RS1AF~RS1MF
Rev.G Aug.-2018
DATA SHEET
Descriptions
快恢复二极管,反向电压:50V~1000V,正向电流:1.0A,薄型 SMAF 封装。
Surface Mount Fast Recovery Rectifiers, Reverse Voltage:50 to1000V,Forward Current:1.0A ,SMAF
thin package.
特征
/ Features
玻璃钝化芯片,反向恢复时间快,无铅符合欧盟 RoHS 指令 2011/65/EU,适用表面贴装。无卤产品。
Features: Glass Passivated Chip Junction,Fast reverse recovery time,Lead free in comply with EU
ROHS 2011/65/EU directives,For surface mounted applications.Halogen free product.
用途
Applications
一般用途.
General purpose.
内部等效电路
/ Equivalent Circuit
引脚排列
/ Pinning
印章代码
/ Marking
见印章说明。See Marking Instructions.
http://www.fsbrec.com
1/7
RS1AF~RS1MF
Rev.G Aug.-2018
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
Maximum Repetitive Peak
Reverse Voltage
Maximum RMS voltage
数值
Rating
RS1AF
RS1BF
RS1DF
RS1GF
RS1JF
RS1KF
RS1MF
VRRM
50
100
200
400
600
800
1000
V
VRMS
35
70
140
280
420
560
700
V
400
600
800
1000
V
Maximum DC Blocking
VDC
50
100
200
Voltage
Maximum Average
Forward Rectified Current
IF(AV)
at Ta = 65℃
Peak Forward Surge
Current 8.3 ms Single Half
Sine Wave Superimposed
IFSM
on Rated Load
(JEDEC Method)
Typical Junction
Ci
1)
Capacitance
Typical Thermal
RθJA
Resistance 2)
Operating and Storage
Tj,Tstg
Temperature Range
Note:
1)Measured at 1MHz and applied reverse voltage of 4V D.C
2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
电性能参数
单位
Unit
1.0
A
30
A
15
pF
80
℃/W
-55~+150
/ Electrical Characteristics(Ta=25℃)
参数
Parameter
Maximum
Instantaneous
Forward Voltage
Maximum DC
Reverse Current
at Rated DC
Blocking Voltage
Maximum
Reverse Recovery
Time
符号
Symbol
VF
测试条件
Test
Conditions
数值
Rating
RS1AF
RS1BF
RS1DF RS1GF
RS1JF
RS1KF RS1MF
单位
Unit
IF=1.0A
1.3
V
Ta=25℃
5.0
μA
Ta=125℃
50
μA
IR
IF=0.5A
trr
IR=1.0A
Irr=0.25A
150
250
500
ns
2/7
RS1AF~RS1MF
Rev.G Aug.-2018
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
3/7
RS1AF~RS1MF
Rev.G Aug.-2018
外形尺寸图
DATA SHEET
/ Package Dimensions
4/7
RS1AF~RS1MF
Rev.G Aug.-2018
印章说明
DATA SHEET
5/7
RS1AF~RS1MF
Rev.G Aug.-2018
印章说明
DATA SHEET
RS1A
说明:
RS1A: 为型号代码
: 为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码
Note:
RS1A: Product Type Code
****: Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot No
Code
6/7
RS1AF~RS1MF
Rev.G Aug.-2018
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Time:10±1 sec
/ REEL
Package Type
封装形式
使用说明
Temp.:260±5℃
/ Packaging SPEC.
卷盘包装
SMAF
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3000
5
15000
5
75000
7〞×11
185X180X105
390X385X205
/ Notices
7/7
很抱歉,暂时无法提供与“RS1MF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08597
- 500+0.06750
- 3000+0.05508
