MB1S~MB10S
Rev.E Nov.-2020
DATA SHEET
描述 / Descriptions
0.8A 表面贴装玻璃钝化整流桥,MBS 封装。
0.8A Surface Mount Glass Passivated Bridge Rectifier, MBS package.
特征 / Features
玻璃钝化芯片,反向电压:100V~1000V,正向电流:0.8A,浪涌电流大,适用于表面贴装。无卤产
品。
Glass Passivated Chip Junction, Reverse Voltage:100to1000V, Forward Current:0.8 A, High Surge
Current Capability, Designed for Surface Mount Application.Halogen free product.
用途 /
Applications
一般用途.
General purpose.
内部等效电路 / Equivalent Circuit
引脚排列 / Pinning
印章代码 / Marking
见印章说明。See Marking Instructions.
http://www.fsbrec.com
1/7
MB1S~MB10S
Rev.E Nov.-2020
极限参数 /
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
Maximum Repetitive Peak
Reverse Voltage
Maximum RMS voltage
Maximum DC Blocking
Voltage
Average Rectified Output
Currentat Ta = 50℃
Peak Forward Surge
Current 8.3 ms Single Half
Sine Wave Superimposed
on Rated Load (JEDEC
Method)
Typical Junction
(Note1)
Capacitance
Typical Thermal
(Note2)
Resistance
Typical Thermal
(Note2)
Resistance
Operating and Storage
Temperature Range
数值
Rating
单位
Unit
MB1S
MB2S
MB4S
MB6S
MB8S
MB10S
VRRM
100
200
400
600
800
1000
V
VRMS
70
140
280
420
560
700
V
VDC
100
200
400
600
800
1000
V
Io
0.8
A
IFSM
30
A
Cj
13
pF
RθJA
95
℃/W
RθJL
30
℃/W
Tj,Tstg
-55~+150
Note:
1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2
2. Mounted on glass epoxy PC board with 4×( 5×5mm )copper pad..
电性能参数 / Electrical Characteristics(Ta=25℃)
参数
Parameter
符号
Symbol
Maximum Forward
Voltage
VF
Maximum DC
Reverse Current at
Maximum DC
Blocking Voltage
IR
测试条件
Test
condition
数值
Rating
IF=0.4A
1.0
IF=0.8A
1.1
Ta=25℃
Ta=125℃
5.0
40
单位
Unit
V
μA
2/7
MB1S~MB10S
Rev.E Nov.-2020
DATA SHEET
电参数曲线图 / Electrical Characteristic Curve
3/7
MB1S~MB10S
Rev.E Nov.-2020
DATA SHEET
外形尺寸图 / Package Dimensions
4/7
MB1S~MB10S
Rev.E Nov.-2020
DATA SHEET
印章说明 / Marking Instructions
5/7
MB1S~MB10S
Rev.E Nov.-2020
DATA SHEET
MB1S
说明:
MB1S:
为型号代码
为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码
Note:
MB1S:
Product Type Code
Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot
No Code
6/7
MB1S~MB10S
Rev.E Nov.-2020
DATA SHEET
回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 25~150℃,时间 60~90sec;
1.Preheating:25~150℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件 /
Resistance to Soldering Heat Test Conditions
温度:260±5℃
时间:10±1 sec.
Temp.:260±5℃
Time:10±1 sec
包装规格 / Packaging SPEC.
卷盘包装 / REEL
Package Type
封装形式
MBS
Dimension 包装尺寸 (unit:mm3)
Units 包装数量
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3000
2
6000
7
42000
13〞×12
336X336X40
380X335X366
使用说明 / Notices
7/7
很抱歉,暂时无法提供与“MB6S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.16222
- 100+0.12723
- 300+0.10779
- 3000+0.09224
- 国内价格
- 1+0.32230
- 200+0.10736
- 1500+0.06710
- 3000+0.05335
