.8x20.3x10.2 mm)
SMD …..…..… 1.25x0.80x0.45 inches(31.8x20.3x11.4 mm)
Weight …………………………………………………………..…………... 17.8g
Case Material …………Black Coated Copper with Non-conductive Base
100%
80%
60%
Natural
Convection
40%
20%
0%
-25
100
50
75
Ambient Temperature(oC)
100
Case A Dimensions:
NOTE:Pin Size is 0.02±0.002 Inch (0.5±0.05 mm)DIA
All Dimensions In Inches (mm)
Tolerances
Inches: X.XX= ±0.02 , X.XXX= ±0.010
Millimeters: X.X= ±0.5 , X.XX=±0.25
CASE AS
PIN CONNECTION
SEE NOTE
Pin
BOTTOM
VIEW
TOP
1,24
VIEW
2,3
4,5
9,16
Function
DIP
SMD
NP
NC
-V Input
-V Output
10,15
11,14
NC
NP
NC
+V Output
12,13
NP
NC
20,21
NP
NC
22,23
+V Input
* NC-NO CONNECTION WITH PIN
* NP-NO PIN
2
很抱歉,暂时无法提供与“EC5A-12S05”相匹配的价格&库存,您可以联系我们找货
