BRFL12N65
BRFL12N65
    BLUEROCKET(蓝箭电子)
    TO-220FL
    MOSFETs TO220FL N-Channel Vdss=650V Id=12A Vgss=±30V Pd=51W
BRFL12N65 数据手册
BRFL12N65 Rev.F Nov.-2017 描述 / DATA SHEET Descriptions TO-220FL 塑封封装 N 沟道 MOS 场效应管。N-CHANNEL MOSFET in a TO-220FL Plastic Package. 特征 / Features 低栅电荷,低反馈电容,开关速度快。 Low gate charge, Low Crss , Fast switching. 用途 / Applications 用于高频开关电源,电子镇流器,UPS 电源。 High efficiency switch mode power supplies, Electronic lamp ballasts based on half bridge, UPS . 内部等效电路 引脚排列 / Equivalent Circuit / Pinning 1 2 3 PIN1:G 放大及印章代码 PIN 2:D PIN 3:S / hFE Classifications & Marking 见印章说明。See Marking Instructions. http://www.fsbrec.com 1/6 BRFL12N65 Rev.F Nov.-2017 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit VDSS 650 V Drain Current ID(Tc=25℃) 12 A Drain Current ID(Tc=100℃) 7.6 A IDM 48 A Gate-Source Voltage VGSS ±30 V Single Pulsed Avalanche Energy EAS 880 mJ Repetitive Avalanche Energy EAR 25 mJ Avalanche Current IAR 12 A Thermal Resistance, Junction to Case RθJC 2.45 ℃/W Thermal Resistance, Junction to Ambient RθJA 62.5 ℃/W PD 51 W TJ,TSTG -55 to 150 ℃ Drain-Source Voltage Drain Current - Pulsed Power Dissipation Operating and Storage Temperature Range 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter 符号 Symbol Drain-Source Breakdown Voltage BVDSS Zero Gate Voltage Drain Current Gate-Body Leakage Current Forward 测试条件 Test Conditions 最小值 典型值 最大值 单位 Min Typ Max Unit VGS=0V ID=250μA 650 V IDSS VDS=650V VGS=0V 1.0 μA IGSS VGS=±30V VDS=0V ±100 nA 4.0 V 0.78 Ω Gate Threshold Voltage VGS(th) VDS=VGS ID=250μA Static Drain-Source On-Resistance RDS(on) VGS=10V ID=6A 0.71 gFS VDS=40V ID=6A 13 VSD VGS=0V IS=12A VDS=25V f=1.0MHz VGS=0V Forward Transconductance Drain-Source Diode Forward Voltage Input Capacitance Ciss 2.0 S 1.39 V 1790 2410 pF 175 229 pF Output Capacitance Coss Reverse Transfer Capacitance Crss 23 31 pF Turn-On Delay Time td(on) 78 102 ns Turn-On Rise Time tr 133 175 ns Turn-Off Delay Time td(off) 233 305 ns 104 160 ns Turn-Off Fall Time http://www.fsbrec.com tf VDD=300V RG=25Ω ID=12A 2/6 BRFL12N65 Rev.F Nov.-2017 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 BRFL12N65 Rev.F Nov.-2017 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 BRFL12N65 Rev.F Nov.-2017 印章说明 / DATA SHEET Marking Instructions BR 12N65 ****  说明: BR:   为公司代码 12N65:  为型号代码 ****:  为生产批号代码,随生产批号变化。  Company Code Note: BR:   12N65: ****: http://www.fsbrec.com Product Type.  Lot No. Code, code change with Lot No. 5/6 BRFL12N65 Rev.F Nov.-2017 DATA SHEET 波峰焊温度曲线图(无铅) / Temperature Profile for Dip Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 255±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:255±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:270±5℃ 包装规格 Package Type 封装形式 使用说明 Temp.:270±5℃ Time:10±1 sec / Packaging SPEC. 套管包装 TO-220FL 时间:10±1 sec. / TUBE Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) Units/Tube 只/套管 Tubes/Inner Box 套管/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Tube 套管 Inner Box 盒 Outer Box 箱 50 20 1,000 5 5,000 532×33×7.0 555×164×50 575×290×180 / Notices http://www.fsbrec.com 6/6
BRFL12N65 价格&库存
很抱歉,暂时无法提供与“BRFL12N65”相匹配的价格&库存,您可以联系我们找货
BRFL12N65
  • 1+3.61800
  • 10+2.82960
  • 50+2.49480
库存:69
