2SD882T
Rev.F Mar.-2019
DATA SHEET
Descriptions
SOT-89 塑封封装 NPN 半导体三极管。Silicon NPN transistor in a SOT-89 Plastic Package.
特征
/ Features
饱和压降 VCE(sat)小,hFE 高且线性极好。无卤产品。
Low saturation voltage, excellent hFE linearity and high hFE. HF Product.
用途
Applications
用于 3 瓦音频放大输出,电压调节器,电源转换和继电器驱动。
Output stage of 3 watts audio amplifier, voltage regulator, DC-DC converter and relay driver.
内部等效电路
引脚排列
1
2
/ Pinning
3
PIN1:Base
印章代码
/ Equivalent Circuit
PIN 2:Collector
PIN 3:Emitter
/ Marking
E
60~120
H82R
100~200
H82Q
160~320
H82P
200~400
H82E
P
Q
http://www.fsbrec.com
R
hFE Classifications
Symbol
hFE Range
Marking
1/6
2SD882T
Rev.F Mar.-2019
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
数值
Rating
单位
Unit
Collector to Base Voltage
VCBO
40
V
Collector to Emitter Voltage
VCEO
30
V
Emitter to Base Voltage
VEBO
5.0
V
Collector Current-Continuous
IC
3.0
A
Collector Power Dissipation
PC
500
mW
Junction Temperature
Tj
150
Tstg
-55~150
Storage Temperature Range
电性能参数
/ Electrical Characteristics(Ta=25℃)
参数
Parameter
符号
Symbol
测试条件
Test Conditions
最小值 典型值 最大值 单位
Min
Typ
Max
Unit
Collector Cut-Off Current
ICBO
VCB=30V
IE=0
1.0
μA
Emitter Base Cut-Off Current
IEBO
VEB=3.0V
IC=0
1.0
μA
hFE(1)
VCE=2.0V
IC=1.0A
60
160
hFE(2)
VCE=2.0V
IC=20mA
30
150
DC Current Gain
400
Collector to Emitter Saturation
Voltage
VCE(sat)
IC=2.0A
IB=0.2A
0.3
0.5
V
Base to Emitter Saturation Voltage
VBE(sat)
IC=2.0A
IB=0.2A
1.0
2.0
V
fT
VCE=5.0V
IC=0.1A
90
MHz
Cob
VCB=10V
f=1.0MHz
IE=0
45
pF
Transition Frequency
Collector Output Capacitance
2/6
2SD882T
Rev.F Mar.-2019
DATA SHEET
电参数曲线图
/ Electrical Characteristic Curve
3/6
2SD882T
Rev.F Mar.-2019
外形尺寸图
DATA SHEET
/ Package Dimensions
4/6
2SD882T
Rev.F Mar.-2019
印章说明
DATA SHEET
Marking Instructions
H82R
说明:
H:
为公司代码
82:
为型号代码
R:
为 hFE 分档代码
为生产批号代码,随生产批号变化。
Note:
H:
Company Code.
82:
Product Type.
R:
hFE Classifications Symbol
Lot No. Code, code change with Lot No.
5/6
2SD882T
Rev.F Mar.-2019
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 25~150℃,时间 60~90sec;
1.Preheating:25~150℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Time:10±1 sec
/ REEL
Package Type
封装形式
使用说明
Temp.:260±5℃
/ Packaging SPEC.
卷盘包装
SOT-89
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
1,000
7
7,000
6
42000
7〞×12
180×120×180
390×385×205
/ Notices
6/6
很抱歉,暂时无法提供与“2SD882T-P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.35640
- 50+0.21010
- 1000+0.18920
- 国内价格
- 10+0.52413
- 100+0.43643
- 300+0.39269
- 1000+0.35986
