BR100N03
BR100N03
    BLUEROCKET(蓝箭电子)
    TO-220-3
    MOSFETs N-Channel TO220 Vdss=30V Id=100A Vgss=±20V Pd=100W
BR100N03 数据手册
BR100N03 Rev.F Jul.-2018 描述 / DATA SHEET Descriptions TO-220 塑封封装 N 沟道 MOS 场效应管。N-CHANNEL MOSFET in a TO-220 Plastic Package. 特征 / Features 低栅电荷,低反馈电容,开关速度快。 Low gate charge, low crss, fast switching. 用途 / Applications 用于高功率 DC/DC 转换和功率开关。 These devices are well suited for high efficiency switching DC/DC converters and switch mode power supplies. 内部等效电路 引脚排列 12 / Equivalent Circuit / Pinning 3 PIN1:G 放大及印章代码 PIN 2:D PIN 3:S / hFE Classifications & Marking 见印章说明。 See Marking Instructions. http://www.fsbrec.com 1/6 BR100N03 Rev.F Jul.-2018 极限参数 DATA SHEET / Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit VDSS 30 V ID(Tc=25℃) 100 A IDM 400 A Gate-Source Voltage VGSS ±20 V Single Pulsed Avalanche Energy EAS 875 mJ PD(Tc=25℃) 100 W TJ,TSTG -55 to 150 ℃ Drain-Source Voltage Drain Current Peak Drain Current Total Power Dissipation Junction and Storage Temperature Range 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Zero Gate Voltage Drain Current 符号 Symbol BVDSS Zero Gate Voltage Drain Current IDSS VDS=30V VGS=0V 1 μA Gate-Body Leakage Current Forward IGSS VGS=±20V VDS=0V ±0.1 μA VDS=VGS ID=250μA 3.0 V IS=20A VGS=0V 1.5 V VGS=10V ID=50A 3.5 4.5 mΩ VGS=4.5V ID=40A 5.0 7.0 mΩ Gate Threshold Voltage VGS(th) Forward On Voltage VSD Static Drain-Source On-Resistance RDS(on) Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Charge QG Gate Source Charge QGS Gate Drain Charge 测试条件 Test Conditions VGS=0V ID=250μA VGS=0V VDS=15V f=1.0MHz 最小值 典型值 最大值 单位 Min Typ Max Unit 30 V 1.0 9500 pF 800 pF 300 pF 50 VDS=15V ID=16A VGS=5V 65 nC 20.8 nC QGD 19 nC Turn-On Delay Time td(on) 25.7 50 ns Turn-On Rise Time tr 10 20 ns Turn-Off Delay Time td(off) 128 200 ns 34 70 ns Turn-Off Fall Time http://www.fsbrec.com tf VDD=15V RGEN=6Ω ID=1A VGS=10V 2/6 BR100N03 Rev.F Jul.-2018 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 BR100N03 Rev.F Jul.-2018 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 BR100N03 Rev.F Jul.-2018 印章说明 / DATA SHEET Marking Instructions BR **** 100N03  说明: BR: 为公司代码 100N03: 为型号代码 ****:  为生产批号代码,随生产批号变化。  Company Code Note: BR:   100N03: ****: http://www.fsbrec.com Product Type.  Lot No. Code, code change with Lot No. 5/6 BR100N03 Rev.F Jul.-2018 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:270±5℃ 包装规格 Package Type 封装形式 TO-220/F 套管包装 Package Type 封装形式 使用说明 Temp.:270±5℃ Time:10±1 sec / Packaging SPEC. 散件包装 TO-220/F 时间:10±1 sec. / BULK Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) Units/Bag 只/袋 Bags/Inner Box 袋/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Bag 袋 Inner Box 盒 Outer Box 箱 200 10 2,000 5 10,000 135×190 237×172×102 560×245×195 Units/Tube 只/套管 Tubes/Inner Box 套管/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Tube 套管 Inner Box 盒 Outer Box 箱 50 20 1,000 5 5,000 532×31.4×5.5 555×164×50 575×290×180 / TUBE Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) / Notices http://www.fsbrec.com 6/6
BR100N03 价格&库存
很抱歉,暂时无法提供与“BR100N03”相匹配的价格&库存,您可以联系我们找货
BR100N03
  • 5+2.85034
  • 50+2.31282
  • 150+2.10071
  • 500+1.83600
库存:755
