SS510C
SS510C
    BLUEROCKET(蓝箭电子)
    SMC(DO-214AB)
    肖特基二极管 SMC Vrrm=100V If=5A Ifsm=150A Ci=400pF
SS510C 数据手册
SS52C~SS520C Rev. B Feb.-2021 DATA SHEET 描述 / Descriptions 表面贴装肖特基整流二极管,反向电压:20~200V,正向电流:5.0A,SMC 封装。 Surface Mount Schottky Barrier Rectifier, Reverse Voltage:20 to 200 V, Forward Current:5.0A ,SMC package. 特征 / Features 低功耗,高效率,正向浪涌电流大,适用于低压高频逆变器和极性保护,适用于表面贴装,无卤产品。 Low power loss, high efficiency, High forward surge current capability, For use in low voltage, high frequency inverters, and polarity protection applications,For surface mounted applications,Halogen free product. 用途 / Applications 一般用途. General purpose. 内部等效电路 / Equivalent Circuit 引脚排列 / Pinning 印章代码 / Marking 见印章说明。See Marking Instructions. http://www.fsbrec.com 1/7 SS52C~SS520C Rev. B Feb.-2021 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol Maximum Repetitive Peak Reverse Voltage Maximum RMS voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) Typical Junction 1) Capacitance Typical Thermal 2) Resistance Operating Junction Temperature Range Storage Temperature Range 数值 Rating SS52C SS54C SS56C SS58C SS510C SS512C SS515C SS520C 单位 Unit VRRM 20 40 60 80 100 120 150 200 V VRMS 14 28 42 56 70 84 105 140 V VDC 20 40 60 80 100 120 150 200 V IF(AV) IFSM Ci A 5.0 175 150 600 400 A pF RθJA 35 ℃/W Tj -55~+150 ℃ Tstg -55~+150 ℃ Note: 1) Measured at 1MHz and applied reverse voltage of 4 V D.C. 2) P.C.B. mounted with 2.0 X 2.0" (5 X 5 cm) copper pad areas. 电性能参数 / Electrical Characteristics(Ta=25℃) 数值 Rating 测试条 参数 Parameter Max Instantaneo us Forward Voltage Maximum DC Reverse Current at Rated DC Reverse Voltage 符号 Symbol VF 件 Test SS52C SS54C Conditions IF=5.0A 0.55 SS56C SS58C SS510C SS512C SS515C SS520C 0.70 0.85 Ta=25℃ 1.0 Ta=100℃ 50 单位 Unit V mA IR http://www.fsbrec.com 2/7 SS52C~SS520C Rev. B Feb.-2021 DATA SHEET 电参数曲线图 / Electrical Characteristic Curve http://www.fsbrec.com 3/7 SS52C~SS520C Rev. B Feb.-2021 DATA SHEET 外形尺寸图 / Package Dimensions http://www.fsbrec.com 4/7 SS52C~SS520C Rev. B Feb.-2021 DATA SHEET 印章说明 / Marking Instructions http://www.fsbrec.com 5/7 SS52C~SS520C Rev. B Feb.-2021 DATA SHEET 印章说明 / Marking Instructions SS52 **** 说明 SS52: **** : 为型号代码 为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码 Note: SS52: ****: Product Type Code Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot No Code http://www.fsbrec.com 6/7 SS52C~SS520C Rev. B Feb.-2021 DATA SHEET 回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 245±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:245±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:260±5℃ 时间:10±1 sec. Temp.:260±5℃ Time:10±1 sec 包装规格 / Packaging SPEC. 卷盘包装 / REEL Package Type 封装形式 SMC Dimension 包装尺寸 (unit:mm3) Units 包装数量 Units/Reel 只/卷盘 Reels/Inner Box 卷盘/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Reel Inner Box 盒 Outer Box 箱 3000 2 6000 6 36000 13〞×16 337X337X49 380X335X366 使用说明 / Notices http://www.fsbrec.com 7/7
SS510C
物料型号为 SS52C 至 SS520C。
这些是表面贴装肖特基整流二极管,具有不同的反向电压和正向电流规格。
例如,SS52C 的反向电压为 20V,正向电流为 5.0A。
器件简介:这些二极管具有低功耗、高效率、高正向浪涌电流能力,适用于低压高频逆变器和极性保护应用,也适用于表面贴装,是无卤产品。
引脚分配:二极管有两个引脚,1 为阴极(Cathode),2 为阳极(Anode)。
参数特性:包括最大重复峰值反向电压(VRRM)、最大有效值电压(VRMS)、最大直流阻断电压(Voc)、最大平均正向整流电流(IF(AV))、峰值正向浪涌电流(IFSM)、典型结电容(Ci)、典型热阻(RBJA)、工作结温范围(T)和存储温度范围(Tstg)。
功能详解:文档提供了电性能参数表和电参数曲线图,展示了不同条件下的正向电压、反向电流等特性。
应用信息:适用于低压高频逆变器和极性保护。
封装信息:采用 SMC 封装,文档还提供了详细的外形尺寸图和机械数据。
SS510C 价格&库存
很抱歉,暂时无法提供与“SS510C”相匹配的价格&库存,您可以联系我们找货
SS510C
    • 5+0.86940
    • 50+0.68278
    • 150+0.58947
    • 500+0.51948
    库存:1886
