ES2J
ES2J
    BLUEROCKET(蓝箭电子)
    SMA(DO-214AC)
    快/超快恢复二极管 SMA Vrrm=600V If=2A Ifsm=50A Cj=40pF
ES2J 数据手册
ES2A~ES2J Rev.B Jun.-2021 DATA SHEET 描述 / Descriptions 超快恢复二极管,反向电压:50V~600V,正向电流:2.0A,SMA 封装。 Surface Mount Superfast Recovery Rectifier,Reverse Voltage:50 to600V,Forward Current:2.0A, SMA package. 特征 / Features 玻璃钝化芯片,反向恢复时间快,无铅符合欧盟 RoHS 指令 2011/65/EU,适用于表面贴装。无卤产品。 Glass Passivated Chip Junction,Superfast reverse recovery time,Lead free in comply with EU ROHS 2011/65/EU directives,For surface mounted applications.Halogen free product. 用途 / Applications 一般用途. General purpose. 内部等效电路 / Equivalent Circuit 引脚排列 / Pinning 印章代码 / Marking 见印章说明。See Marking Instructions http://www.fsbrec.com 1/7 ES2A~ES2J Rev.B Jun.-2021 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol Maximum Repetitive Peak Reverse Voltage Maximum RMS voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current at Tc = 125 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load Typical Junction Capacitance at VR =4V,f=1MHZ Typical Thermal ) Resistance 1 Operating and Storage Temperature Range 数值 Rating 单位 Unit ES2A ES2B ES2C ES2D ES2E ES2G ES2J VRRM 50 100 150 200 300 400 600 V VRMS 35 70 105 140 210 280 420 V VDC 50 100 150 200 300 400 600 V IF(AV) 2.0 A IFSM 50 A Cj 40 pF RθJA 60 ℃/W Tj,Tstg -55~+150 ℃ 1)P.C.B. mounted with 1.0 X 1.0" (2.54 X 2.54 cm) copper pad areas. 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Maximum Forward Voltage Maximum DC Reverse Current at Rated DC Blocking Voltage Maximum Reverse Recovery Time 符号 Symbol VF 测试条件 Test Conditions ES2A ES2B ES2C IF=2.0A 数值 Rating ES2D 1.0 ES2E ES2G 1.25 ES2J 单位 Unit 1.68 V Ta=25℃ 5.0 μA Ta=125℃ 100 μA 35 ns IR IF=0.5A trr http://www.fsbrec.com IR=1.0A Irr=0.25A 2/7 ES2A~ES2J Rev.B Jun.-2021 DATA SHEET 电参数曲线图 / Electrical Characteristic Curve http://www.fsbrec.com 3/7 ES2A~ES2J Rev.B Jun.-2021 DATA SHEET 外形尺寸图 / Package Dimensions http://www.fsbrec.com 4/7 ES2A~ES2J Rev.B Jun.-2021 DATA SHEET 印章说明 / Marking Instructions http://www.fsbrec.com 5/7 ES2A~ES2J Rev.B Jun.-2021 DATA SHEET 印章说明 / Marking Instructions ES2A **** 说明: ES2A: **** 为型号代码 : 为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码 Note: ES2A: Product Type Code ****: Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot No Code http://www.fsbrec.com 6/7 ES2A~ES2J Rev.B Jun.-2021 DATA SHEET 回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free) 350 Temperature(℃) 300 245±5℃ 250 5±0.5 sec 200 150 60~90 sec 100 50 0 0 20 40 60 80 100 120 140 160 180 200 220 240 260 280 Time(sec) 说明: Note: 1、预热温度 150~180℃,时间 60~90sec; 1.Preheating:150~180℃, Time:60~90sec. 2、峰值温度 245±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:245±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:260±5℃ 时间:10±1 sec. Temp.:260±5℃ Time:10±1 sec 包装规格 / Packaging SPEC. 卷盘包装 / REEL Package Type 封装形式 SMA Dimension 包装尺寸 (unit:mm3) Units 包装数量 Units/Reel 只/卷盘 Reels/Inner Box 卷盘/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Reel Inner Box 盒 Outer Box 箱 5000 2 10000 7 70000 13〞×12 336X336X40 380X335X366 使用说明 / Notices http://www.fsbrec.com 7/7
很抱歉,暂时无法提供与“ES2J”相匹配的价格&库存,您可以联系我们找货
ES2J
  • 20+0.14516
  • 200+0.11308
  • 600+0.09526
库存:650
