BRCS2302MA
Rev.I Mar.-2020
DATA SHEET
描述 / Descriptions
SOT-23 塑封封装 N 沟道 MOS 场效应管。
N- CHANNEL MOSFET in a SOT-23 Plastic Package.
特征 / Features
芯片采用超高密度元胞设计技术,RDS(ON)导通电阻小,SOT-23 封装。
Super high dense cell design for low RDS(ON),SOT-23 package.
用途 /
Applications
电池管理,高速开关,低功率 DC-DC 转换。
Battery management,High speed switch,low power DC to DC converter.
内部等效电路 / Equivalent Circuit
引脚排列 / Pinning
3
1
2
PIN1:G
PIN 2:S
PIN 3:D
印章代码 / Marking
Marking
http://www.fsbrec.com
A2H
1/6
BRCS2302MA
Rev.I Mar.-2020
极限参数 /
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
数值
Rating
单位
Unit
Drain-Source Voltage
VDSS
V
Gate-Source Voltage
VGSS
±8
V
Drain Current – Continuous
ID
3.0
A
Pulsed Drain Current
IDM
10
A
Continuous Source Current
IS
0.95
A
Power Dissipation
PD
0.9
W
Storage Temperature Range
Tstg
-55~150
电性能参数 / Electrical Characteristics(Ta=25℃)
参数
Parameter
Drain–Source Breakdown Voltage
符号
Symbol
V(BR)DSS
测试条件
Test Conditions
VGS=0
ID=10μA
最小值 典型值 最大值 单位
Min
Typ
Max Unit
V
Zero Gate Voltage Drain Current
IDSS
VGS=0
VDS=20V
1.0
μA
Gate–Body Leakage.
IGSS
VGS=±8V
VDS=0V
±100
nA
Static Drain–Source
On–Resistance
RDS(on)1
VGS=4.5V
ID=3.6A
34
60
mΩ
RDS(on)2
VGS=2.5V
ID=3.1A
41
115
mΩ
gFS
VDS=5V
ID=3.6A
8
VSD
VGS=0V
ID=1.25A
VGS(th)
VDS=VGS
ID=50μA
0.50
State Drain Current
ID(on)
VDS=5V
VGS=2.5V
4
Turn–On Delay Time
td(on)
Turn–On Rise Time
tr
Turn–Off Delay Time
td(off)
Forward Transconductance
Drain–Source Diode Forward
Voltage
Gate Threshold Voltage
Turn–Off Fall Time
tf
S
1.2
V
1.0
V
A
7
VDD=10V
VGEN=4.5V
RGEN=6Ω
ID=3.6A
55
RL=2.8Ω
15
ns
10
2/6
BRCS2302MA
Rev.I Mar.-2020
DATA SHEET
电参数曲线图 / Electrical Characteristic Curve
3/6
BRCS2302MA
Rev.I Mar.-2020
DATA SHEET
外形尺寸图 / Package Dimensions
4/6
BRCS2302MA
Rev.I Mar.-2020
DATA SHEET
印章说明 / Marking Instructions
A2H
说明:
A2:
为型号代码
H:
为公司代码
Note:
A2:
Product Type Code
H:
Company Code.
5/6
BRCS2302MA
Rev.I Mar.-2020
DATA SHEET
回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件 /
Resistance to Soldering Heat Test Conditions
温度:260±5℃
时间:10±1 sec.
Temp.:260±5℃
Time:10±1 sec
包装规格 / Packaging SPEC.
卷盘包装 / REEL
Package Type
封装形式
SOT-23
Dimension 包装尺寸 (unit:mm3)
Units 包装数量
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3,000
10
30,000
6
180,000
7〞×8
180×120×180
390×385×205
使用说明 / Notices
6/6
很抱歉,暂时无法提供与“BRCS2302MA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.08604
- 50+0.05311
- 150+0.03284
- 500+0.02928
- 3000+0.02622
- 6000+0.02455
- 国内价格
- 1+0.46640
- 200+0.15510
- 1500+0.09713
- 3000+0.07689
