78D12
Rev.I Feb.-2019
DATA SHEET
描述 / Descriptions
TO-252 塑封封装电压调整器。Voltage Regulator in a TO-252 Plastic Package.
特征
/ Features
三端稳压调整器,输出电流高达 1.5A,内设过热保护和短路限制。无卤产品。
3-Terminal regulators ,output current up to 1.5A, internal thermal overload protection and short-circuit
limiting. Halogen-free Product.
用途
Applications
电压调整器。
Voltage Regulator.
内部等效电路/应用电路
引脚排列
1
2
Equivalent Circuit or Application Circuit
/ Pinning
4
3
PIN1:IN
印章代码
PIN 2、4:GND
PIN 3:OUT
/ Marking
见印章说明。See Marking Instructions.
http://www.fsbrec.com
1/6
78D12
Rev.I Feb.-2019
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
VI
数值
Rating
35
单位
Unit
V
Thernal Resistance Junction-Ambient
RθJA
65
℃/W
Thernal Resistance Junction-Case
RθJC
5.0
℃/W
Operating Junction Temperature Range
TOPR
0~125
Storage temperature range
Tstg
-65~150
Input voltage
电性能参数 / Electrical Characteristics(Ta=25℃,Vi=19V,Io=500mA,unless otherwise specified)
参数
Parameter
符号
Symbol
Output voltage
VO
Vo
Load Regulation
Vo
Line regulation
Quiescent Current
Iq
Iq
Quiescent Current Change
Output Voltage Drift
Output Noise Voltage
Supply Voltage Rejection
Vo/△T
eN
SVR
测试条件
Test Conditions
Tj=25℃
单位
Unit
11.5
12.0
12.5
V
11.4
12.0
12.6
V
240
mV
120
mV
240
mV
120
mV
Tj=25℃
8.0
mA
Vi=14.5V-30V
1.0
mA
Io=5mA-1A
0.5
mA
Vi=14.5V-27V
Io=5mA-1A
Po≤15W
Tj=25℃
Io=5.0mA-1.5A
Tj=25℃
Io=250mA-750mA
Tj=25℃
Vi=14.5V-30V
Tj=25℃
Vi=16V-22V
Io=5mA
B=10Hz-100KHz
Tj=25℃
Vi=15V-25V
f=120Hz
Tj=25℃
Dropout Voltage
Vd
Io=1A
Output Resistance
Ro
f=1KHz
Short Circuit Current
Isc
Vi=35V
Short Circuit Peak Current
Iscp
Tj=25℃
最小值 典型值 最大值
Min
Typ
Max
Tj=25℃
-1
mV/℃
75
μV/Vo
55
dB
2.0
V
18
mΩ
0.35
A
2.2
A
2/6
78D12
Rev.I Feb.-2019
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
3/6
78D12
Rev.I Feb.-2019
外形尺寸图
DATA SHEET
/ Package Dimensions
4/6
78D12
Rev.I Feb.-2019
印章说明
DATA SHEET
BR
78D12
说明:
BR:
为公司代码
78D12:
为产品型号
为生产批号代码,随生产批号变化。
Note:
BR:
Company Code.
78D12:
Product Type.
Lot No. Code, code change with Lot No.
5/6
78D12
Rev.I Feb.-2019
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Units 包装数量
TO-252
Dimension
包装尺寸
3
(unit:mm )
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
2,500
2
5,000
6
30,000
13〞×16
360×360×50
380×335×366
/ TUBE
Package Type
封装形式
使用说明
Time:10±1 sec
/ REEL
Package Type
封装形式
TO-251/252
Temp:260±5℃
/ Packaging SPEC.
卷盘包装
套管包装
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
(unit:mm3)
Units/Tube
只/套管
Tubes/Inner Box
套管/盒
Units/Inner Box
只/盒
盒/箱
Units/Outer Box
只/箱
Tube 套管
Inner Box 盒
Outer Box 箱
75
48
3,600
5
18,000
526×20.5×5.25
555×164×50
575×290×180
/ Notices
6/6
很抱歉,暂时无法提供与“78D12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.68534
- 50+1.34720
- 150+1.20226
