9014M
Rev.H Aug.-2022
DATA SHEET
描述 / Descriptions
SOT-23 塑封封装 NPN 半导体三极管。Silicon NPN transistor in a SOT-23 Plastic Package.
特征 / Features
PC 大,hFE 高且特性好,与 9015M 互补,无卤产品。
High PC and hFE, excellent hFE linearity, complementary pair with 9015M,HF product.
用途 /
Applications
用于低电平、低噪声的前置放大器。
low frequency, low noise pre-amplifier.
内部等效电路 / Equivalent Circuit
引脚排列 / Pinning
PIN1:Base
PIN 2: Emitter
PIN 3:Collector
放大及印章代码 / hFE Classifications & Marking
hFE Classifications
Symbol
hFE Range
Marking
A
B
C
D
60~150
100~300
200~600
400~1000
HJ6A
HJ6B
HJ6C
HJ6D
http://www.fsbrec.com
1/6
9014M
Rev.H Aug.-2022
极限参数 /
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
数值
Rating
单位
Unit
Collector to Base Voltage
VCBO
50
V
Collector to Emitter Voltage
VCEO
45
V
Emitter to Base Voltage
VEBO
5.0
V
Collector Current
IC
100
mA
Collector Power Dissipation
PC
400
mW
Junction Temperature
Tj
150
Tstg
-55~150
Storage Temperature Range
电性能参数 / Electrical Characteristics(Ta=25℃)
参数
Parameter
Collector to Base Breakdown
Voltage
Collector to Emitter Breakdown
Voltage
Emitter to Base Breakdown
Voltage
Collector Cut-Off Current
符号
Symbol
测试条件
Test Conditions
最小值 典型值 最大值 单位
Min
Typ
Max
Unit
VCBO
IC=0.1mA
IE=0
50
V
VCEO
IC=1.0mA
IB=0
45
V
VEBO
IE=0.1mA
IC=0
5.0
V
ICBO
VCB=50V
IE=0
0.05
μA
Emitter Cut-off Current
IEBO
VEB=5.0V
IC=0
0.05
μA
DC Current Gain
Collector-Emitter Saturation
Voltage
Base-Emitter Saturation Voltage
hFE
VCE=5.0V
IC=1.0mA
VCE(sat)
IC=100mA
IB=5.0mA
0.14
0.3
V
VBE(sat)
IC=100mA
IB=5.0mA
0.84
1.0
V
Base-Emitter Voltage
VBE
VCE=5.0V
IC=2.0mA
0.63
0.7
V
Transition Frequency
fT
VCE=5.0V
VCB=10V
f=1.0MHz
VCE=5.0V
Rg=2.0KΩ
f=200Hz
IC=10mA
IE=0
Collector Output Capacitance
Cob
Noise Figure
NF
IC=0.2mA
f=1.0KHz
60
150
1000
270
MHz
2.2
3.5
pF
0.9
10
dB
2/6
9014M
Rev.H Aug.-2022
DATA SHEET
电参数曲线图 / Electrical Characteristic Curve
3/6
9014M
Rev.H Aug.-2022
DATA SHEET
外形尺寸图 / Package Dimensions
4/6
9014M
Rev.H Aug.-2022
DATA SHEET
印章说明 / Marking Instructions
HJ6A
说明:
H:
为公司代码
J6:
为型号代码
A:
为 hFE 档次代码
Note:
H:
Company Code
J6:
Product Type Code
A:
hFE Classifications Symbol Code
5/6
9014M
Rev.H Aug.-2022
DATA SHEET
回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free)
350
Temperature(℃)
300
245±5℃
250
5±0.5 sec
200
150
60~90 sec
100
50
60
80
100
120
140
160
180
200
220
240
260
280
Time(sec)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件 /
Resistance to Soldering Heat Test Conditions
温度:260±5℃
时间:10±1 sec.
Temp.:260±5℃
Time:10±1 sec
包装规格 / Packaging SPEC.
卷盘包装 / REEL
Package Type
封装形式
SOT-23
Dimension 包装尺寸 (unit:mm3)
Units 包装数量
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3,000
10
30,000
6
180,000
7〞×8
180×120×180
390×385×205
使用说明 / Notices
6/6
很抱歉,暂时无法提供与“9014M-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08457
- 500+0.06707
- 3000+0.05195
- 6000+0.04612
