S2A~S2M
Rev. B Mar.-2021
DATA SHEET
描述 / Descriptions
表面贴装整流二极管,反向电压:50V~1000V,正向电流:2.0A,SMA 封装。
Surface Mount General Purpose Silicon Rectifiers, Reverse Voltage:50 to1000V,Forward
Current:2.0A ,SMA package.
特征 / Features
玻璃钝化芯片,无铅符合欧盟 RoHS 指令 2011/65/EU,适用表面贴装。无卤产品。
Glass Passivated Chip Junction, Lead free in comply with EU RoHS 2011/65/EU directives, For
surface mounted applications. HF product.
用途 /
Applications
一般用途.
General purpose.
内部等效电路 / Equivalent Circuit
引脚排列 / Pinning
印章代码 / Marking
见印章说明。See Marking Instructions.
http://www.fsbrec.com
1/6
S2A~S2M
Rev. B Mar.-2021
极限参数 /
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
Maximum Repetitive Peak
Reverse Voltage
Maximum RMS voltage
Maximum DC Blocking
Voltage
Maximum Average
Forward Rectified Current
Peak Forward Surge
Current 8.3 ms Single Half
Sine Wave Superimposed
on Rated Load
(JEDEC Method)
Typical Junction
Capacitance at
VR=4V f=1MHz
Typical Thermal
Resistance 1
Operating and Storage
Temperature Range
数值
Rating
单位
Unit
S2A
S2B
S2D
S2G
S2J
S2K
S2M
VRRM
50
100
200
400
600
800
1000
V
VRMS
35
70
140
280
420
560
700
V
VDC
50
100
200
400
600
800
1000
V
IF(AV)
2.0
A
IFSM
50
A
Cj
25
pF
RθJA
65
℃/W
-55~+150
Tj,Tstg
Note:
1)P.C.B. mounted with 2.0 X 2.0" (5 X5cm) copper pad areas.
电性能参数 / Electrical Characteristics(Ta=25℃)
参数
Parameter
Maximum
Instantaneous
Forward Voltage
Maximum DC
Reverse Current
at Rated DC
Blocking Voltage
符号
Symbol
VF
测试条件
Test
Conditions
数值
Rating
S2A
S2B
S2D
S2G
S2J
S2K
S2M
单位
Unit
IF=2.0A
1.1
V
Ta=25℃
5.0
μA
Ta=125℃
100
μA
IR
2/6
S2A~S2M
Rev. B Mar.-2021
DATA SHEET
电参数曲线图 / Electrical Characteristic Curve
3/6
S2A~S2M
Rev. B Mar.-2021
DATA SHEET
外形尺寸图 / Package Dimensions
SMA
4/6
S2A~S2M
Rev. B Mar.-2021
DATA SHEET
印章说明 / Marking Instructions
5/6
S2A~S2M
Rev. B Mar.-2021
DATA SHEET
回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 25~150℃,时间 60~90sec;
1.Preheating:25~150℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件 /
Resistance to Soldering Heat Test Conditions
温度:260±5℃
时间:10±1 sec.
Temp.:260±5℃
Time:10±1 sec
包装规格 / Packaging SPEC.
卷盘包装 / REEL
Package Type
封装形式
SMA
Units 包装数量
Dimension 包装尺寸 (unit:mm3)
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
5000
2
10000
7
70000
13〞×12
336X336X40
380X335X366
使用说明 / Notices
6/6
很抱歉,暂时无法提供与“S2M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.22770
- 500+0.07568
- 2500+0.05049
- 5000+0.04136
